PESD5V0S1BBN
ESD Protection Diode
»Features
75Watts peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±25kV contact ±25kVair
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 5A (8/20μs)
»Applications
»Mechanical Data
Microprocessor based equipment
SOD523 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
»Schematic & PIN Configuration
SOD-523
Revision 2018
www.born-tw.com
1/4
PESD5V0S1BBN
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
75
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
5
A
VESD
25
25
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-OffVoltage
Reverse BreakdownVoltage
Conditions
Min
Typical
VRWM
Max
Units
5.0
V
VBR
IT=1mA
6.0
V
Reverse LeakageCurrent
IR
VRWM=5V,T=25℃
0.2
uA
Clamping Voltage
VC
IPP=5A,tp=8/20μs
15
V
Junction Capacitance
Cj
VR = 0V, f =1MHz
10
pF
8
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRW M
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC V BR
V RWM
IT
IR
ITIR
VRWM
V BR V C
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD5V0S1BBN
»Typical Characteristics
Figure 1: Peak Pulse Power vs. Pulse Time
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
100
1
75w 8/20μs waveform
0.1
0.01
0.1
1
10
100
td – Pulse Duration - µs
90
Ipp
80
Percent
50
40
30
50
75
100
125
Ambient Temperature - TA (℃)
150
Test
Waveform
Paramters
tr=8µs
td=20µs
40
Clamping Voltage–VC (V)
100
e
-1
50
40
td=Ipp/2
45
Waveform
Paramters
tr=8µs
td=20µs
30
70
Figure 4: Clamping Voltage vs.Ipp
110
60
80
1,000
Figure3: Pulse Waveform
70
90
10
35
30
25
10
5
Revision 2018
10
15
Time (µs)
30
2
3
4
5
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PESD5V0S1BBN
»Outline Drawing – SOD523
D
-X-Y-
1
2
E
DIMENSIONS
SYMBOL
b 2x
0.08 (0.0032)
X
A
b
C
D
E
HE
L
Y
A
C
HE
L
MILLIMETER
INCHES
MIN
MAX
MIN
MAX
0.50
0.25
0.07
1.10
0.70
1.50
0.15
0.70
0.35
0.20
1.30
0.90
1.70
0.25
0.020
0.010
0.0028
0.043
0.028
0.059
0.006
0.028
0.014
0.0079
0.051
0.035
0.067
0.010
»Marking
1
5XB
2
»Ordering information
Order code
Package
Base qty
Delivery mode
PESD5V0S1BBN
SOD523
5000
Tape and reel
Revision 2018
www.born-tw.com
4/4
很抱歉,暂时无法提供与“PESD5V0S1BBN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.43142
- 500+0.14416
- 2500+0.09572
- 5000+0.07844
- 国内价格
- 20+0.15870
- 500+0.11237
- 2000+0.11068
- 5000+0.08435
- 国内价格
- 20+0.17120
- 200+0.13620
- 600+0.12070
- 5000+0.09020
- 10000+0.08570
- 20000+0.08260
- 国内价格
- 20+0.17313
- 200+0.13814
- 600+0.12258
- 5000+0.09202
- 10000+0.08738
- 20000+0.08424
