Datasheet
5A 180KHz 36V Buck DC to DC Converter
XL4015
Features
General Description
n
n
n
n
n
n
n
n
n
n
n
n
n
The XL4015 is a 180 KHz fixed frequency
PWM buck (step-down) DC/DC converter,
capable of driving a 5A load with high
efficiency, low ripple and excellent line and
load regulation. Requiring a minimum
number of external components, the regulator
is simple to use and include internal
frequency
compensation
and
a
fixed-frequency oscillator.
Wide 8V to 36V Input Voltage Range
Output Adjustable from 1.25V to 32V
Maximum Duty Cycle 100%
Minimum Drop Out 0.3V
Fixed 180KHz Switching Frequency
5A Constant Output Current Capability
Internal Optimize Power MOSFET
High efficiency up to 96%
Excellent line and load regulation
Built in thermal shutdown function
Built in current limit function
Built in output short protection function
Available in TO263-5L package
The PWM control circuit is able to adjust the
duty ratio linearly from 0 to 100%. An over
current protection function is built inside.
When short protection function happens, the
operation frequency will be reduced from
180KHz to 48KHz. An internal compensation
block is built in to minimize external
component count.
Applications
n
n
n
LCD Monitor and LCD TV
Portable instrument power supply
Telecom / Networking Equipment
Figure1. Package Type of XL4015
Rev 1.3
www.xlsemi.com
1
Datasheet
XL4015
Pin Configurations
Figure2. Pin Configuration of XL4015 (Top View)
Table 1 Pin Description
Pin Number
Pin Name
1
GND
2
FB
3
SW
4
VC
5
VIN
Description
Ground Pin. Care must be taken in layout. This pin should be
placed outside of the Schottky Diode to output capacitor
ground path to prevent switching current spikes from inducing
voltage noise into XL4015.
Feedback Pin (FB). Through an external resistor divider
network, FB senses the output voltage and regulates it. The
feedback threshold voltage is 1.25V.
Power Switch Output Pin (SW). SW is the switch node that
supplies power to the output.
Internal Voltage Regulator Bypass Capacity. In typical system
application, The VC pin connect a 1uf capacity to VIN.
Supply Voltage Input Pin. XL4015 operates from a 8V to 36V
DC voltage. Bypass Vin to GND with a suitably large
capacitor to eliminate noise on the input.
Rev 1.3
www.xlsemi.com
2
Datasheet
XL4015
Function Block
Figure3. Function Block Diagram of XL4015
Typical Application Circuit
Figure4. XL4015 Typical Application Circuit (VIN=8V~36V, VOUT=5V/5A)
Rev 1.3
www.xlsemi.com
3
Datasheet
XL4015
Ordering Information
Order Information
XL4015E1
Marking ID
XL4015E1
Package Type
TO263-5L
Packing Type Supplied As
800 Units on Tape & Reel
XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant.
Absolute Maximum Ratings(Note1)
Parameter
Symbol
Vin
VFB
VOutput
PD
Value
-0.3 to 40
-0.3 to Vin
-0.3 to Vin
Internally limited
Unit
V
V
V
mW
Input Voltage
Feedback Pin Voltage
Output Switch Pin Voltage
Power Dissipation
Thermal Resistance (TO263-5L)
(Junction to Ambient, No Heatsink, Free Air)
Operating Junction Temperature
Storage Temperature
Lead Temperature (Soldering, 10 sec)
ESD (HBM)
RJA
30
ºC/W
TJ
TSTG
TLEAD
-40 to 125
-65 to 150
260
>2000
ºC
ºC
ºC
V
Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage
to the device. This is a stress rating only and functional operation of the device at these or any
other conditions above those indicated in the operation is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect reliability.
Rev 1.3
www.xlsemi.com
4
Datasheet
XL4015
XL4015 Electrical Characteristics
Ta = 25℃;unless otherwise specified.
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Unit
1.225
1.25
1.275
V
87
93
System parameters test circuit figure4
Feedback
Voltage
VFB
Efficiency
ŋ
Efficiency
ŋ
Vin = 8V to 40V, Vout=5V
Iload=0.5A to 5A
Vin=12V ,Vout=5V
Iout=5A
Vin=24V ,Vout=12V
Iout=4A
Electrical Characteristics (DC Parameters)
Vin = 12V, GND=0V, Vin & GND parallel connect a 220uf/50V capacitor; Iout=500mA, Ta =
25℃; the others floating unless otherwise specified.
Parameters
Input operation voltage
Quiescent Supply Current
Symbol
Vin
Fosc
Output Short Frequency
Fosp
Min.
Typ.
Max.
Unit
36
V
2.1
5
mA
180
216
KHz
8
Iq
Oscillator Frequency
Switch Current Limit
Test Condition
VFB =Vin
144
48
KHz
IL
VFB =0
7
A
Max. Duty Cycle
DMAX
VFB=0V
100
Output Power PMOS
Rdson
VFB=0V, Vin=12V,
ISW=5A
60
Rev 1.3
80
mohm
www.xlsemi.com
5
Datasheet
XL4015
Typical System Application (VOUT=5V/5A)
Figure5. XL4015 System Parameters Test Circuit (VIN=8V~36V, VOUT=5V/5A)
Efficiency VS Output current
100
95
90
Efficiency(%)
85
80
75
VIN=8V,VOUT=5V,IOUT=0.1A~5A
VIN=12V,VOUT=5V,IOUT=0.1A~5A
VIN=24V,VOUT=5V,IOUT=0.1A~5A
VIN=36V,VOUT=5V,IOUT=0.1A~5A
70
65
60
55
50
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
Load current(A)
Figure6. XL4015 System Efficiency Curve
Rev 1.3
www.xlsemi.com
6
Datasheet
XL4015
Typical System Application (VOUT=12V/4A)
Figure7. XL4015 System Parameters Test Circuit (VIN=15V~36V, VOUT=12V/4A)
100
95
90
Efficiency(%)
85
80
VIN=15V,VOUT=12V,IOUT=0.1A~4A
VIN=24V,VOUT=12V,IOUT=0.1A~4A
VIN=36V,VOUT=12V,IOUT=0.1A~4A
75
70
65
60
55
50
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
Output current(A)
Figure8. XL4015 System Efficiency Curve
Rev 1.3
www.xlsemi.com
7
Datasheet
XL4015
Typical System Application (TTL shutdown function)
Logic level signals shutdown function can be used in typical system application with external
components. When the TTL high voltage above 3.3V(referenced to ground, lower than VIN), the
converter will shutdown, input current less than 5mA; when the TTL Low voltage below
0.8V(referenced to ground), the converter will turn on.
L1 47uH/5A
VIN 5
VC
CIN
220uF/50V
C1
105
4
1
GND
VOUT=1.25*(1+R2/R1)
SW
D1
B540
XL4015
CC
105
VIN
3
2 FB
R3
10K
C2
105
COUT
330uF/25V
R2
10K
D2
1N4148
OFF(High>3.3V)
R1
3.3K
ON(Low
很抱歉,暂时无法提供与“XL4015E1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.66200
- 50+2.04600
- 800+1.89200
- 国内价格
- 1+4.04910
- 10+3.47490
- 160+2.74230
- 320+2.15820
- 800+2.09880
- 4000+2.07781
- 国内价格
- 1+4.41720
- 10+3.79080
- 30+3.35880
- 100+2.99160
- 500+2.35440
- 800+2.28960
- 国内价格
- 50+2.01242
- 500+1.98880
