XM25QH128AHIG
XM25QH128AHIG
    XMC(新芯)
    SOP8_208MIL
    存储器容量:128Mb (256 Bytes x 65535 pages) 存储器构架(格式):FLASH 存储器类型:Non-Volatile 存储器接口类型:SPI - Dual/Quad I/O...
XM25QH128AHIG 数据手册
XM25QH128A XM25QH128A preliminary 128 Megabit 3V Serial Flash Memory with 4Kbyte Uniform Sector FEATURES      -    -   - Single power supply operation Full voltage range: 2.7-3.6 volt Serial Interface Architecture SPI Compatible: Mode 0 and Mode 3 128 M-bit Serial Flash 128 M-bit / 16,384 KByte /65,535 pages 256 bytes per programmable page Standard, Dual or Quad SPI Standard SPI: CLK, CS#, DI, DO, WP#, HOLD#/RESET# Dual SPI: CLK, CS#, DQ0, DQ1, WP#, HOLD#/RESET# Quad SPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3 Configurable dummy cycle number High performance Normal read - 50MHz Fast read (Single Data Rate Mode) - Standard SPI: 104MHz with 1 dummy bytes - Dual SPI: 104MHz with 1 dummy bytes - Quad SPI: 104MHz with 3 dummy bytes Write Suspend and Write Resume Support Serial Flash Discoverable Parameters (SFDP) signature Low power consumption 5 mA typical active current 1A typical power down current          Uniform Sector Architecture: 4096 sectors of 4-Kbyte 512 blocks of 32-Kbyte 256 blocks of 64-Kbyte Any sector or block can be erased individually Software and Hardware Write Protection: Write Protect all or portion of memory via software Enable/Disable protection with WP# pin Software and Hardware Reset High performance program/erase speed Page program time: 0.5ms typical Sector erase time: 40ms typical Half Block erase time 200ms typical Block erase time 300ms typical Chip erase time: 60 Seconds typical Volatile Status Register Bits. Lockable 512 byte OTP security sector Read Unique ID Number Typical 100K endurance cycle Data retention time 20years Package Options SOP 208mil 8L WSON 5x6 8L TFBGA 6x8 24ball All Pb-free packages are compliant RoHS, Halogen-Free and REACH. Industrial temperature Range GENERAL DESCRIPTION The XM25QH128A is a 128 Megabit (16,384K-byte) Serial Flash memory, with advanced write protection mechanisms. The XM25QH128A supports the single bit and four bits serial input and output commands via standard Serial Peripheral Interface (SPI) pins: Serial Clock, Chip Select, Serial DQ 0 (DI) and DQ1(DO), DQ2(WP#) and DQ3(HOLD#/RESET#). SPI clock frequencies of up to 104Mhz are supported allowing equivalent clock rates of 416Mhz(104Mhz x 4) for Quad Output while using the Quad Output read instructions. The memory can be programmed 1 to 256 bytes at a time, using the Page Program instruction. The XM25QH128A also offers a sophisticated method for protecting individual blocks against erroneous or malicious program and erase operations. By providing the ability to individually protect and unprotect blocks, a system can unprotect a specific block to modify its contents while keeping the remaining blocks of the memory array securely protected. This is useful in applications where program code is patched or updated on a subroutine or module basis or in applications where data storage segments need to be modified without running the risk of errant modifications to the program code segments. The XM25QH128A is designed to allow either single Sector/Block at a time or full chip erase operation. The XM25QH128A can be configured to protect part of the memory as the software protected mode. The device can sustain a typical of 100K program/erase cycles on each sector or block. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 1 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Figure.1 CONNECTION DIAGRAMS preliminary CS# 1 8 VCC DO (DQ1) 2 7 HOLD#/RESET# (DQ3) WP# (DQ2) 3 6 CLK 4 5 DI (DQ0) VSS 8 - LEAD SOP CS# 1 8 VCC DO (DQ1) 2 7 HOLD#/RESET# (DQ3) WP# (DQ2) 3 6 CLK 4 5 DI (DQ0) VSS 8 – LEAD WSON Top View, Balls Facing Down 24 - Ball TFBGA This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 2 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Table 1. Pin Names Symbol Pin Name CLK Serial Clock Input DI (DQ0) Serial Data Input (Data Input Output 0) DO (DQ1) Serial Data Output (Data Input Output 1) CS# Chip Enable WP# (DQ2) Write Protect (Data Input Output 2) HOLD#/RESET# (DQ3) *1 *1 *2 HOLD# or RESET# pin (Data Input Output 3) *2 Vcc Supply Voltage (2.7-3.6V) Vss Ground NC No Connect Note: 1. DQ0 and DQ1 are used for Dual and Quad instructions. 2. DQ0 ~ DQ3 are used for Quad instructions, WP# & HOLD# (or RESET#) functions are only available for Standard/Dual SPI. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 3 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 2. BLOCK DIAGRAM Flash Memory X-Decoder Address Buffer And Latches Y-Decoder I/O Buffers and Data Latches Control Logic Serial Interface CS# CLK DI (DQ0) DO (DQ1) WP# (DQ2) HOLD# / RESET# (DQ3) Note: 1. DQ0 and DQ1 are used for Dual instructions. 2. DQ0 ~ DQ3 are used for Quad instructions. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 4 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A SIGNAL DESCRIPTION preliminary Serial Data Input, Output and IOs (DI, DO and DQ0, DQ1, DQ2, DQ3) The XM25QH128A support standard SPI, Dual SPI and Quad SPI operation. Standard SPI instructions use the unidirectional DI (input) pin to serially write instructions, addresses or data to the device on the rising edge of the Serial Clock (CLK) input pin. Standard SPI also uses the unidirectional DO (output) to read data or status from the device on the falling edge CLK. Dual and Quad SPI instruction use the bidirectional IO pins to serially write instruction, addresses or data to the device on the rising edge of CLK and read data or status from the device on the falling edge of CLK. Serial Clock (CLK) The SPI Serial Clock Input (CLK) pin provides the timing for serial input and output operations. ("See SPI Mode") Chip Select (CS#) The SPI Chip Select (CS#) pin enables and disables device operation. When CS# is high the device is deselected and the Serial Data Output (DO, or DQ0, DQ1, DQ2 and DQ3) pins are at high impedance. When deselected, the devices power consumption will be at standby levels unless an internal erase, program or status register cycle is in progress. When CS# is brought low the device will be selected, power consumption will increase to active levels and instructions can be written to and data read from the device. After power-up, CS# must transition from high to low before a new instruction will be accepted. Write Protect (WP#) The Write Protect (WP#) pin can be used to prevent the Status Register from being written. Used in conjunction with the Status Register’s Block Protect (SR.5, SR.4, SR.3, SR.2) bits and Status Register Protect (SRP) bits, a portion or the entire memory array can be hardware protected. The WP# function is only available for standard SPI and Dual SPI operation, when during Quad SPI, this pin is the Serial Data IO (DQ2) for Quad I/O operation. HOLD (HOLD#) The HOLD# pin allows the device to be paused while it is actively selected. When WXDIS bit is “0” (factory default) and HRSW bit is ‘0’ (factory default is ‘0’), the HOLD# pin is enabled. When HOLD# is brought low, while CS# is low, the DO pin will be at high impedance and signals on the DI and CLK pins will be ignored (don’t care). The hold function can be useful when multiple devices are sharing the same SPI signals. The HOLD# function is only available for standard SPI and Dual SPI operation, when during Quad SPI, this pin is the Serial Data IO (DQ3) for Quad I/O operation. RESET (RESET#) The RESET# pin allows the device to be reset by the controller. When WXDIS bit is “0” (factory default) and HRSW bit is ‘1’ (factory default is ‘0’), the RESET# pin is enabled. The Hardware Reset function is only available for standard SPI and Dual SPI operation, when during Quad SPI, this pin is the Serial Data IO (DQ3) for Quad I/O operation. Set RESET# to low for a minimum period 1us (tHRST) will interrupt any on-going instructions to have the device to initial state. The device can accept new instructions again in 28us (tHRSL) after RESET# back to high. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 5 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A MEMORY ORGANIZATION preliminary The memory is organized as:  16,777,216 bytes  Uniform Sector Architecture 256 blocks of 64-Kbyte 512 blocks of 32-Kbyte 4,096 sectors of 4-Kbyte 65,536 pages (256 bytes each) Each page can be individually programmed (bits are programmed from 1 to 0). The device is Sector, Block or Chip Erasable but not Page Erasable. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 6 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 2. Uniform Block Sector Architecture ( 1/4 ) 418 417 208 416 3344 3343 D10000h D0F000h D10FFFh D0FFFFh 3328 D00000h D00FFFh This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. …. …. …. …. …. …. …. …. …. …. …. …. …. …. …. E20FFFh E1FFFFh …. 449 3600 3599 E10000h E0F000h E10FFFh E0FFFFh …. 448 3584 E00000h E00FFFh 32K Block Sector 415 3327 …. 414 3312 3311 CF0000h CEF000h CF0FFFh CEFFFFh 450 224 64K Block 207 …. CFFFFFh 411 3296 3295 CE0000h CDF000h CE0FFFh CDFFFFh 410 3280 CD0000h CD0FFFh 206 412 …. 205 389 3119 C2F000h C2FFFFh 388 3014 3103 C20000h C1F000h C20FFFh C1FFFFh 194 387 385 3088 3087 C10000h C0F000h C10FFFh C0FFFFh 384 3072 C00000h C00FFFh 193 386 192 7 CFF000h …. 413 Address range …. 419 209 E20000h E1F000h …. D20FFFh D1FFFFh 3616 3615 …. D20000h D1F000h 452 451 …. …. …. 3360 3359 …. 420 210 …. D2FFFFh …. D2F000h …. 3375 …. 421 E2FFFFh …. …. …. DD0FFFh …. …. DD0000h …. 3536 …. DE0FFFh DDFFFFh …. DE0000h DDF000h …. 442 3552 3551 …. 443 221 …. 444 E2F000h 225 DFFFFFh …. 445 222 3631 …. DF0FFFh DEFFFFh 453 …. DF0000h DEF000h ED0FFFh …. 3568 3567 ED0000h …. 446 223 3792 226 Address range DFF000h 474 237 …. 3583 EE0FFFh EDFFFFh …. 447 EE0000h EDF000h …. Sector 475 3808 3807 476 …. 32K Block 477 238 …. F00FFFh EF0FFFh EEFFFFh …. F00000h EF0000h EEF000h EFFFFFh …. 3840 240 3824 3823 EFF000h …. …. …. 480 …. F10FFFh F0FFFFh …. F10000h F0F000h …. 3856 3855 …. …. …. F20FFFh F1FFFFh …. 481 F20000h F1F000h …. 482 3872 3871 …. 483 241 …. F2FFFFh 478 239 …. F2F000h 3839 …. …. …. FD0FFFh …. …. …. FD0000h …. 4048 …. FE0FFFh FDFFFFh 3887 484 …. FE0000h FDF000h 485 242 64K Block 4064 4063 …. …. 506 FF0FFFh FEFFFFh …. 507 253 FF0000h FEF000h …. 508 …. 509 254 4080 4079 …. 510 …. 255 479 …. FFFFFFh Address range …. FFF000h Sector …. 4095 32K Block …. 511 64K Block Address range …. Sector …. 32K Block …. 64K Block preliminary Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 2. Uniform Block Sector Architecture ( 2/4 ) 910FFFh 90FFFFh 2304 900000h 900FFFh This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. …. …. …. …. …. …. …. …. …. …. …. …. A2FFFFh …. …. …. 324 2592 2591 A20000h A1F000h A20FFFh A1FFFFh …. …. 321 2576 2575 A10000h A0F000h A10FFFh A0FFFFh …. …. 320 2560 A00000h A00FFFh 32K Block Sector 287 2303 …. …. 323 286 2288 2287 8F0000h 8EF000h 8F0FFFh 8EFFFFh 322 160 64K Block 143 …. …. 283 8E0000h 8DF000h 8E0FFFh 8DFFFFh …. 8FFFFFh 2272 2271 282 2256 8D0000h 8D0FFFh 142 284 …. 261 2095 82F000h 82FFFFh …. 141 260 2080 2079 820000h 81F000h 820FFFh 81FFFFh 130 259 257 2064 2063 810000h 80F000h 810FFFh 80FFFFh 256 2048 800000h 800FFFh 129 258 128 8 8FF000h …. 285 Address range …. 910000h 90F000h A2F000h …. …. 288 2320 2319 …. 289 144 920FFFh 91FFFFh …. 290 920000h 91F000h …. 291 145 2336 2335 …. 292 …. 92FFFFh …. 92F000h …. 2351 2607 …. …. 293 146 325 …. 9D0FFFh AD0FFFh …. 9D0000h AD0000h 161 …. …. 2512 …. …. …. 9E0FFFh 9DFFFFh …. 9E0000h 9DF000h …. …. 2528 2527 …. 314 …. 315 157 9F0FFFh 9EFFFFh …. 316 9F0000h 9EF000h …. 317 158 2544 2543 2768 162 Address range …. 318 346 173 …. 9FFFFFh AE0FFFh ADFFFFh …. 9FF000h AE0000h ADF000h …. 2559 347 2784 2783 348 …. 319 159 349 174 …. Sector AF0FFFh AEFFFFh …. 32K Block AF0000h AEF000h …. B00FFFh 2800 2799 AFFFFFh …. B00000h 350 AFF000h …. 2816 2815 …. 352 176 351 Address range …. …. B10FFFh B0FFFFh …. B10000h B0F000h …. 2832 2831 …. 353 B20FFFh B1FFFFh …. 354 B20000h B1F000h …. 355 177 2848 2847 …. 356 …. B2FFFFh …. B2F000h Sector …. 2863 32K Block 175 …. …. BD0FFFh …. BD0000h …. 3024 …. BE0FFFh BDFFFFh 357 178 …. BE0000h BDF000h …. …. 378 …. 379 189 3040 3039 …. …. BF0FFFh BEFFFFh …. BF0000h BEF000h …. 3056 3055 380 BFFFFFh …. 382 382 BFF000h …. 3071 190 64K Block Address range 383 191 64K Block Sector …. 32K Block …. 64K Block preliminary Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A …. 160 1296 1295 510000h 50F000h 510FFFh 50FFFFh …. 161 80 1280 500000h 500FFFh This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. …. …. …. …. …. …. …. …. …. …. …. …. …. …. …. 620FFFh 61FFFFh …. 193 1552 1551 610000h 60F000h 610FFFh 60FFFFh …. 192 1536 600000h 600FFFh 32K Block Sector 159 1279 …. 195 158 1264 1263 4F0000h 4EF000h 4F0FFFh 4EFFFFh 194 96 64K Block 79 …. 4FFFFFh 155 1248 1247 4E0000h 4DF000h 4E0FFFh 4DFFFFh 154 1232 4D0000h 4D0FFFh 78 156 77 133 1071 42F000h 42FFFFh 132 1056 1055 420000h 41F000h 420FFFh 41FFFFh 66 131 129 1040 1039 410000h 40F000h 410FFFh 40FFFFh 128 1024 400000h 400FFFh 65 130 64 9 4FF000h …. 157 Address range …. 520FFFh 51FFFFh …. 162 520000h 51F000h …. 163 81 1312 1311 …. 164 …. 52FFFFh …. 52F000h …. 1327 620000h 61F000h …. …. 165 82 1568 1567 …. 5D0FFFh 196 …. 5D0000h 62FFFFh 97 …. …. 1488 …. …. …. 5E0FFFh 5DFFFFh …. 5E0000h 5DF000h …. …. 1504 1503 …. 186 …. 187 93 5F0FFFh 5EFFFFh …. 188 5F0000h 5EF000h …. 189 94 1520 1519 62F000h 98 Address range …. 190 1583 …. 5FFFFFh 197 …. 5FF000h 6D0FFFh …. 1535 6D0000h …. 191 95 1744 …. Sector 218 109 …. 32K Block 6E0FFFh 6DFFFFh …. 700FFFh 6E0000h 6DF000h …. 700000h 219 1760 1759 220 …. 1792 221 …. 224 112 6F0FFFh 6EFFFFh …. 710FFFh 70FFFFh 6F0000h 6EF000h 110 …. …. …. …. 710000h 70F000h …. 1808 1807 …. …. 720FFFh 71FFFFh …. 225 720000h 71F000h …. 226 1824 1823 …. 227 113 …. 72FFFFh …. 72F000h 1776 1775 6FFFFFh …. …. …. 7D0FFFh …. 7D0000h …. 2000 1839 228 …. 7E0FFFh 7DFFFFh 229 114 64K Block 7E0000h 7DF000h …. …. 250 2016 2015 …. 251 125 …. 252 …. 253 126 222 111 6FF000h …. 7F0FFFh 7EFFFFh 1791 …. 7F0000h 7EF000h 223 …. …. 2032 2031 7FFFFFh Address range …. …. 254 127 7FF000h Sector …. 2047 32K Block …. 255 64K Block Address range …. Sector preliminary …. 32K Block …. 64K Block …. Table 2. Uniform Block Sector Architecture ( 3/4 ) Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 2. Uniform Block Sector Architecture ( 4/4 ) 4095 3FF000h 3FFFFFh …. …. …. …. …. …. …. 2D0000h 2D0FFFh 1F0FFFh 1EFFFFh …. …. …. …. …. …. 255 30 240 239 0F0000h 0EF000h 0F0FFFh 0EFFFFh 15 …. …. …. …. …. …. 0FFFFFh …. 29 0FF000h 100FFFh This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. …. …. …. …. …. …. …. 02FFFFh 4 32 31 020000h 01F000h 020FFFh 01FFFFh 2 3 1 2 1 0 0 10 …. …. 100000h 02F000h 16 15 010000h 00F000h 010FFFh 00FFFFh …. …. 256 47 …. 110FFFh 10FFFFh 5 …. …. 110000h 10F000h 13 …. …. 272 271 28 …. …. 120FFFh 11FFFFh 14 …. …. …. …. 31 Address range 0D0FFFh …. …. Sector 0D0000h 120000h 11F000h 32 32K Block 208 288 287 33 64K Block 26 36 16 200FFFh 1D0FFFh 12FFFFh 34 200000h 1D0000h 12F000h 35 512 27 303 17 64 32 0E0FFFh 0DFFFFh 37 18 210FFFh 20FFFFh 0E0000h 0DF000h …. 464 210000h 20F000h 224 223 …. 1E0FFFh 1DFFFFh …. 1E0000h 1DF000h …. 58 480 479 65 528 527 66 …. 59 29 …. 60 67 33 1FFFFFh …. 61 220FFFh 21FFFFh …. 1F0000h 1EF000h 220000h 21F000h …. 496 495 544 543 …. 62 68 34 Address range 1FF000h 22FFFFh …. 511 22F000h …. 63 559 …. Sector 69 …. 32K Block 45 …. 300FFFh 92 …. …. …. 300000h …. 310FFFh 30FFFFh …. 310000h 30F000h …. 784 783 …. …. …. 320FFFh 31FFFFh …. …. 320000h 31F000h …. 800 799 46 …. …. 720 …. …. …. 90 768 30 93 3D0FFFh 96 31 2F0FFFh 2EFFFFh 3D0000h …. 97 48 2F0000h 2EF000h …. 98 752 751 2FFFFFh 91 32FFFFh 99 94 47 2FF000h 2E0FFFh 2DFFFFh 32F000h 49 767 2E0000h 2DF000h …. 4048 95 Address range 736 735 …. 3E0FFFh 3DFFFFh 815 100 …. 3E0000h 3DF000h 101 50 64K Block 4064 4063 …. …. 122 3F0FFFh 3EFFFFh …. 123 61 3F0000h 3EF000h Sector …. 124 …. 125 62 4080 4079 …. 126 …. 63 32K Block …. 127 64K Block Address range …. Sector …. 32K Block …. 64K Block preliminary 0 000000h 000FFFh Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A OPERATING FEATURES preliminary Standard SPI Modes The XM25QH128A is accessed through an SPI compatible bus consisting of four signals: Serial Clock (CLK), Chip Select (CS#), Serial Data Input (DI) and Serial Data Output (DO). Both SPI bus operation Modes 0 (0,0) and 3 (1,1) are supported. The primary difference between Mode 0 and Mode 3, as shown in Figure 3, concerns the normal state of the CLK signal when the SPI bus master is in standby and data is not being transferred to the Serial Flash. For Mode 0 the CLK signal is normally low. For Mode 3 the CLK signal is normally high. In either case data input on the DI pin is sampled on the rising edge of the CLK. Data output on the DO pin is clocked out on the falling edge of CLK. Figure 3. SPI Modes Dual SPI Instruction The XM25QH128A supports Dual SPI operation when using the “Dual Output Fast Read and Dual I/ O FAST_READ “ (3Bh and BBh) instructions. These instructions allow data to be transferred to or from the Serial Flash memory at two to three times the rate possible with the standard SPI. The Dual Read instructions are ideal for quickly downloading code from Flash to RAM upon power-up (code-shadowing) or for application that cache code-segments to RAM for execution. The Dual output feature simply allows the SPI input pin to also serve as an output during this instruction. When using Dual SPI instructions the DI and DO pins become bidirectional I/O pins; DQ0 and DQ1. All other operations use the standard SPI interface with single output signal. Quad I/O SPI Modes The XM25QH128A supports Quad input/output operation when using the Quad I/O Fast Read (EBh).This instruction allows data to be transferred to or from the Serial Flash memory at four to six times the rate possible with the standard SPI. The Quad Read instruction offer a significant improvement in continuous and random access transfer rates allowing fast code-shadowing to RAM or for application that cache code-segments to RAM for execution. When using Quad SPI instruction the DI and DO pins become bidirectional I/O pins; DQ0 and DQ1, and the WP# and HOLD#/RESET# pins become DQ2 and DQ3 respectively. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 11 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Figure 4. Quad SPI Modes preliminary Full Quad SPI Modes (QPI) The XM25QH128A also supports Full Quad SPI Mode (QPI) function while using the Enable Quad Peripheral Interface mode (EQPI) (38h). When using Quad SPI instruction the DI and DO pins become bidirectional I/O pins; DQ0 and DQ1, and the WP# and HOLD#/RESET# pins become DQ2 and DQ3 respectively. Figure 5. Full Quad SPI Modes This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 12 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Page Programming preliminary To program one data byte, two instructions are required: Write Enable (WREN), which is one byte, and a Page Program (PP) or Quad Input Page Program (QPP) sequence, which consists of four bytes plus data. This is followed by the internal Program cycle (of duration tPP). To spread this overhead, the Page Program (PP) or Quad Input Page Program (QPP) instruction allows up to 256 bytes to be programmed at a time (changing bits from 1 to 0) provided that they lie in consecutive addresses on the same page of memory. Sector Erase, Half Block Erase, Block Erase and Chip Erase The Page Program (PP) or Quad Input Page Program (QPP) instruction allows bits to be reset from 1 to 0. Before this can be applied, the bytes of memory need to have been erased to all 1s (FFh). This can be achieved a sector at a time, using the Sector Erase (SE) instruction, half a block at a time using the Half Block Erase (HBE) instruction, a block at a time using the Block Erase (BE) instruction or throughout the entire memory, using the Chip Erase (CE) instruction. This starts an internal Erase cycle (of duration tSE, tHBE,, tBE or tCE). The Erase instruction must be preceded by a Write Enable (WREN) instruction. Polling During a Write, Program or Erase Cycle A further improvement in the time to Write Status Register (WRSR), Program (PP, QPP) or Erase (SE, HBE, BE or CE) can be achieved by not waiting for the worst case delay (tW , tPP, tSE, tHBE, tBE or tCE). The Write In Progress (WIP) bit is provided in the Status Register so that the application program can monitor its value, polling it to establish when the previous Write cycle, Program cycle or Erase cycle is complete. Active Power, Stand-by Power and Deep Power-Down Modes When Chip Select (CS#) is Low, the device is enabled, and in the Active Power mode. When Chip Select (CS#) is High, the device is disabled, but could remain in the Active Power mode until all internal cycles have completed (Program, Erase, Write Status Register). The device then goes into the Stand-by Power mode. The device consumption drops to ICC1. The Deep Power-down mode is entered when the specific instruction (the Enter Deep Power-down Mode (DP) instruction) is executed. The device consumption drops further to ICC2. The device remains in this mode until another specific instruction (the Release from Deep Power-down Mode and Read Device ID (RDI) instruction) is executed. All other instructions are ignored while the device is in the Deep Power-down mode. This can be used as an extra software protection mechanism, when the device is not in active use, to protect the device from inadvertent Write, Program or Erase instructions. Write Protection Applications that use non-volatile memory must take into consideration the possibility of noise and other adverse system conditions that may compromise data integrity. To address this concern the XM25QH128A provides the following data protection mechanisms:  Power-On Reset and an internal timer (tPUW ) can provide protection against inadvertent changes while the power supply is outside the operating specification.  Program, Erase and Write Status Register instructions are checked that they consist of a number of clock pulses that is a multiple of eight, before they are accepted for execution.  All instructions that modify data must be preceded by a Write Enable (WREN) instruction to set the Write Enable Latch (WEL) bit. This bit is returned to its reset state by the following events: – Power-up – Write Disable (WRDI) instruction completion or Write Status Register (WRSR) instruction completion or Page Program (PP), Quad Input Page Program (QPP) instruction completion or Sector Erase (SE) instruction completion or Half Block Erase (HBE) / Block Erase (BE) instruction completion or Chip Erase (CE) instruction completion – Software/Hardware Reset completion  The Block Protect (BP3, BP2, BP1, BP0) bits allow part of the memory to be configured as readonly. This is the Software Protected Mode (SPM).  The Write Protect (WP#) signal allows the Block Protect (BP3, BP2, BP1, BP0) bits and Status Register Protect (SRP) bit to be protected. This is the Hardware Protected Mode (HPM).  In addition to the low power consumption feature, the Deep Power-down mode offers extra software protection from inadvertent Write, Program and Erase instructions, as all instructions are ignored except one particular instruction (the Release from Deep Power-down instruction). This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 13 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 3. Protected Area Sizes Sector Organization Status Register Content preliminary Memory Content T/B SR.5 SR.4 SR.3 SR.2 Protect Areas Addresses Density(KB) Portion Bit Bit Bit Bit Bit 0 0 0 0 0 None None None None 0 0 0 0 1 Block 252 to 255 FC0000h-FFFFFFh 256KB Upper 4/256 0 0 0 1 0 Block 248 to 255 F80000h-FFFFFFh 512KB Upper 8/256 0 0 0 1 1 Block 240 to 255 F00000h-FFFFFFh 1024KB Upper 16/256 0 0 1 0 0 Block 224 to 255 E00000h-FFFFFFh 2048KB Upper 32/256 0 0 1 0 1 Block 192 to 255 C00000h-FFFFFFh 4096KB Upper 64/256 0 0 1 1 0 Block 128 to 255 800000h-FFFFFFh 8192KB Upper 128/256 0 0 1 1 1 Block 0 to 255 000000h-FFFFFFh 16384KB All 0 1 0 0 0 None None None None 0 1 0 0 1 Block 0 to 3 000000h-03FFFFh 256KB Lower 4/256 0 1 0 1 0 Block 0 to 7 000000h-07FFFFh 512KB Lower 8/256 0 1 0 1 1 Block 0 to 15 000000h-0FFFFFh 1024KB Lower 16/256 0 1 1 0 0 Block 0 to 31 000000h-1FFFFFh 2048KB Lower 32/256 0 1 1 0 1 Block 0 to 63 000000h-3FFFFFh 4096KB Lower 64/256 0 1 1 1 0 Block 0 to 127 000000h-7FFFFFh 8192KB Lower 128/256 0 1 1 1 1 Block 0 to 255 000000h-FFFFFFh 16384KB All 1 0 0 0 0 None None None None 1 0 0 0 1 Block 0 to 251 000000h-FBFFFFh 16128KB Lower 252/256 1 0 0 1 0 Block 0 to 247 000000h-F7FFFFh 15872KB Lower 248/256 1 0 0 1 1 Block 0 to 239 000000h-EFFFFFh 15360KB Lower 240/256 1 0 1 0 0 Block 0 to 223 000000h-DFFFFFh 14336KB Lower 224/256 1 0 1 0 1 Block 0 to 191 000000h-BFFFFFh 12288KB Lower 192/256 1 0 1 1 0 Block 0 to 127 000000h-7FFFFFh 8192KB Lower 128/256 1 0 1 1 1 Block 0 to 255 000000h-FFFFFFh 16384KB All 1 1 0 0 0 None None None None 1 1 0 0 1 Block 4 to 255 040000h-FFFFFFh 16128KB Upper 252/256 1 1 0 1 0 Block 8 to 255 080000h-FFFFFFh 15872KB Upper 248/256 1 1 0 1 1 Block 16 to 255 100000h-FFFFFFh 15360KB Upper 240/256 1 1 1 0 0 Block 32 to 255 200000h-FFFFFFh 14336KB Upper 224/256 1 1 1 0 1 Block 64 to 255 400000h-FFFFFFh 12288KB Upper 192/256 1 1 1 1 0 Block 128 to 255 800000h-FFFFFFh 8192KB Upper 128/256 1 1 1 1 1 Block 0 to 255 000000h-FFFFFFh 16384KB All This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 14 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Enable Boot Lock preliminary The Enable Boot Lock feature enables user to lock the 64KB-block/sector on the top/bottom of the device for protection. This feature is activated by configuring 4KBL/TB bits and programming EBL bit to ‘1’. The TB bit and 4KBL bits can only be programmed once. The bits’ definitions are described in the following table. Table 4. The Enable Boot Lock feature Type Non-volatile/ Volatile bit Register Description Function 0 (default) SR.6 Enable Boot lock SR.3 Top/Bottom Protect SR.4 4KB Boot Lock 1 : Lock selected 64KB-Block/Sector 0 : Top (default) 1 : Bottom OTP/Volatile bit This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 0 : 64KB-Block (default) 1 : Sector 15 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A INSTRUCTIONS preliminary All instructions, addresses and data are shifted in and out of the device, most significant bit first. Serial Data Input (DI) is sampled on the first rising edge of Serial Clock (CLK) after Chip Select (CS#) is driven Low. Then, the one-byte instruction code must be shifted in to the device, most significant bit first, on Serial Data Input (DI), each bit being latched on the rising edges of Serial Clock (CLK). The instruction set is listed in Table 5. Every instruction sequence starts with a one-byte instruction code. Depending on the instruction, it might be followed by address bytes, or data bytes, or both or none. Chip Select (CS#) must be driven High after the last bit of the instruction sequence has been shifted in. In the case of a Read Data Bytes (READ), Read Data Bytes at Higher Speed (Fast_Read), Dual Output Fast Read (3Bh), Dual I/O Fast Read (BBh), Quad Output Fast Read (6Bh), Quad Input/Output FAST_READ (EBh), Read Status Register (RDSR), Read Suspend Status Register (RDSSR) or Release from Deep Power-down, and Read Device ID (RDI) instruction, the shifted-in instruction sequence is followed by a data-out sequence. Chip Select (CS#) can be driven High after any bit of the data-out sequence is being shifted out. In the case of a write instruction, Chip Select (CS#) must be driven High exactly at a byte boundary, otherwise the instruction is rejected, and is not executed. That is, Chip Select (CS#) must driven High when the number of clock pulses after Chip Select (CS#) being driven Low is an exact multiple of eight. For Page Program, if at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. In the case of multi-byte commands of Page Program (PP), Quad Input Page Program (QPP), and Release from Deep Power Down (RES ) minimum number of bytes specified has to be given, without which, the command will be ignored. In the case of Page Program, if the number of byte after the command is less than 4 (at least 1 data byte), it will be ignored too. In the case of SE and HBE / BE, exact 24-bit address is a must, any less or more will cause the command to be ignored. All attempts to access the memory array during a Write Status Register cycle, Program cycle or Erase cycle are ignored, and the internal Write Status Register cycle, Program cycle or Erase cycle continues unaffected. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 16 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 5A. Instruction Set Instruction Name Byte 1 Code RSTEN RST(1) 66h EQPI 38h RSTQPI(2) Write Enable (WERN) Volatile Status Register Write Enable (3) FFh Write Disable (WRDI)/ Exit OTP mode Read Status Register (RDSR) Write Status Register (WRSR) Read Status Register 2 (RDSR2) Read Status Register 3 (RDSR3) Write Status Register 3 (WRSR3) Write Suspend preliminary Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 n-Bytes 99h 06h 50h 04h 05h (S7-S0)(4) 01h S7-S0 09h (S7-S0)(4) 95h (S7-S0)(4) C0h S7-S0 continuous(5) continuous(5) B0h Write Resume 30h Deep Power-down Release from Deep Power-down, and read Device ID (RES) Release from Deep Power-down (RDP) Manufacturer/ Device ID Read Identification (RDID) Enter OTP mode Read SFDP mode and Unique ID Number B9h (6) dummy dummy 90h dummy dummy 9Fh (M7-M0) (ID15ID8) A23-A16 A15-A8 dummy (ID7-ID0) 00h 01h (ID7-ID0) (M7-M0) (ID7-ID0) (8) (ID7-ID0) (M7-M0) A7-A0 dummy (D7-D0) ABh (7) 3Ah 5Ah (Next Byte) continuous Notes: 1. RST command only executed if RSTEN command is executed first. Any intervening command will disable Reset. 2. Release Full Quad SPI or Fast Read Enhanced mode. Device accepts eight-clocks command in Standard SPI mode, or twoclocks command in Full Quad SPI mode. 3. Volatile Status Register Write Enable command must precede WRSR command without any intervening commands to write data to Volatile Status Register. 4. Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “( )” indicate data being read from the device on the DO pin. 5. The Status Register contents will repeat continuously until CS# terminate the instruction. 6. The Device ID will repeat continuously until CS# terminates the instruction. 7. The Manufacturer ID and Device ID bytes will repeat continuously until CS# terminates the instruction. 00h on Byte 4 starts with MID and alternate with DID, 01h on Byte 4 starts with DID and alternate with MID. 8. (M7-M0) : Manufacturer, (ID15-ID8) : Memory Type, (ID7-ID0) : Memory Capacity. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 17 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 5B. Instruction Set (Read Instruction) Instruction Name preliminary Address bits OP Code Dummy bits / Clocks (Default) Data Out Read Data 03h 24 bits 0 (D7-D0, …) Fast Read 0Bh 24 bits 8 bits / 8 clocks (D7-D0, …) Dual Output Fast Read 3Bh 24 bits 8 bits / 8 clocks (D7-D0, …) Dual I/O Fast Read BBh 24 bits 8 bits / 4 clocks (D7-D0, …) Quad I/O Fast Read EBh 24 bits 24 bits / 6 clocks (D7-D0, …) Quad Output Fast Read 6Bh 24 bits 8 bits / 8 clocks (D7-D0, …) Remark (Next Byte) continuous (Next Byte) continuous (one byte Per 4 clocks, continuous) (one byte Per 4 clocks, continuous) (one byte per 2 clocks, continuous) (one byte per 2 clocks, continuous) Table 5C. Instruction Set (Program Instruction) Instruction Name Address bits OP Code Dummy bits Clocks (Default) Data In Page Program (PP) 02h 24 bits 0 (D7-D0, …) Quad Input Page Program (QPP) 32h 24 bits 0 (D7-D0, …) Remark (Next Byte) continuous (one byte per 2 clocks, continuous) Table 5D. Instruction Set (Erase Instruction) Instruction Name Address bits OP Code Dummy bits Clocks (Default) Data In Sector Erase (SE) 20h 24 bits 0 (D7-D0, …) 32K Half Block Erase (HBE) 52h 24 bits 0 (D7-D0, …) 64K Block Erase (BE) D8h 24 bits 0 (D7-D0, …) Chip Erase (CE) C7h/ 60h 24 bits 0 (D7-D0, …) Remark Table 5E. Instruction Set (Read Instruction support mode and apply dummy cycle setting) Instruction Name OP Code Start From SPI/QPI (1) Dummy Byte (2) SPI QPI Start From SPI Start From QPI Read Data 03h Yes No N/A N/A Fast Read 0Bh Yes Yes 8 clocks By SR3.4~5 Dual Output Fast Read 3Bh Yes No 8 clocks N/A Dual I/O Fast Read BBh Yes No 4 clocks N/A Quad Output Fast Read 6Bh Yes No 8 clocks N/A Quad I/O Fast Read EBh Yes Yes By SR3.4~5 Note: 1. ‘Start From SPI/QPI' means if this command is initiated from SPI or QPI mode. 2. The dummy byte settings please refer to table 9 This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 18 By SR3.4~5 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 6. Manufacturer and Device Identification OP Code (M7-M0) (ID15-ID0) ABh preliminary (ID7-ID0) 17h 90h 20h 9Fh 20h 17h 7018h Reset-Enable (RSTEN) (66h) and Reset (RST) (99h) The Reset operation is used as a system (software) reset that puts the device in normal operating Ready mode. This operation consists of two commands: Reset-Enable (RSTEN) and Reset (RST). To reset the XM25QH128A the host drives CS# low, sends the Reset-Enable command (66h), and drives CS# high. Next, the host drives CS# low again, sends the Reset command (99h), and drives CS# high. The Reset operation requires the Reset-Enable command followed by the Reset command. Any command other than the Reset command after the Reset-Enable command will disable the ResetEnable. A successful command execution will reset the status registers, see Figure 6 for SPI Mode and Figure 6.1 for Quad Mode. A device reset during an active Program or Erase operation aborts the operation, which can cause the data of the targeted address range to be corrupted or lost. Depending on the prior operation, the reset timing may vary. Recovery from a Write operation requires more software latency time ( tSR) than recovery from other operations. Figure 6. Reset-Enable and Reset Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 19 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 6.1 . Reset-Enable and Reset Sequence Diagram in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 20 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Software Reset Flow preliminary Initial No Command = 66h ? Yes Reset enable No Command = 99h ? Yes Reset start No WIP = 0 ? Embedded Reset Cycle Yes Reset done Note: 1. Reset-Enable (RSTEN) (66h) and Reset (RST) (99h) commands need to match standard SPI or EQPI (quad) mode. 2. Continue (Enhance) EB mode need to use quad Reset-Enable (RSTEN) (66h) and quad Reset (RST) (99h) commands. 3. If user is not sure it is in SPI or Quad mode, we suggest to execute sequence as follows: Quad Reset-Enable (RSTEN) (66h) -> Quad Reset (RST) (99h) -> SPI Reset-Enable (RSTEN) (66h) -> SPI Reset (RST) (99h) to reset. 4. The reset command could be executed during embedded program and erase process, QPI mode, Continue EB mode and suspend mode to back to SPI mode. 5. This flow can release the device from Deep power down mode. 6. The Status Register Bit and Suspend Status Register Bit will reset to default value after reset done. 7. If user reset device during erase, the embedded reset cycle software reset latency will take about 28us in worst case. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 21 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Enable Quad Peripheral Interface mode (EQPI) (38h) preliminary The Enable Quad Peripheral Interface mode (EQPI) instruction will enable the flash device for Quad SPI bus operation. Upon completion of the instruction, all instructions thereafter will be 4-bit multiplexed input/output until a power cycle or “ Reset Quad I/O instruction “ instruction, as shown in Figure 7. The device did not support the Read Data Bytes (READ) (03h), Dual Output Fast Read (3Bh) ,Dual Input/Output FAST_READ (BBh) and Quad output fast read (6Bh) modes while the Enable Quad Peripheral Interface mode (EQPI) (38h) turns on. Figure 7. Enable Quad Peripheral Interface mode Sequence Diagram Reset Quad I/O (RSTQIO) (FFh) The Reset Quad I/O instruction resets the device to 1-bit Standard SPI operation. To execute a Reset Quad I/O operation, the host drives CS# low, sends the Reset Quad I/O command cycle (FFh) then, drives CS# high. This command can’t be used in Standard SPI mode. User also can use the FFh command to release the Quad I/O Fast Read Enhancement Mode. The detail description, please see the Quad I/O Fast Read Enhancement Mode section. Note: If the system is in the Quad I/O Fast Read Enhance Mode in QPI Mode, it is necessary to execute FFh command by two times. The first FFh command is to release Quad I/O Fast Read Enhance Mode, and the second FFh command is to release EQPI Mode. Write Enable (WREN) (06h) The Write Enable (WREN) instruction (Figure 8) sets the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Quad Input Page Program (QPP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE) and Write Status Register (WRSR) instruction. The Write Enable (WREN) instruction is entered by driving Chip Select (CS#) Low, sending the instruction code, and then driving Chip Select (CS#) High. The instruction sequence is shown in Figure 10.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 22 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 8. Write Enable Instruction Sequence Diagram Volatile Status Register Write Enable (50h) This feature enable user to change memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Volatile Status Register Write Enable (50h) command won’t set the Write Enable Latch (WEL) bit, it is only valid for ‘Write Status Register’ (01h) command to change the Volatile Status Register bit values. To write to Volatile Status Register, issue the Volatile Status Register Write Enable (50h) command prior issuing WRSR (01h). The Status Register bits will be refresh to Volatile Status Register (SR[7:2]) within tSHSL2 (50ns). Upon power off or the execution of a Software/Hardware Reset, the volatile Status Register bit values will be lost, and the non-volatile Status Register bit values will be restored. The instruction sequence is shown in Figure 9. The instruction sequence is shown in Figure 10.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 9. Volatile Status Register Write Enable Instruction Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 23 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Write Disable (WRDI) (04h) preliminary The Write Disable instruction (Figure 10) resets the Write Enable Latch (WEL) bit in the Status Register to a 0 or exit from OTP mode to normal mode. The Write Disable instruction is entered by driving Chip Select (CS#) low, shifting the instruction code “04h” into the DI pin and then driving Chip Select (CS#) high. Note that the WEL bit is automatically reset after Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Half Block Erase (HBE), Block Erase (BE) and Chip Erase instructions. The instruction sequence is shown in Figure 10.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 10. Write Disable Instruction Sequence Diagram Figure 10.1 Write Enable/Disable Instruction Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 24 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Read Status Register (RDSR) (05h) The Read Status Register (RDSR) instruction allows the Status Register to be read. The Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new instruction to the device. It is also possible to read the Status Register continuously, as shown in Figure 11. The instruction sequence is shown in Figure 11.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 11. Read Status Register Instruction Sequence Diagram Figure 11.1 Read Status Register Instruction Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 25 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Table 7. Status Register Bit Locations SR.7 SRP bit OTP_LOCK bit SR.6 EBL bit (Enable boot lock) WXDIS bit SR.5 SR.4 SR.3 SR.2 BP3 bit BP2 bit BP1 bit BP0 bit HRSW bit 4KBL bit (4KB Boot Lock) TB bit (Top / Bottom Protect) SR.1 SR.0 WEL bit WIP bit Reserved Table 7.1 Status Register Bit Locations (In Normal mode) SR.7 SR.6 SR.5 SR.4 SR.3 SR.2 SR.1 SR.0 SRP Status Register Protect EBL bit (Enable Boot Lock) BP3 bit (Block Protect) BP2 bit (Block Protect) BP1 bit (Block Protect) BP0 bit (Block Protect) WEL bit (Write Enable Latch) WIP bit (Write In Progress bit) 1 = status register write disable 1 = Lock selected 64KBBlock/Sector (note 2) (note 2) (note 2) (note 2) 1 = write enable 0 = not write enable 1 = write operation 0 = not in write operation Non-volatile/ Volatile bit Non-volatile/ Volatile bit Non-volatile/ Volatile bit Non-volatile/ Volatile bit Non-volatile/ Volatile bit Non-volatile/ Volatile bit indicator bit indicator bit SR.1 SR.0 WEL bit (Write Enable Latch) WIP bit (Write In Progress bit) 1 = write enable 0 = not write enable 1 = write operation 0 = not in write operation indicator bit indicator bit Table 7.2 Status Register Bit Locations (In OTP mode) SR.7 SR.6 OTP_LOCK bit 1 = OTP sector is protected OTP bit SR.5 SR.4 SR.3 WXDIS bit HRSW bit (WP# and 4KBL bit (HOLD#/RESET# HOLD#/RESET# (4KB Boot Lock) switch) disabled) 1 = WP# and HOLD#/RESET# 1 = RESET# disable enable 1 = Sector 0 = WP# and 0 = HOLD# 0 = 64KB-Block HOLD#/RESET# enable (default 0) enable (default 0) (default 0) OTP / Volatile bit OTP / Volatile bit OTP / Volatile bit SR.2 TB bit (Top / Bottom Protect) 1 = Bottom 0 = Top (default 0) OTP / Volatile bit Reserved bit Note 1. In OTP mode, SR.7 bit is served as OTP_LOCK bit; SR.6 bit is served as WXDIS bit; SR.5 bit is served as HRSW bit; SR.4 bit is served as 4KBL bit; SR.3 bit is served as TB bit; SR.1 bit is served as WEL bit and SR.0 bit is served as WIP bit. 2. See the table 3 “Protected Area Sizes Sector Organization”. 3. When executed the (RDSR) (05h) command, the WIP (SR.0) value is the same as WIP (SR2.0) in table 8. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 26 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary The status and control bits of the Status Register are as follows: WIP bit. The Write In Progress (WIP) bit indicates whether the memory is busy with a Write Status Register, Program or Erase cycle. When set to 1, such a cycle is in progress, when reset to 0 no such cycle is in progress. WEL bit. The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write Status Register, Program or Erase instruction is accepted. BP3, BP2, BP1, BP0 bits. The Block Protect (BP3, BP2, BP1, BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase instructions. These bits are written with the Write Status Register (WRSR) instruction. When one or both of the Block Protect (BP3, BP2, BP1, BP0) bits is set to 1, the relevant memory area (as defined in Table 3.) becomes protected against Page Program (PP), Quad Input Page Program (QPP), Sector Erase (SE) and , Half Block Erase (HBE), Block Erase (BE), instructions. The Block Protect (BP3, BP2, BP1, BP0) bits can be written and provided that the Hardware Protected mode has not been set. The Chip Erase (CE) instruction is executed if and only if all Block Protect (BP3, BP2, BP1, BP0) bits are 0 and EBL bit is 0. EBL bit. The Enable Boot Lock (EBL) bit is used to enable the Boot Lock feature. When this bit is programmed to ‘1’, the sector/block selected by the TB bit and 4KBL bit will be locked. SRP bit. The Status Register Protect (SRP) bit is operated in conjunction with the Write Protect (WP#) signal. The Status Register Write Protect (SRP) bit and Write Protect (WP#) signal allow the device to be put in the Hardware Protected mode (when the Status Register Protect (SRP) bit is set to 1, and Write Protect (WP#) is driven Low). In this mode, the non-volatile bits of the Status Register (SRP, SR.5, SR.4, SR.3, SR.2) become read-only bits and the Write Status Register (WRSR) instruction is no longer accepted for execution. In OTP mode, SR.7, SR.6, SR.5, SR.4, SR.3, SR.1 and SR.0 are served as OTP_Lock bit, WXDIS bit, HRSW bit, 4KBL bit, TB bit, WEL bit and WIP bit. TB bit. The Top/Bottom Protect Bit (TB) controls if the Block Protect Bits (BP3, BP2, BP1, BP0) protect from the Top (TB = 0) or the Bottom (TB = 1) of the array as shown in the Status Register Memory Protection table. It also controls if the Top (TB=0) or the Bottom (TB=1) 64KB-block/sector is protected when Boot Lock feature is enabled. The factory default setting is TB = 0. The TB bit can be set with the Write Status Register instruction in OTP mode. 4KBL bit, The 4KB Boot Lock bit (4KBL) is set by WRSR command in OTP mode. It is used to set the protection area size as block (64KB) or sector (4KB). WXDIS bit. The WP# and HOLD#/RESET# Disable bit (WXDIS bit), OTP / Volatile bit, it indicates the WP# and HOLD#/RESET# are enabled or not. When it is “0” (factory default), the WP# and HOLD#/RESET# are enabled. On the other hand, while WXDIS bit is “1”, the WP# and HOLD#/RESET# are disabled. If the system executes Quad mode commands, this WXDIS bit becomes no affection since WP# and HOLD#/RESET# function will be disabled by Quad mode commands. HRSW bit. The HOLD#/RESET# switch bit (HRSW bit), OTP / Volatile bit, the HRSW bit is used to determine whether HOLD# or RESET# function should be implemented on the hardware pin. When it is “0” (factory default), the pin acts as HOLD#; when it is “1”, the pin acts as RESET#. However, HOLD# or RESET# functions are only available when WXDIS bit is “0”. If WXDIS bit is set to “1”, the HOLD# and RESET# functions are disabled, the pin acts as a dedicated data I/O pin. OTP_LOCK bit. This bit is served as OTP_LOCK bit, user can read/program/erase OTP sector as normal sector while OTP_LOCK value is equal 0, after OTP_LOCK is programmed with 1 by WRSR command, the OTP sector is protected from program and erase operation. The OTP_LOCK bit can only be programmed once. Reserved bit. Status Register bit locations SR.2 in OTP mode is reserved for future use. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 27 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Read Status Register 2 (RDSR 2) (09h) The Read Status Register 2 (RDSR2) instruction allows the Status Register 2 to be read. The Status Register 2 may be read at any time, even while a Write Suspend or Write Resume cycle is in progress. When one of these bytes is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new instruction to the device. It is also possible to read the Read Status Register 2 continuously, as shown in Figure 12. The instruction sequence is shown in Figure 12.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 12. Read Status Register 2 Instruction Sequence Diagram Figure 12.1 Read Status Register 2 Instruction Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 28 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Table 8. Status Register 2 Bit Locations SR2.7 Reserved bit SR2.6 SR2.5 Erase Fail Flag Program Fail Flag 1 = indicate Erase failed 0 = normal Erase succeed (default = 0) volatile bit Read Only 1 = indicate Program failed 0 = normal Program succeed (default = 0) volatile bit Read Only SR2.4 SR2.3 SR2.2 SR2.1 WIP (Write In Progress bit) (Note 1) WSP WSE (Write Suspend (Write Suspend Program bits) Erase status bit) Reserved bit 1 = Program 1 = Erase suspended suspended 0 = Program is 0 = Erase is not not suspended suspended volatile bit Read Only volatile bit Read Only SR2.0 Reserved bit 1 = write operation 0 = not in write operation volatile bit Read Only Note: 1. The default of each volatile bit is “0” at Power-up or after reset. 2. When executed the (RDSR 2) (09h) command, the WIP (SR2.0) value is the same as WIP (SR.0) in table 7. The status and control bits of the Suspend Status Register 2 are as follows: WIP bit. The Write In Progress (WIP) bit indicates whether the memory is busy with a Write Status Register, Program or Erase cycle. WSE bit. The Write Suspend Erase Status (WSE) bit indicates when an Erase operation has been suspended. The WSE bit is “1” after the host issues a suspend command during an Erase operation. Once the suspended Erase resumes, the WSE bit is reset to “0”. WSP bit. The Write Suspend Program Status (WSP) bit indicates when a Program operation has been suspended. The WSP is “1” after the host issues a suspend command during the Program operation. Once the suspended Program resumes, the WSP bit is reset to “0”. Reserved bit. Status Register 3 bit locations SR2.1、SR2.4 and SR2.7 are reserved for future use. Current devices will read 0 for these bit locations. It is recommended to mask out the reserved bit when testing the Suspend Status Register. Doing this will ensure compatibility with future devices. Program Fail Flag bit. While a program failure happened, the Program Fail Flag bit would be set. This bit will also be set when the user attempts to program a protected main memory region or a locked OTP region. This bit can indicate whether one or more of program operations fail, and can be reset by Program (PP), Quad Input Page Program (QPP) or Erase (SE, HBE/BE or CE) instructions. Erase Fail Flag bit. While an erase failure happened, the Erase Fail Flag bit would be set. This bit will also be set when the user attempts to erase a protected main memory region or a locked OTP region. This bit can indicate whether one or more of erase operations fail, and can be reset by Program (PP), Quad Input Page Program (QPP) or Erase (SE, HBE/BE or CE) instructions. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 29 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Read Status Register 3 (RDSR 3) (95h) The Read Status Register 3 (RDSR3) instruction allows the Status Register 3 to be read. The Status Register 3 may be read at any time, even while a Write Suspend or Write Resume cycle is in progress. When one of these bytes is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new instruction to the device. It is also possible to read the Read Status Register 3 continuously, as shown in Figure 13. The instruction sequence is shown in Figure 13.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 13. Read Status Register 3 Instruction Sequence Diagram Figure 13.1 Read Status Register 3 Instruction Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 30 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary The status and control bits of the Status Register 3 are as follows: Output Drive Strength. The Output Drive Strength (SR3.3 and SR3.2) bits indicate the status of output Drive Strength in I/O pins. Dummy Byte. The Dummy Byte (SR3.5 and SR3.4) bits indicate the status of the number of dummy byte in high performance read. Reserved bit. SR3.7, SR3.6, SR3.1 and SR3.0 are reserved for future use. Table 9. Status Register 3 Bit Locations SR3.7 SR3.6 SR3.5 SR3.4 Dummy Byte Default = 00 volatile bit volatile bit SR3.2 SR3.1 SR3.0 Output Drive Strength 00 = 3 Bytes 01 = 2 Bytes 10 = 4 Bytes 11 = 5 Bytes Reserved Reserved volatile bit SR3.3 (1) 00 = Full Drive (default) Reserved 01 = 67% (2/3) Drive 10 = 50% (1/2) Drive 11 = 33% (1/3) Drive volatile bit volatile bit volatile bit volatile bit Reserved volatile bit Note: 1. 2 Bytes (4 clocks in Quad mode), 3 Bytes (6 clocks in Quad mode), 4 Bytes (8 clocks in Quad mode), 5 Bytes (10 clocks in Quad mode) Table 10. SR3.4 and SR3.5 Status (for Dummy Bytes) Instruction Name Op Code Fast Read 0Bh Quad IO Fast Read EBh Dummy Byte settings sending Quad Output Fast Read (6Bh) instruction -> 24-bit address on DQ0 -> 8 dummy clocks -> data out interleave on DQ3, DQ2, DQ1 and DQ0 -> to end Quad Output Fast Read (6Bh) operation can use CS# to high at any time during data out, as shown in Figure 19. The WP#(DQ2) and HOLD#/RESET#(DQ3) need to drive high before address input if WXDIS bit in Status Register is 0. CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 CLK Command DQ0 3 Address bytes (24 clocks) 6Bh A23 A21 A3 A2 A1 A0 * High Impedance DQ1 A22 High Impedance DQ2 High Impedance DQ3 * = MSB CS# 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 CLK DQ0 switches from Input to Output Dummy Byte DQ0 DQ1 High Impedance A0 D4 D0 D4 D0 D4 D0 D4 D0 D4 D0 D4 D5 D1 D5 D1 D5 D1 D5 D1 D5 D1 D5 D6 D2 D6 D2 D6 D2 D6 D2 D6 D2 D6 D7 D3 D7 D3 D7 D3 D7 D3 D7 D3 D7 High Impedance High Impedance DQ2 High Impedance DQ3 Data Byte 1 Data Byte 2 Data Byte 3 Data Byte 4 Data Byte 5 Figure 19. Quad Output Fast Read Instruction Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 37 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Quad Input / Output FAST_READ (EBh) preliminary The Quad Input/Output FAST_READ (EBh) instruction is similar to the Dual I/O Fast Read (BBh) instruction except that address and data bits are input and output through four pins, DQ0, DQ1, DQ2 and DQ3 and six dummy clocks are required prior to the data output. The Quad I/O dramatically reduces instruction overhead allowing faster random access for code execution (XIP) directly from the Quad SPI. The Quad Input/Output FAST_READ (EBh) instruction enable quad throughput of Serial Flash in read mode. The address is latching on rising edge of CLK, and data of every four bits (interleave on 4 I/O pins) shift out on the falling edge of CLK at a maximum frequency F R. The first address can be any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out at a single Quad Input/Output FAST_READ instruction. The address counter rolls over to 0 when the highest address has been reached. Once writing Quad Input/Output FAST_READ instruction, the following address/dummy/data out will perform as 4-bit instead of previous 1-bit. The sequence of issuing Quad Input/Output FAST_READ (EBh) instruction is: CS# goes low -> sending Quad Input/Output FAST_READ (EBh) instruction -> 24-bit address interleave on DQ3, DQ2, DQ1 and DQ0 -> 6 dummy clocks -> data out interleave on DQ3, DQ2, DQ1 and DQ0 -> to end Quad Input/Output FAST_READ (EBh) operation can use CS# to high at any time during data out, as shown in Figure 20. The instruction sequence is shown in Figure 20.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 20. Quad Input / Output Fast Read Instruction Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 38 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 20.1. Quad Input / Output Fast Read Instruction Sequence in QPI Mode Another sequence of issuing Quad Input/Output FAST_READ (EBh) instruction especially useful in random access is : CS# goes low -> sending Quad Input/Output FAST_READ (EBh) instruction -> 24-bit address interleave on DQ3, DQ2, DQ1 and DQ0 -> performance enhance toggling bit P[7:0] -> 4 dummy clocks -> data out interleave on DQ3, DQ2, DQ1 and DQ0 till CS# goes high -> CS# goes low (reduce Quad Input/Output FAST_READ (EBh) instruction) -> 24-bit random access address, as shown in Figure 21. In the performance – enhancing mode, P[7:4] must be toggling with P[3:0] ; likewise P[7:0] = A5h, 5Ah, F0h or 0Fh can make this mode continue and reduce the next Quad Input/Output FAST_READ (EBh) instruction. Once P[7:4] is no longer toggling with P[3:0] ; likewise P[7:0] = FFh, 00h, AAh or 55h. These commands will reset the performance enhance mode. And afterwards CS# is raised or issuing FFh command (CS# goes high -> CS# goes low -> sending FFh -> CS# goes high) instead of no toggling, the system then will escape from performance enhance mode and return to normal operation. While Program/ Erase/ Write Status Register is in progress, Quad Input/Output FAST_READ (EBh) instruction is rejected without impact on the Program/ Erase/ Write Status Register current cycle. The instruction sequence is shown in Figure 21.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 39 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 21. Quad Input/Output Fast Read Enhance Performance Mode Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 40 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 21.1 Quad Input/Output Fast Read Enhance Performance Mode Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 41 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Write Status Register 3 (C0h) The Write Status Register 3 (C0h) command can be used to set output drive strength in I/O pins and the number of dummy byte in high performance read. To set the output drive strength and the number of dummy byte to the host driver CS# low, sends the Write Status Register 3 (C0h) and one data byte, then drivers CS# high, After power-up or reset, the output drive strength is set to full drive (00b) and the dummy byte is set to 3 bytes (00b), please refer to Table 9 for Status Register 3 data and Figure 22 for the sequence. In QPI mode, a cycle is two nibbles, or two clocks, long, most significant nibble first. The instruction sequence is shown in Figure 22.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 CLK Command DI 1 data byte C0h D7 D6 D5 D4 D3 D2 D1 D0 * High Impedance DO * = MSB Figure 22. Write Status Register 3 Instruction Sequence Diagram Figure 22.1 Write Status Register 3 Instruction Sequence Diagram in QPI mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 42 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Page Program (PP) (02h) The Page Program (PP) instruction allows bytes to be programmed in the memory. Before it can be accepted, a Write Enable (WREN) instruction must previously have been executed. After the Write Enable (WREN) instruction has been decoded, the device sets the Write Enable Latch (WEL). The Page Program (PP) instruction is entered by driving Chip Select (CS#) Low, followed by the instruction code, three address bytes and at least one data byte on Serial Data Input (DI). If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). Chip Select (CS#) must be driven Low for the entire duration of the sequence. The instruction sequence is shown in Figure 23. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 Data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. Chip Select (CS#) must be driven High after the eighth bit of the last data byte has been latched in, otherwise the Page Program (PP) instruction is not executed. As soon as Chip Select (CS#) is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) instruction applied to a page which is protected by the Block Protect (BP3, BP2, BP1, BP0) bits (see Table 3) is not executed. The instruction sequence is shown in Figure 23.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 23. Page Program Instruction Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 43 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 23.1 Program Instruction Sequence in QPI Mode Quad Input Page Program (QPP) (32h) The Quad Page Program (QPP) instruction allows up to 256 bytes of data to be programmed at previously erased (FFh) memory locations using four pins: DQ0, DQ1, DQ2 and DQ3. The Quad Page Program can improve performance for PROM Programmer and applications that have slow clock speeds < 5MHz. Systems with faster clock speed will not realize much benefit for the Quad Page Program instruction since the inherent page program time is much greater than the time it take to clockin the data. To use Quad Page Program (QPP) the WP# and HOLD#/RESET# Disable (WXDIS) bit in Status Register must be set to 1. A Write Enable instruction must be executed before the device will accept the Quad Page Program (QPP) instruction (SR.1, WEL=1). The instruction is initiated by driving the CS# pin low then shifting the instruction code “32h” followed by a 24-bit address (A23-A0) and at least one data byte, into the IO pins. The CS# pin must be held low for the entire length of the instruction while data is being sent to the device. All other functions of Quad Page Program (QPP) are identical to standard Page Program. The Quad Page Program (QPP) instruction sequence is shown in Figure 24. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 44 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 CLK Command DQ0 32h 3 Address bytes (24 clocks) A23 A22 A21 A3 A2 A1 A0 * DQ1 DQ2 DQ3 * = MSB CS# 31 32 33 34 35 36 37 534 535 536 537 538 539 540 541 542 543 CLK Data Byte 1 DQ0 A0 Data Byte 2 Data Byte 3 Data Byte 252 Data Byte 253 Data Byte 254 Data Byte 255 Data Byte 256 D4 D0 D4 D0 D4 D0 D4 D0 D4 D0 D4 D0 D4 D0 D4 D0 DQ1 D5 D1 D5 D1 D5 D1 D5 D1 D5 D1 D5 D1 D5 D1 D5 D1 DQ2 D6 D2 D6 D2 D6 D2 D6 D2 D6 D2 D6 D2 D6 D2 D6 D2 DQ3 D7 D3 D7 D3 D7 D3 D7 D3 D7 D3 D7 D3 D7 D3 D7 D3 * * * * * * * * Figure 24. Quad Input Page Program Instruction Sequence Diagram (SPI Mode only) This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 45 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Write Suspend (B0h) preliminary Write Suspend allows the interruption of Sector Erase, Block Erase or Page Program operations in order to erase, program, or read data in another portion of memory. The original operation can be continued with Write Resume command. The instruction sequence is shown in Figure 25. Only one write operation can be suspended at a time; if an operation is already suspended, the device will ignore the Write Suspend command. Write Suspend during Chip Erase is ignored; Chip Erase is not a valid command while a write is suspended. Suspend to suspend ready timing: 20us. Resume to another suspend timing: 1ms. Figure 25. Write Suspend Instruction Sequence Diagram Write Suspend During Sector Erase or Block Erase Issuing a Write Suspend instruction during Sector Erase or Block Erase allows the host to program or read any sector that was not being erased. The device will ignore any programming commands pointing to the suspended sector(s). Any attempt to read from the suspended sector(s) will out put unknown data because the Sector or Block Erase will be incomplete. To execute a Write Suspend operation, the host drives CS# low, sends the Write Suspend command cycle (B0h), then drives CS# high. A cycle is two nibbles long, most significant nibble first. The Suspend Status register indicates that the erase has been suspended by changing the WSE bit from “0” to “1”, but the device will not accept another command until it is ready. To determine when the device will accept a new command, poll the WIP bit in the Suspend Status register or after issue program suspend command, latency time 20us is needed before issue another command. For “Suspend to Read”, “Resume to Read”, “Resume to Suspend” timing specification please note Figure 26.1, 26.2 and 26.3. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 46 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Write Suspend During Page Programming preliminary Issuing a Write Suspend instruction during Page Programming allows the host to erase or read any sector that is not being programmed. Erase commands pointing to the suspended sector(s) will be ignored. Any attempt to read from the suspended page will output unknown data because the program will be incomplete. To execute a Write Suspend operation, the host drives CS# low, sends the Write Suspend command cycle (B0h), then drives CS# high. A cycle is two nibbles long, most significant nibble first. The Suspend Status register indicates that the programming has been suspended by changing the WSP bit from “0” to “1”, but the device will not accept another command until it is ready. To determine when the device will accept a new command, poll the WIP bit in the Suspend Status register or after issue program suspend command, latency time 20us is needed before issue another command. For “Suspend to Read”, “Resume to Read”, “Resume to Suspend” timing specification please note Figure 26.1, 26.2 and 26.3. Figure 26.1 Suspend to Read Latency Figure 26.2 Resume to Read Latency Figure 26.3 Resume to Suspend Latency The instruction sequence is shown in Figure 27.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Write Resume (30h) Write Resume restarts a Write command that was suspended, and changes the suspend status bit in the Suspend Status register (WSE or WSP) back to “0”. The instruction sequence is shown in Figure 27. To execute a Write Resume operation, the host drives CS# low, sends the Write Resume command cycle (30h), then drives CS# high. A cycle is two nibbles long, most significant nibble first. To determine if the internal, self-timed Write operation completed, poll the WIP bit in the Suspend Status register, or wait the specified time tSE, tHBE, tBE or tPP for Sector Erase, Block Erase, or Page Programming, respectively. The total write time before suspend and after resume will not exceed the uninterrupted write times tSE, tHBE, tBE or tPP. Resume to another suspend operation requires latency time of 1ms. The instruction sequence is shown in Figure 27.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 47 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 27. Write Resume Instruction Sequence Diagram Figure 27.1. Write Suspend/Resume Instruction Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 48 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 27.2. Write Suspend/Resume Flow Note: 1. The ‘WIP’ can be either checked by command ‘09’or ‘05’ polling. 2. ‘Wait for write cycle’ can be referring to maximum write cycle time or polling the WIP. 3. ‘Wait for suspend latency’, after issue program suspend command, latency time 20us is needed before issue another command or polling the WIP. 4. The ‘WSP’ and ‘WSE’ can be checked by command ‘09’ polling. 5. ‘Suspend done’ means the chip can do further operations allowed by suspend spec. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 49 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Sector Erase (SE) (20h) The Sector Erase (SE) instruction sets to 1 (FFh) all bits inside the chosen sector. Before it can be accepted, a Write Enable (WREN) instruction must previously have been executed. After the Write Enable (WREN) instruction has been decoded, the device sets the Write Enable Latch (WEL). The Sector Erase (SE) instruction is entered by driving Chip Select (CS#) Low, followed by the instruction code, and three address bytes on Serial Data Input (DI). Any address inside the Sector (see Table 2) is a valid address for the Sector Erase (SE) instruction. Chip Select (CS#) must be driven Low for the entire duration of the sequence. The instruction sequence is shown in Figure 28. Chip Select (CS#) must be driven High after the eighth bit of the last address byte has been latched in, otherwise the Sector Erase (SE) instruction is not executed. As soon as Chip Select (CS#) is driven High, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the selftimed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) instruction applied to a sector which is protected by the Block Protect (BP3, BP2, BP1, BP0) bits (see Table 3) or Boot Lock feature will be ignored. The instruction sequence is shown in Figure 30.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 28. Sector Erase Instruction Sequence Diagram 32KB Half Block Erase (HBE) (52h) The Half Block Erase (HBE) instruction sets to 1 (FFh) all bits inside the chosen block. Before it can be accepted, a Write Enable (WREN) instruction must previously have been executed. After the Write Enable (WREN) instruction has been decoded, the device sets the Write Enable Latch (WEL). The Half Block Erase (HBE) instruction is entered by driving Chip Select (CS#) Low, followed by the instruction code, and three address bytes on Serial Data Input (DI). Any address inside the Block (see Table 2) is a valid address for the Half Block Erase (HBE) instruction. Chip Select (CS#) must be driven Low for the entire duration of the sequence. The instruction sequence is shown in Figure 29. Chip Select (CS#) must be driven High after the eighth bit of the last address byte has been latched in, otherwise the Half Block Erase (HBE) instruction is not executed. As soon as Chip Select (CS#) is driven High, the self-timed Block Erase cycle (whose duration is tHBE) is initiated. While the Half Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Half Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Half Block Erase (HBE) instruction applied to a block which is protected by the Block Protect (BP3, BP2, BP1, BP0) bits (see Table 3) or Boot Lock feature will be ignored. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 50 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A The instruction sequence is shown in Figure 30.1 while using the Enable Quad Peripheral Interface preliminary mode (EQPI) (38h) command. Figure 29. 32KB Half Block Erase Instruction Sequence Diagram 64K Block Erase (BE) (D8h) The Block Erase (BE) instruction sets to 1 (FFh) all bits inside the chosen block. Before it can be accepted, a Write Enable (WREN) instruction must previously have been executed. After the Write Enable (WREN) instruction has been decoded, the device sets the Write Enable Latch (WEL). The Block Erase (BE) instruction is entered by driving Chip Select (CS#) Low, followed by the instruction code, and three address bytes on Serial Data Input (DI). Any address inside the Block (see Table 2) is a valid address for the Block Erase (BE) instruction. Chip Select (CS#) must be driven Low for the entire duration of the sequence. The instruction sequence is shown in Figure 30. Chip Select (CS#) must be driven High after the eighth bit of the last address byte has been latched in, otherwise the Block Erase (BE) instruction is not executed. As soon as Chip Select (CS#) is driven High, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the selftimed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Block Erase (BE) instruction applied to a block which is protected by the Block Protect (BP3, BP2, BP1, BP0) bits (see Table 3) or Boot Lock feature will be ignored. The instruction sequence is shown in Figure 30.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 51 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 30. 64K Block Erase Instruction Sequence Diagram Figure 30.1 Block/Sector Erase Instruction Sequence in QPI Mode Chip Erase (CE) (C7h/60h) The Chip Erase (CE) instruction sets all bits to 1 (FFh). Before it can be accepted, a Write Enable (WREN) instruction must previously have been executed. After the Write Enable (WREN) instruction has been decoded, the device sets the Write Enable Latch (WEL). The Chip Erase (CE) instruction is entered by driving Chip Select (CS#) Low, followed by the instruction code on Serial Data Input (DI). Chip Select (CS#) must be driven Low for the entire duration of the sequence. The instruction sequence is shown in Figure 31. Chip Select (CS#) must be driven High after the eighth bit of the instruction code has been latched in, otherwise the Chip Erase instruction is not executed. As This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 52 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A soon as Chip Select (CS#) is driven High, the self-timed Chip Erase cycle (whose duration is tCE) is preliminary initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) instruction is executed only if all Block Protect (BP3, BP2, BP1, BP0) bits are 0 and EBL bit is 0. The Chip Erase (CE) instruction is ignored if one or more blocks are protected. The instruction sequence is shown in Figure 31.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 31. Chip Erase Instruction Sequence Diagram Figure 31.1 Chip Erase Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 53 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Deep Power-down (DP) (B9h) preliminary Executing the Deep Power-down (DP) instruction is the only way to put the device in the lowest consumption mode (the Deep Power-down mode). It can also be used as an extra software protection mechanism, while the device is not in active use, since in this mode, the device ignores all Write, Program and Erase instructions. Driving Chip Select (CS#) High deselects the device, and puts the device in the Standby mode (if there is no internal cycle currently in progress). But this mode is not the Deep Power-down mode. The Deep Power-down mode can only be entered by executing the Deep Power-down (DP) instruction, to reduce the standby current (from ICC1 to ICC2, as specified in Table 17.) Once the device has entered the Deep Power-down mode, all instructions are ignored except the Release from Deep Power-down, Read Device ID (RDI) and Software Reset instruction which release the device from this mode. The Release from Deep Power-down and Read Device ID (RDI) instruction also allows the Device ID of the device to be output on Serial Data Output (DO). The Deep Power-down mode automatically stops at Power-down, and the device always Powers-up in the Standby mode. The Deep Power-down (DP) instruction is entered by driving Chip Select (CS#) Low, followed by the instruction code on Serial Data Input (DI). Chip Select (CS#) must be driven Low for the entire duration of the sequence. The instruction sequence is shown in Figure 32. Chip Select (CS#) must be driven High after the eighth bit of the instruction code has been latched in, otherwise the Deep Power-down (DP) instruction is not executed. As soon as Chip Select (CS#) is driven High, it requires a delay of tDP before the supply current is reduced to ICC2 and the Deep Power-down mode is entered. Any Deep Power-down (DP) instruction, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 32. Deep Power-down Instruction Sequence Diagram Release from Deep Power-down and Read Device ID (RDI) Once the device has entered the Deep Power-down mode, all instructions are ignored except the Release from Deep Power-down and Read Device ID (RDI) instruction. Executing this instruction takes the device out of the Deep Power-down mode. Please note that this is not the same as, or even a subset of, the JEDEC 16-bit Electronic Signature that is read by the Read Identifier (RDID) instruction. The old-style Electronic Signature is supported for reasons of backward compatibility, only, and should not be used for new designs. New designs should, instead, make use of the JEDEC 16-bit Electronic Signature, and the Read Identifier (RDID) instruction. When used only to release the device from the power-down state, the instruction is issued by driving the CS# pin low, shifting the instruction code “ABh” and driving CS# high as shown in Figure 33. After the time duration of tRES1 (See AC Characteristics) the device will resume normal operation and other instructions will be accepted. The CS# pin must remain high during the tRES1 time duration. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 54 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A When used only to obtain the Device ID while not in the power-down state, the instruction is initiated by preliminary driving the CS# pin low and shifting the instruction code “ABh” followed by 3-dummy bytes. The Device ID bits are then shifted out on the falling edge of CLK with most significant bit (MSB) first as shown in Figure 34. The Device ID value for the XM25QH128A are listed in Table 6. The Device ID can be read continuously. The instruction is completed by driving CS# high. When Chip Select (CS#) is driven High, the device is put in the Stand-by Power mode. If the device was not previously in the Deep Power-down mode, the transition to the Stand-by Power mode is immediate. If the device was previously in the Deep Power-down mode, though, the transition to the Standby Power mode is delayed by tRES2, and Chip Select (CS#) must remain High for at least tRES2 (max), as specified in Table 19. Once in the Stand-by Power mode, the device waits to be selected, so that it can receive, decode and execute instructions. Except while an Erase, Program or Write Status Register cycle is in progress, the Release from Deep Power-down and Read Device ID (RDI) instruction always provides access to the 8bit Device ID of the device, and can be applied even if the Deep Power-down mode has not been entered. Any Release from Deep Power-down and Read Device ID (RDI) instruction while an Erase, Program or Write Status Register cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. Figure 33. Release Power-down Instruction Sequence Diagram Figure 34. Release Power-down / Device ID Instruction Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 55 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Read Manufacturer / Device ID (90h) preliminary The Read Manufacturer/Device ID instruction is an alternative to the Release from Power-down / Device ID instruction that provides both the JEDEC assigned manufacturer ID and the specific device ID. The Read Manufacturer/Device ID instruction is very similar to the Release from Power-down / Device ID instruction. The instruction is initiated by driving the CS# pin low and shifting the instruction code “90h” followed by a 24-bit address (A23-A0) of 000000h. After which, the Manufacturer ID for XMC (20h) and the Device ID are shifted out on the falling edge of CLK with most significant bit (MSB) first as shown in Figure 35. The Device ID values for the XM25QH128A are listed in Table 6. If the 24-bit address is initially set to 000001h the Device ID will be read first The instruction sequence is shown in Figure 35.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. Figure 35. Read Manufacturer / Device ID Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 56 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 35.1. Read Manufacturer / Device ID Diagram in QPI Mode Read Identification (RDID) (9Fh) The Read Identification (RDID) instruction allows the 8-bit manufacturer identification to be read, followed by two bytes of device identification. The device identification indicates the memory type in the first byte , and the memory capacity of the device in the second byte . Any Read Identification (RDID) instruction while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) instruction should not be issued while the device is in Deep Power down mode. The device is first selected by driving Chip Select Low. Then, the 8-bit instruction code for the instruction is shifted in. This is followed by the 24-bit device identification, stored in the memory, being shifted out on Serial Data Output , each bit being shifted out during the falling edge of Serial Clock . The instruction sequence is shown in Figure 36. The Read Identification (RDID) instruction is terminated by driving Chip Select High at any time during data output. When Chip Select is driven High, the device is put in the Standby Power mode. Once in the Standby Power mode, the device waits to be selected, so that it can receive, decode and execute instructions. The instruction sequence is shown in Figure 36.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 57 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 36. Read Identification (RDID) This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 58 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 36.1. Read Identification (RDID) in QPI Mode Enter OTP Mode (3Ah) This Flash support OTP mode to enhance the data protection, user can use the Enter OTP mode (3Ah) command for entering this mode. In OTP mode, the Status Register S7 bit is served as OTP_LOCK bit, S6 bit is served as WXDIS bit, S5 bit is served as HRSW bit, S4 bit is served as 4KBL bit, S3 bit is served as TB bit, S1 bit is served as WEL bit and S0 bit is served as WIP bit. They can be read by RDSR command. This Flash has an extra 512 bytes OTP sector, user must issue ENTER OTP MODE command to read, program or erase OTP sector. After entering OTP mode, the OTP sector is mapping to sector 4095, SRP bit becomes OTP_LOCK bit. The Chip Erase, Block Erase and Half Block Erase commands are also disabled. In OTP mode, user can read other sectors, but program/erase other sectors only allowed when they are not protected by Block Protect (BP3, BP2, BP1, BP0) bits and Block Lock feature. The OTP sector can only be erased by Sector Erase (20h) command. The Chip Erase (C7h/ 60h), 64K Block Erase (D8h) and 32K Half Block Erase (52h) commands are disable in OTP mode. Table 11. OTP Sector Address Sector Sector Size Address Range 4095 512 byte FFF000h – FFF1FFh Note: The OTP sector is mapping to sector 4095 WRSR command is used to program OTP_LOCK bit, TB bit, 4KBL bit to ‘1‘, but these bits only can be programmed once. User can use WRDI (04h) command to exit OTP mode. The instruction sequence is shown in Figure 37.1 while using the Enable Quad Peripheral Interface mode (EQPI) (38h) command. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 59 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 37. Enter OTP Mode Figure 37.1 Enter OTP Mode Sequence in QPI Mode This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 60 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Read SFDP Mode and Unique ID Number (5Ah) preliminary Read SFDP Mode XM25QH128A features Serial Flash Discoverable Parameters (SFDP) mode. Host system can retrieve the operating characteristics, structure and vendor specified information such as identifying information, memory size, operating voltage and timing information of this device by SFDP mode. The device is first selected by driving Chip Select (CS#) Low. The instruction code for the Read SFDP Mode is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of Serial Clock (CLK). Then the memory contents, at that address, is shifted out on Serial Data Output (DO), each bit being shifted out, at a maximum frequency FR, during the falling edge of Serial Clock (CLK). The instruction sequence is shown in Figure 38. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The whole memory can, therefore, be read with a single Serial Flash Discoverable Parameters (SFDP) instruction. When the highest address is reached, the address counter rolls over to 0x00h, allowing the read sequence to be continued indefinitely. The Serial Flash Discoverable Parameters (SFDP) instruction is terminated by driving Chip Select (CS#) High. Chip Select (CS#) can be driven High at any time during data output. Any Read Data Bytes at Serial Flash Discoverable Parameters (SFDP) instruction, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 38. Read SFDP Mode Instruction Sequence Diagram This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 61 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 12. Serial Flash Discoverable Parameters (SFDP) Signature and Parameter Identification preliminary Data Value (Advanced Information) Description SFDP Signature SFDP Minor Revision Number SFDP Major Revision Number Number of Parameter Headers (NPH) Unused ID Number(JEDEC) Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length (in double word) Parameter Table Pointer (PTP) Unused ID number(Manufacturer ID) Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length(in double word) Parameter Table Pointer(PTP) Unused Add (h) (Byte) DW Add (Bit) Data 00h 01h 02h 03h 04h 05h 07 : 00 15 : 08 23 : 16 31 : 24 07 : 00 15 : 08 53h 46h 44h 50h 00h 01h 06h 23 : 16 01h 07h 31 : 24 FFh 08h 07 : 00 00h 09h 15 : 08 00h Star from 0x00 0Ah 23 : 16 01h Star from 0x01 0Bh 31 : 24 09h How many DWORDs in the parameter table 0Ch 0Dh 0Eh 0Fh 10h 07 : 00 15 : 08 23 : 16 31 : 24 07 : 00 30h 00h 00h FFh 20h 11h 15 : 08 00h Start from 00h 12h 23 : 16 01h Start from 01h 13h 31 : 24 04h How many DWORDs in the parameter table 14h 15h 16h 17h 07 : 00 15 : 08 23 : 16 31 : 24 60h 00h 00h FFh This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 62 Comment Fixed: 50444653h Star from 0x00 Star from 0x01 This number is 0-based.Therefore,0 indicates 1 parameter header. Reserved 00h:it indicates a JEDEC specified header. First address of JEDEC Flash Parameter table It indicates manufacture ID First address of VENDOR Flash Parameter table Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 1/9 Description Add (h) DW Add (Byte) (Bit) preliminary Data Comment 01 : 00 01b 00:Reserved, 01:4KB erase, 10:Reserved, 11:not supported 4KB erase 02 1b 03 0b 04 0b 07 : 05 15 : 08 111b 20h 16 1b 0 = not supported 1 = supported 18 : 17 00b 00:3Byte only, 01:3 or 4Byte 10:4Byte only, 11:Reserved 19 0b 0 = not supported 1 = supported (1-2-2) Fast Read 20 1b 0 = not supported 1 = supported (1-4-4) Fast Read 21 1b (1-1-4) Fast Read 22 1b 23 31 : 24 1b FFh Block / Sector Erase sizes Write Granularity Volatile Status Register Block Protect bits Write Enable Instruction Select for Writing to Volatile Status Registers Unused 4KB Erase Instruction (1-1-2) Fast Read 30h 31h (1) Address Bytes Number used in addressing flash array Double Transfer Rate(DTR) clocking 32h Unused Unused 33h 0:1Byte,1:64Byte or larger 0: Block Protect bits in device's status register are solely non-volatile or may be programmed either as volatile using the 50h instruction for write enable or nonvolatile using the 06h instruction for write enable. 1: Block Protect bits in device's status register are solely volatile. 0:use 50h instruction 1:use 06h instruction Contains 111b and can never be changed 0 = not supported 1 = supported 0 = not supported 1 = supported Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 2/9 Description Flash Memory Density Add (h) (Byte) 37h : 34h This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. DW Add (Bit) 31 : 00 63 Data Comment For densities 2 gigabits or less, bit-31 is set to 0b. The field 30:0 defines the size in bits. Example: 00FFFFFFh = 16 megabits For densities 4 gigabits and above, 07FFFFFFh bit-31 is set to 1b. The field 30:0 defines ‘N’ where the density is computed as 2^N bits (N must be >= 32). Example: 80000021h = 2^33 = 8 gigabits Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 3/9 Description (1-4-4)Fast Read number of Wait (2) states (1-4-4)Fast Read number of Mode (3) Clocks (1-4-4)Fast Read instruction (1-1-4)Fast Read Number of Wait states (1-1-4)Fast Read Number of Mode Clocks (1-1-4)Fast Read Instruction Add (h) DW Add (Byte) (Bit) Data 04 : 00 00100b 07 : 05 010b 15 : 08 EBh 20 : 16 01000b 23 : 21 000b 31 : 24 6Bh 38h 39h 3Ah 3Bh preliminary Comment 00000b:Not supported;00100b:4 00110b:6 01000b:8 Mode clocks: 000b:Not supported;010: 2 clocks 00000b:Not suppoted;00100b:4 00100b:6; 01000b:8 Mode clocks: 000b:Not supported;010b:2 clocks Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 4/9 Description Add (h) DW Add (Byte) (Bit) (1-1-2)Fast Read Number of Wait states (1-1-2)Fast Read Number of Mode Clocks 3Ch (1-1-2)Fast Read Instruction 3Dh (1-2-2)Fast Read Number of Wait states (1-2-2)Fast Read Number of Mode Clocks (1-2-2)Fast Read Instruction Data 04 : 00 01000b 00000b:Not supported;00100b:4 00110b:6;01000b:8 07 : 05 000b Mode clocks: 000b:Not supported;010:2 clocks 15 : 08 3Bh 20 : 16 00100b 00000b:Not supported;00100b:4 0 0110b:6;01000b:8 23 : 21 000b Mode clocks: 000b:Not supported;010:2 clocks 31 : 24 BBh 3Eh 3Fh Comment Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 5/9 Description Add (h) DW Add (Byte) (Bit) (2-2-2)Fast Read Unused 40h (4-4-4)Fast Read Unused Unused 43h : 41h Data 00 0b 03 : 01 111b 04 1b 07 : 05 31 : 08 111b FFFFFFh Comment 0 = not supported 1 = supported 0 = not supported 1 = supported Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 6/9 Description Unused (2-2-2)Fast Read Number of Wait states (2-2-2) Fast Read Number of Mode Clocks (2-2-2)Fast Read Instruction Add (h) DW Add (Byte) (Bit) 45h : 44h 15 : 00 Data FFh 20 : 16 00000b 00000b:Not supported;00100b:4 00110b:6;01000b:8 23 : 21 000b Mode Clocks: 000b:Not supported;010:2 clocks 31 : 24 FFh 46h 47h This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. Comment 64 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 7/9 Description Unused (4-4-4)Fast Read Number of Wait states (4-4-4) Fast Read Number of Mode Clocks (4-4-4)Fast Read Instruction Add (h) DW Add (Byte) (Bit) 49h : 48h 15 : 00 Data FFFFh 20 : 16 00100b 00000b:Not supported;00100b:4 00110b:6;01000b:8 23 : 21 010b Mode Clocks: 000b:Not supported;010:2 clocks 31 : 24 EBh 4Ah 4Bh Comment Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 8/9 Description Add (h) DW Add (Byte) (Bit) Data Comment N Erase Type 1 Size 4Ch 07 : 00 0Ch Erase Type 1 Erase Instruction 4Dh 15 : 08 20h Erase Type 2 Size 4Eh 23 : 16 0Fh Erase Type 2 Erase Instruction 4Fh 31 : 24 52h (4) Sector/block size=2 bytes 0Ch:4KB;0Fh:32KB;10h:64KB N Sector/block size=2 bytes 00h:NA;0Fh:32KB;10h:64KB Table 13. Parameter ID (0) JEDEC Flash Parameter Tables 9/9 Description Add (h) DW Add (Byte) (Bit) Data Comment N Sector/block size=2 bytes 00h:NA;0Fh:32KB;10h:64KB Erase Type 3 Size 50h 07 : 00 10h Erase Type 3 Erase Instruction 51h 15 : 08 D8h Erase Type 4 Size 52h 23 : 16 00h Sector/block size=2 bytes 00h:NA;0Fh:32KB;10h:64KB Erase Type 4 Erase Instruction 53h 31 : 24 FFh Not support N This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 65 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 14. Parameter ID (0) Flash Parameter Tables Add (h) DW Add Description (Byte) (Bit) 07:00 61h:60h Vcc supply maximum voltage 15:08 Vcc supply minimum voltage 00h 36h 23:16 00h 31:24 27h 63h:62h H/W Reset# pin 0 H/W Hold# pin 1 Deep Power Down Mode 2 S/W Reset 3 S/W Reset Instruction preliminary Data 65h:64h 11:04 Program suspend/resume 12 Erase suspend/resume 13 Unused 14 Wrap-Around Read mode 15 799Fh Wrap-Around Read mode instruction 66h 23:16 00h Wrap-Around Read data length 67h 31:24 00h 0 Individual block lock Individual block lock bit(Volatile/Nonvolatile) Individual block lock Instruction Individual block lock Volatile protect bit default protect status Secured OTP 1 2000h=2.000V 2700h=2.700V 3600h=3.600V 1650h=1.65V 1750h=1.75V 2250h=2.25V 2300h=2.3V 2350h=2.35V 2650h=2.65V 2700h=2.7V 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported Reset Enable(66h)should be issued before Reset instruction 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported Not support 08h:support 8B wrap-around read 16h:8B&16B 32h:8B&16B&32B 64h:8B&16B&32B&64B 0 = not supported 1 = supported 0:Volatile 1:Nonvolatile 09:02 10 6Bh:68h 12 Permanent Lock 13 6Fh:6Ch 0:Protect 1:Unprotect F800h 11 Read Lock Unused Unused Unused Comment 15:14 31:16 31:00 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported FFh FFh Note 1: (x-y-z) means I/O mode nomenclature used to indicate the number of active pins used for the instruction (x), address (y), and data (z). At the present time, the only valid Read SFDP instruction modes are: (1-1-1), (2-2-2),and (4-4-4) Note 2: Wait States is required dummy clock cycles after the address bits or optional mode clocks. Note 3: Mode clocks is optional control bits that follow the address bits. These bits are driven by the system controller if they are specified. (eg,read performance enhance toggling bits) Note 4: 4KB=2^0Ch,32KB=2^0Fh,64KB=2^10h Note 5: All unused and undefined area data is blank FFh. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 66 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Read Unique ID Number preliminary The Read Unique ID Number instruction accesses a factory-set read-only 96-bit number that is unique to each XM25QH128A device. The ID number can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID instruction is initiated by driving the CS# pin low and shifting the instruction code “5Ah” followed by a three bytes of addresses, 0x80h, and one byte of dummy clocks. After which, the 96-bit ID is shifted out on the falling edge of CLK as shown in Figure 38. Table 15. Unique ID Number Description Add (h) (Byte) DW Add (Bit) Data Unique ID Number 80h : 8Bh 95 : 00 By die This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 67 Comment Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Power-up Timing preliminary All functionalities and DC specifications are specified for a VCC ramp rate of greater than 1V per 100 ms (0V to 2.7V in less than 270 ms). See Table 16 and Figure 39 for more information. Figure 39. Power-up Timing Table 16. Power-Up Timing Symbol TPU-READ (1) TPU-WRITE (1) Parameter Min. Unit VCC Min to Read Operation 100 µs VCC Min to Write Operation 100 µs Note: 1. This parameter is measured only for initial qualification and after a design or process change that could affect this parameter. . INITIAL DELIVERY STATE The device is delivered with the memory array erased: all bits are set to 1 (each byte contains FFh). The Status Register contains 00h (all Status Register bits are 0). This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 68 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 17. DC Characteristics preliminary (Ta = - 40°C to 85°C; VCC = 2.7-3.6V) Symbol Parameter Test Conditions Min. Typ. Max. Unit ILI Input Leakage Current 1 ±2 µA ILO Output Leakage Current 1 ±2 µA ICC1 Standby Current CS# = VCC, VIN = VSS or VCC 20 µA ICC2 Deep Power-down Current CS# = VCC, VIN = VSS or VCC 20 µA 10 25 mA CLK = 0.1 VCC / 0.9 VCC at 104MHz, DQ = open ICC3 ICC4 ICC5 ICC6 ICC7 CLK = 0.1 VCC / 0.9 VCC at 33MHz, DQ = open CLK = 0.1 VCC / 0.9 VCC at 104MHz, Quad Output Read, DQ = open CLK = 0.1 VCC / 0.9 VCC at 33MHz, Quad Output Read, DQ = open 5 12 mA 14 35 mA 7 17 mA Operating Current (PP) Operating Current (WRSR) Operating Current (SE) CS# = VCC 9 30 mA 25 mA CS# = VCC 13 25 mA Operating Current (BE) CS# = VCC 15 Operating Current (READ) CS# = VCC VIL Input Low Voltage VIH Input High Voltage VOL Output Low Voltage IOL = 100 µA, Vcc=Vcc Min. VOH Output High Voltage IOH = –100 µA , Vcc=Vcc Min. 25 mA – 0.5 0.2 VCC V 0.7VCC VCC+0.4 V 0.3 V VCC-0.2 V Table 18. AC Measurement Conditions Symbol CL Parameter Min. Max. Load Capacitance 30 Input Rise and Fall Times Unit pF 5 ns Input Pulse Voltages 0.2VCC to 0.8VCC V Input Timing Reference Voltages 0.3VCC to 0.7VCC V VCC / 2 V Output Timing Reference Voltages Figure 40. AC Measurement I/O Waveform This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 69 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Table 19. AC Characteristics preliminary (Ta = - 40°C to 85°C; VCC = 2.7-3.6V) Symbol Alt Parameter Serial SPI Clock Frequency for: PP, QPP, SE, HBE, BE, CE, DP, RES, RDP, WREN, WRDI, WRSR, WRSR3, Fast Read Serial SPI Clock Frequency for: RDSR, RDSR2, RDSR3, RDID, Serial Dual/Quad Clock Frequency for: PP, QPP, SE, HBE, BE, CE, DP, RES, RDP, FR fC WREN, WRDI, WRSR, WRSR3, RDSR, RDSR2, RDSR3, RDID, Fast Read, Dual Output Fast Min Typ Max Unit D.C. 104 MHz D.C. 104 MHz D.C. 104 MHz D.C. 104 MHz Read, Dual I/O Fast Read D.C. 80 MHz fR Serial Clock Frequency for: Quad I/O Fast Read (3.0-3.6V) Serial Clock Frequency for: Quad I/O Fast Read (2.7-3.0V) Serial Clock Frequency for READ D.C. 50 4 MHz tCH 1 Serial Clock High Time 3.5 ns tCL1 Serial Clock Low Time 3.5 ns tCLCH2 tCHCL 2 Serial Clock Rise Time (Slew Rate) 0.1 V / ns Serial Clock Fall Time (Slew Rate) 0.1 V / ns tSLCH tCSS CS# Active Setup Time 5 ns tCHSH CS# Active Hold Time 5 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns tSHSL tCSH CS# High Time for read CS# High Time for program/erase 10 30 ns tSHSL2 tCSH Volatile Register Write Time 50 ns tSHQZ 2 tDIS Output Disable Time tCLQX tHO Output Hold Time 0 ns tDVCH tDSU Data In Setup Time 2 ns tCHDX tDH 6 ns Data In Hold Time 3 ns tHLCH HOLD# Low Setup Time ( relative to CLK ) 5 ns tHHCH HOLD# High Setup Time ( relative to CLK ) 5 ns tCHHH HOLD# Low Hold Time ( relative to CLK ) 5 ns HOLD# High Hold Time ( relative to CLK ) 5 ns tCHHL tCLQV tV tWHSL3 tSHWL tDP 3 2 Output Valid from CLK 7 ns Write Protect Setup Time before CS# Low 20 ns Write Protect Hold Time after CS# High 100 ns CS# High to Deep Power-down Mode 3 µs 3 µs 1.8 µs 50 ms tW CS# High to Standby Mode without Electronic Signature read CS# High to Standby Mode with Electronic Signature read Write Status Register Cycle Time tPP Page Programming Time 0.5 3 ms tSE Sector Erase Time 0.04 0.7 s tHBE Half Block Erase Time 0.2 1 s tBE Block Erase Time 0.3 2 s tCE Chip Erase Time 60 200 s tRES1 2 tRES2 2 This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 70 10 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A tHRST RESET# low period to reset the device 1 tHRSL RESET# high to next instruction 28 tSHRV Deselect to RESET# valid in quad mode 8 tSR Software Reset Latency µs preliminary µs ns WIP = write operation 28 µs WIP = not in write operation 0 µs Note: 1. tCH + tCL must be greater than or equal to 1/ fC 2. Value guaranteed by characterization, not 100% tested in production. 3. Only applicable as a constraint for a Write status Register instruction when Status Register Protect Bit is set at 1.4. 4. For speed inquire high than 50MHz, please call XMC for details. Figure 41. Serial Output Timing Figure 42. Input Timing This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 71 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 43. Hold Timing CS# CLK tSHRV RESET# tHRST tHRSL Figure 44. Reset Timing ABSOLUTE MAXIMUM RATINGS Stresses above the values so mentioned above may cause permanent damage to the device. These values are for a stress rating only and do not imply that the device should be operated at conditions up to or above these values. Exposure of the device to the maximum rating values for extended periods of time may adversely affect the device reliability. Parameter Value Storage Temperature -65 to +150 C Plastic Packages -65 to +125 C Output Short Circuit Current 1 Unit 200 mA Input and Output Voltage 2 (with respect to ground) -0.5 to Vcc+0.5 V Vcc -0.5 to Vcc+0.5 V This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 72 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Notes: 1. No more than one output shorted at a time. Duration of the short circuit should not be greater than one second. 2. Minimum DC voltage on input or I/O pins is –0.5 V. During voltage transitions, inputs may undershoot Vss to –1.0V for periods of up to 50ns and to –2.0 V for periods of up to 20ns. See figure below. Maximum DC voltage on output and I/O pins is Vcc + 0.5 V. During voltage transitions, outputs may overshoot to Vcc + 2.0 V for periods up to 20ns. See figure below. preliminary RECOMMENDED OPERATING RANGES 1 Parameter Value Ambient Operating Temperature Industrial Devices Unit C -40 to 85 Operating Supply Voltage Vcc Full: 2.7 to 3.6 V Notes: 1. Recommended Operating Ranges define those limits between which the functionality of the device is guaranteed. Vcc +1.5V V Maximum Negative Overshoot Waveform Maximum Positive Overshoot Waveform Table 20. CAPACITANCE ( VCC = 2.7-3.6V) Parameter Symbol Parameter Description Test Setup Max Unit CIN Input Capacitance VIN = 0 Typ 6 pF COUT Output Capacitance VOUT = 0 8 pF Note : Sampled only, not 100% tested, at TA = 25°C and a frequency of 20MHz. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 73 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary PACKAGE MECHANICAL Figure 45. SOP 208mil 8L SYMBOL DIMENSION IN MM NOR 1.975 0.15 1.825 5.275 7.90 5.275 1.27 0.425 0.65 MIN. MAX A 1.75 2.20 A1 0.05 0.25 A2 1.70 1.95 D 5.15 5.40 E 7.70 8.10 E1 5.15 5.40 e ----b 0.35 0.50 L 0.5 0.80 θ 00 40 80 Note : 1. Coplanarity: 0.1 mm 2. Max. allowable mold flash is 0.15 mm at the pkg ends, 0.25 mm between leads. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 74 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 46. WSON 5x6 8L DIMENSION IN MM MIN. NOR MAX A 0.70 0.75 0.80 A1 0.00 0.02 0.04 A2 --0.20 --D 5.90 6.00 6.10 E 4.90 5.00 5.10 D2 3.30 3.40 3.50 E2 3.90 4.00 4.10 e --1.27 --b 0.35 0.40 0.45 L 0.55 0.60 0.65 Note: 1. Coplanarity: 0.1 mm SYMBOL This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 75 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary Figure 47. 24-ball Thin Profile Fine-Pitch Ball Grid Array (6 x 8 mm) Package DIMENSION IN MM MIN. NOR A ----A1 0.27 --0.21 REF A2 0.54 REF A3 6 BSC D 8 BSC E D1 --3.00 E1 --5.00 e --1.00 b --0.40 Note : 1. Coplanarity: 0.1 mm SYMBOL MAX 1.20 0.37 --------- This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 76 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A preliminary ORDERING INFORMATION XM25QH128A H I G X - xx [1] SPECIAL OPTIONS xx = for UID, start from 01 to distinguish different UID request [1] SPECIAL OPTIONS T=Tape and Reel(packing method) R = Tray packing PACKAGING CONTENT G = RoHS, Halogen-Free and REACH compliant TEMPERATURE RANGE I = Industrial (-40°C to +85°C) PACKAGE H = SOP 208mil 8L W = WSON 5x6 8L B = TFBGA 6x8 24ball BASE PART NUMBER XM = Wuhan Xinxin Semiconductor Manufacturing. Corp. 25QH = 3V Serial Flash with 4KB Uniform-Sector 128 = 128 Megabit (16,384K x 8) A = version identifier Notes: 1、This option code is not included on the part marketing. This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 77 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06 XM25QH128A Revisions List preliminary Revision No Description Date A B C D E F Initial Release 2016/06/27 Add WSON(6x8mm) Package Change the max value of tSE (from 0.3s to 0.4s) 2017/01/03 Change Table 12-14(SFDP) 2017/09/28 Update ORDERING INFORMATION 2017/10/19 Update ORDERING INFORMATION; 1.Change the max value of tSE (from 0.4s to 0.7s) in Table 19. AC Characteristics 2.Delete PDIP, SOP16, WSON(6x8mm) Package type 3.Update the package name of SOP, WSON, TFBGA packages 1.Change normal read 83MHz to 50MHz in Page1 2. Add Parameter FR for Serial Clock Frequency for: Quad I/O Fast Read (3.03.6V), Max value 104MHz in Page70 3. Add Parameter FR for Serial Clock Frequency for: Quad I/O Fast Read (2.73.0V), max value 80MHz in Page70 4. Update the max value of fR from 83MHz to 50MHz in Page70 5. Add note4 for Table 19. AC Characteristics 2018/02/28 G H This Data Sheet may be revised by subsequent versions or modifications due to changes in technical specifications. 78 2017/05/03 2018/07/13 2018/08/06 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. H, Issue Date: 2018/08/06
XM25QH128AHIG 价格&库存
很抱歉,暂时无法提供与“XM25QH128AHIG”相匹配的价格&库存,您可以联系我们找货
