SOT-363 Plastic-Encapsulate Transistors
MMDT3906DW
SOT-363
DUAL TRANSISTOR (PNP+PNP)
FEATURES
·Epitaxial planar die construction
·Ideal for low power amplification and switching
MARKING:K3N
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
VCBO
Collector-Base Voltage
-40
V
VCEO
Collector-Emitter Voltage
-40
V
VEBO
-5
V
IC
Emitter-Base Voltage
Collector Current -Continuous
-0.2
A
PC
Collector Power Dissipation
0.2
W
RθJA
625
℃/W
TJ
Thermal Resistance. Junction to Ambient Air
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS(Ta=25℃unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=-10μA,IE=0
-40
Collector-emitter breakdown voltage
V(BR)CEO
IC=-1mA,IB=0
-40
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-10μA,IC=0
-5
V
V
Collector cut-off current
ICEX
VCE=-30V,VEB(OFF)=-3V
-50
nA
Base cut-off current
IEBO
VEB=-5V,IC=0
-50
nA
hFE(1)
VCE=-1V,IC=-0.1mA
60
hFE(2)
VCE=-1V,IC=-1mA
80
hFE(3)
VCE=-1V,IC=-10mA
100
hFE(4)
VCE=-1V,IC=-50mA
60
30
DC current gain
Collector-emitter saturation voltage
Base-emitter saturation voltage
Transition frequency
hFE(5)
VCE=-1V,IC=-100mA
VCE(sat)1
IC=-10mA,IB=-1mA
-0.25
V
VCE(sat)2
IC=-50mA,IB=-5mA
-0.4
V
VBE(sat)1
IC=-10mA,IB=-1mA
-0.85
V
VBE(sat)2
IC=-50mA,IB=-5mA
-0.95
V
fT
Collector output capacitance
Cob
Noise figure
NF
Delay time
td
Rise time
tr
Storage time
tS
Fall time
tf
Page 1 of 3
300
VCE=-20V,IC=-10mA,f=100MHz
-0.65
250
MHz
VCB=-5V,IE=0,f=1MHz
VCE=-5V,Ic=-0.1mA,f=1KHz,Rg=1KΩ
4.5
pF
4
dB
VCC=-3V, VBE=0.5V
IC=-10mA , IB1=-IB2=-1mA
35
nS
35
nS
VCC=-3V, IC=-10mA
IB1=-IB2=- 1mA
225
nS
75
nS
2/28/2013
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Page 2 of 3
2/28/2013
Page 3 of 3
2/28/2013
很抱歉,暂时无法提供与“MMDT3906DW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.09344
- 50+0.08643
- 200+0.08059
- 600+0.07475
- 1500+0.07008
- 3000+0.06716
- 国内价格
- 1+0.34650
- 200+0.11550
- 1500+0.07227
- 3000+0.05731
- 国内价格
- 20+0.17540
- 200+0.13922
- 600+0.11924
- 3000+0.10109
- 9000+0.09062
- 21000+0.08500
