DPX1608LL85R2455A
DPX1608LL85R2455A
    YAGEO(国巨)
    1608 = 1.6 × 0.8 mm 2.4/5GHz
DPX1608LL85R2455A 数据手册
DATA SHEET WIRELESS COMPONENTS Diplexer DPX1608LL85R2455A 2.4 AND 5 GHZ Product Specification – May 11, 2018 V.3 1608 Series Product specification WIRELESS COMPONENTS 2 5 Diplexer FEATURES  Compact size design  RoHS compliant ORDERING INFORMATION APPLICATIONS  WLAN, 802.11a/b/g/n  ISM Band PART NUMBER All part numbers are identified by the series, packing type, material, size, antenna type, working frequency and packing quantity. DPX 1608 LL 85 R 2455A (1) (2) (3) (4) (5) (6) (1) PRODUCT DPX = Diplexer (2) SIZE 1608 = 1.6 × 0.8 mm (3) MATERIALS Material Code LL (4) TYPE 85 = Type 85 (5) PACKING STYLE R = Tape and Reel (6) WORKING FREQUENCY 2455 = 2.4/5GHz PHYCOMP CTC CFL4111715852524K 12NC 411171585252 www.yageo.com May. 11, 2018 V.3 Product specification WIRELESS COMPONENTS 3 5 Diplexer SPECIFICATION Table 1 VALUE DESCRIPTION Low Band Pass Band High Band 2400~2500MHz 4900~6000MHz Insertion loss 0.7dB (Max) at 25°C 0.8dB (Max) at 25°C Return-Loss 10.0dB(Min) 12.0dB(Min) 28dB(Min).@860~960MHz 23dB(Min).@1545~1605MHz 23dB(Min).@1710~1990GHz 20dB(Min).@4.8~5GHz 20dB(Min).@7.2~7.5GHz Attenuation 28dB(Min).@2.17GHz 8dB(Min).@8.1GHz 15dB(Min).@8.82~9.8GHz 27dB(Min).@9.8~11.8GHz Isolation Middle Band to High Band: 20dB (Min). @4.9~5.95GHz Operating Temperature -40 ~ 85℃ Dimension 1.6 x 0.8 x0.6mm DIMENSIONS Table 2 Machinical Dimension OUTLINES DIMENSION L (mm) 1.60±0.15 W (mm) 0.80±0.15 T (mm) 0.60±0.15 P1 (mm) 0.20±0.15 P2 (mm) 0.20±0.15 P3 (mm) 0.20±0.15 P4 (mm) 0.20±0.15 P5 (mm) 0.20±0.15 P6 (mm) 0.20±0.15 D1 (mm) 0.20±0.15 D2 (mm) 0.30±0.10 D3 (mm) 0.15±0.10 Fig. 1 Filter outlines Table 3 Termination configuration TERMINAL NAME FUNCTION P1 High band port P2 Ground P3 Low band port P4 Ground P5 Common port P6 Ground www.yageo.com May. 11, 2018 V.3 Product specification WIRELESS COMPONENTS 4 5 Diplexer Fig. 2 Reference design of evaluation board ELECTRICAL PERFORMANCES     Measured on Agilent E5071C Network Analyzer Common port: Port 2 (Return loss S22) Low band port: Port 3 (Low band insertion loss S32, and attenuation at high band) High band port: Port 1 (High band insertion loss S12, and attenuation at low band) Fig. 3 Frequency Characteristics www.yageo.com May. 11, 2018 V.3 Product specification WIRELESS COMPONENTS Diplexer 5 5 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version 3 May 11, 2018 - Version 2 Aug. 18, 2014 - Version 1 Aug. 05, 2014 - DESCRIPTION - Update termination function - Update specification - Update Attenuation www.yageo.com May. 11, 2018 V.3
DPX1608LL85R2455A 价格&库存
很抱歉,暂时无法提供与“DPX1608LL85R2455A”相匹配的价格&库存,您可以联系我们找货
DPX1608LL85R2455A
  • 10+0.43060
  • 100+0.34614
  • 300+0.30392
  • 1000+0.27216
  • 4000+0.24689
  • 8000+0.23415
DPX1608LL85R2455A
  • 20+0.66630
  • 100+0.39740
  • 1000+0.27820
  • 4000+0.19870
  • 8000+0.18880
  • 40000+0.17490
DPX1608LL85R2455A
    库存:1724000
    DPX1608LL85R2455A
      • 4000+0.12650
      库存:1724000
