REV.
Mechanicals Dimensions
DESCRIPTION
DATE
DWN
AP’PD
ELECTRICAL SPECFICATIONS@25℃:
Turn Ratio(±5%):TX&RX=1CT:1CT
Inductance(100KHz/0.1V@8mA):350uH MIN
Insertion Loss (dB MAX):-1.0dB(0.3-100MHz)
Return Loss (dB MIN):
-18dB(1-30MHz), -16dB(40MHz), -12dB(50MHz), -10dB(60-80MHz)
Cross talk(dB MIN):
-40dB(30MHz), -35dB(60MHz), -30dB(100MHz)
CMR (dB MIN):
-30dB(30MHz), -20dB(60MHz), -20dB(100MHz)
HI-POT:1500Vrms/0.5mA/2Sec
Operating Temperature:-40℃ TO +85℃
RoHS compliance:YES
UNIT: mm Unless otherwise specified, all tolerances are ±0.25
Schematics
1000pF/2KV
J8
75Ω
P8
J7
P7
RD CT
CT
RD +
TD TD +
Ref:BOM-AE45
75Ω
P6
75Ω
P5
TX
P4
J3
P2
J2
P1
J1
9
RX +
TX TX +
Yellow
Green
LEFT
RX -
J4
75Ω
P3
J6
J5
10
RIGHT
11
RJ-45 Front View
PCB Top View
RX
元冊科技股份有限公司
YUAN DEAN SCIENTIFIC CO., LTD.
TITLE
10/100 BASE-T SINGLE PORT RJ-45 JACK
MAGNETICS
P/N
13F-64GYD2PLXNL
REV.
PAGE NO
1-2
DATE
2008-7-30
AP’PD
Li YueSheng
DWN
Chen JiaPei
12
REV.
Mechanicals
DESCRIPTION
DATE
DWN
AP’PD
Housing Material:
MATERIAL:NYLON GF (Fr50) UL94V-0
STANDARD COLOR:BLACK
Insert Material:
MATERIAL:Phos–Bronze C5210 EH---0.35mm Thickness
Insert –PBT GF UL94V-0
Packaging
1. packaging unit : 60 PCS/tray
2. packaging material :
PET
1.PLATING(1) NICKEL
17.5±0.5
2.PLATING(2) 100%Sn
3.PLATING(3) GOLD (3u"~50u")
Plate Material:
PBT GF UL 94V-0
29.4±0.5
Contact pin Material:
MATERIAL: Phos–Bronze C5210 EH---0.35mm Thickness
1.PLATING(1) NICKEL
2.3±0.2
Unit=cm
3. outer carton unit:1320 pcs/ 22 Trays/box
2.PLATING(2) 100%Sn
Shielding Material:
BRASS C2680 H.---0.25mm THICKNESS
PLATING NICKEL
Operating Life:750 Cycles MIN.
Environmental
Unit=cm
1.Storage Temp:-40℃TO +85℃.
2.Operating Temp:-40℃TO +85℃.
3.Wave Soldering Temperature:230~250℃(3~5 SECONDS)
元冊科技股份有限公司
4. MATES WITH MODULAR PLUG CONFORMING TO FCC PART 68,SUBPART F.
Part Number
TITLE
13F-64GYD2PLXNL
RoHS version
Gold Plating:1=3u",2=6u",3=15u",4=30u",5=50u",
MAGNETICS
P/N
13F-64GYD2PLXNL
REV.
PAGE NO
2-2
DATE
2008-7-30
AP’PD
Li YueSheng
DWN
Chen JiaPei
很抱歉,暂时无法提供与“13F-64GYD2PL2NL”相匹配的价格&库存,您可以联系我们找货
