US3M-SMB
US3M-SMB
    GOODWORK(固得沃克)
    SMB(DO-214AA)
    3.0安培表面贴装高效整流器VR=1KV IR=10μA SMB
US3M-SMB 数据手册
US3A US3M THRU 3.0 AMP SURFACE MOUNT HIGH EFFICIENCY RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 3.0 Ampere FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Fast switching speed DO-214AA(SMB) .155(3.94) .130(3.30) .083(2.11) .075(1.91) MECHANICAL DATA .185(4.70) .160(4.06) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.093 grams .012(0.31) .006(0.15) .096(2.44) .083(2.13) .008 MAX. (.203) .220(5.59) .200(5.08) .050(1.27) .030(0.76) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current US3A 50 35 50 US3B US3D US3E US3G US3J US3K US3M UNITS 100 200 300 400 600 800 1000 V 70 140 210 280 420 560 700 V 100 200 300 400 600 800 1000 V at Ta=55 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 3.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=100 C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Operating and Storage Temperature Range TJ, TSTG A 3.0 100 1.3 10 1.0 1.85 200 50 75 -65 75 +150 A V A A nS pF C NOTES: 1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (US3A THRU US3M) FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE FIG.1-TYPICAL FORWARD CHARACTERISTICS 8B 6B ~S M H 30 B~ SM H3 SM H 30 04 B~ S 01 1.0 SM H3 SM H3 .1 3.0 2.5 2.0 Single Phase 1.5 Half Wave 60Hz Resistive Or Inductive Load 1.0 0.375"(9.5mm) Lead Length 0.5 0 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE ( C) Tj=25 C Pulse Width 300us 1% Duty Cycle .01 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT .6 .8 1.0 1.2 1.4 1.6 1.8 FORWARD VOLTAGE,(V) FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTICS 50W NONINDUCTIVE 10W NONINDUCTIVE ( ) (+) D.U.T. 25Vdc (approx.) PULSE GENERATOR (NOTE 2) ( ) 150 PEAK FORWARD SURGE CURRENT,(A) .001 .4 (+) 1W NONINDUCTIVE 120 90 8.3ms Single Half Tj=25 C Sine Wave 60 JEDEC method 30 0 1 OSCILLISCOPE (NOTE 1) 5 50 10 100 NUMBER OF CYCLES AT 60Hz NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF. 2. Rise Time= 10ns max., Source Impedance= 50 ohms. FIG.5-TYPICAL JUNCTION CAPACITANCE 175 trr JUNCTION CAPACITANCE,(pF) INSTANTANEOUS FORWARD CURRENT,(A) MH 3 05 B 03 B AVERAGE FORWARD CURRENT,(A) 10 | | | | | | | | +0.5A 0 -0.25A -1.0A 150 125 100 75 50 25 1cm SET TIME BASE FOR 50 / 10ns / cm 0 .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) REV 1.0 2015 JAN PAGE:2/2
US3M-SMB
物料型号:US3A、US3B、US3D、US3E、US3G、US3J、US3K、US3M
器件简介:这是一系列3.0安培的表面安装高效率整流器,适用于50至1000伏特的电压范围。这些整流器适合表面安装应用,具有易挑选和放置的特点,并且具有快速开关速度。
引脚分配:无具体引脚分配信息,但提到了“0.375"(9.5mm) Lead Length”,可能指的是引脚长度。
参数特性:各型号整流器具有不同的最大重复峰值反向电压和最大直流阻断电压,如US3A为50V,US3M为1000V。部分型号具有最大平均正向整流电流3.0A,最高正向脉冲电流100A(US3B型号)。
功能详解:整流器具有内置的应变缓解和冶金结合构造,极性通过色带表示阴极端,并且可以以任何位置安装。
应用信息:适用于单相半波、60Hz、电阻性或感性负载。对于电容性负载,电流需要降低20%。
封装信息:封装类型为DO-214AA(SMB),外壳是模制塑料,环氧树脂符合UL 94V-0级阻燃标准。
US3M-SMB 价格&库存
很抱歉,暂时无法提供与“US3M-SMB”相匹配的价格&库存,您可以联系我们找货
US3M-SMB
  • 10+0.22860
  • 100+0.18705
  • 300+0.16396
  • 3000+0.13277
  • 6000+0.12076
  • 12000+0.11419
库存:7870
US3M-SMB
  • 1+0.22390
库存:10
US3M-SMB
  • 20+0.20954
  • 300+0.15029
  • 1200+0.14804
  • 3000+0.12170
库存:1595
