RS3MF
RS3MF
    JINGDAO(晶导微电子)
    SMAF(DO-214AD)
    快/超快恢复二极管 VRRM=1KV VRMS=700V IF=3A IFSM=80A VF=1.3V IR=5μA
RS3MF 数据手册
山东晶导微电子有限公司 RS3AF THRU RS3MF Jingdao Microelectronics Surface Mount Fast Recovery Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 3 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Fast reverse recovery time • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: RS3A-RS3M MECHANICAL DATA • Case: SMAF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 27mg / 0.00095oz Simplified outline SMAF and symbol Absolute Maximum Ratings and Characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols RS3AF RS3BF RS3DF RS3GF RS3JF RS3KF RS3MF Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 3 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 80 A Maximum Forward Voltage at 3 A VF 1.3 V IR 5 100 μA Cj 32 pF Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance at V R =4V, f=1MHz Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range t rr 250 150 500 ns RθJA RθJC 50 16 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2016.12 SMAF-F-RS3AF~RS3MF-3A1KV Page 1 of 3 山东晶导微电子有限公司 RS3AF THRU RS3MF Jingdao Microelectronics Fig.2 Typical Reverse Characteristics 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Maximum Average Forward Current Rating 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2016.12 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 RS3AF THRU RS3MF Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE g Top View mil Bottom View A C D E e g HE max 1.2 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 47 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm Marking 1.6 (63) 1.8 (71) 2.2 (86) mm Unit : (mil) 2016.12 ∠ 7° The recommended mounting pad size 1.6 (63) g pad e E A pad D E A V M JD612058B0 Type number Marking code RS3AF RS3A RS3BF RS3B RS3DF RS3D RS3GF RS3G RS3JF RS3J RS3KF RS3K RS3MF RS3M Page 3 of 3
RS3MF
物料型号为RS3AF至RS3MF,是山东晶导微电子有限公司生产的表面贴装型快速回复整流器。
器件简介包括低轮廓封装、玻璃钝化芯片结构、符合欧盟RoHS 2011/65/EU指令的无铅特性,以及具有快速反向恢复时间。
引脚分配为1脚阴极,2脚阳极。
参数特性包括最大重复峰值反向电压、最大RMS电压、最大直流阻断电压、最大平均正向整流电流、正向浪涌电流、最大正向电压、最大直流反向电流、典型结电容、最大反向恢复时间、典型热阻抗、工作和存储温度范围。
功能详解涉及器件的正向电流、反向电压、反向恢复时间、结电容等典型特性曲线。
应用信息为表面贴装应用。
封装信息为SMAF型塑料表面贴装包,2引脚,提供了封装的尺寸数据和推荐的焊盘尺寸。
RS3MF 价格&库存
很抱歉,暂时无法提供与“RS3MF”相匹配的价格&库存,您可以联系我们找货
RS3MF
    • 1+0.18030
    库存:10
    RS3MF
    • 20+0.45310
    • 100+0.27020
    • 800+0.18920
    • 3000+0.13510
    • 6000+0.12830
    • 30000+0.11890
    库存:15000
    RS3MF
    • 1+0.12100
    • 3000+0.09600
    库存:7732
    RS3MF
    • 20+0.23245
    • 300+0.18325
    • 1200+0.15593
    库存:582
