产品承认书
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N:
JXD P/N. :
G3601D
DESCRIPTION:
1000 BASE-T MAGNETICS MODULES
REF NO:
REV/NO:
A/0
DATE:
2014-9-15
■ SPECIFICATION
■ SAMPLE
Q’TY OF SAMPLES
PCS
CUSTOMER'S
SIGNATURE
REMARK
FULL APPROVED
CONDITIONAL
APPROVED
REJECTED
深圳磁联达电子有限公司
Shenzhen CND-TEK Industrial Co.,Ltd
公司地址: 深圳市南山区西丽镇阳光工业区5栋3楼
TEL: 86-755-29016433
FAX: 0755-27652977
Email: cd001@cd-tek.com
Http: //www.cd-tek.com
1. FEATURES:
1.1 Designed for long haul Gigabit Ethernet 1000 Base-T, full duplex applications.
1.2 Supports four pairs of category 5 UTP cable.
1.3 Cable interface for isolation and low common mode emissions
1.4 Compliant with IEEE 802.3ab standard for 1000 Base-T
1.5 Designed to support 1:1 Turns Ratio Transceivers.
1.6 Operating Temperature range: 0℃ TO +70℃
1.7 Storage temperature range: -25℃ TO +125℃
2. DIMENSIONS & MARKING
DRAWN BY: CHECKED BY: APPROVED BY: CUSTOMER:
PART NO. :G3601D
深圳磁联达电子有限公司
Shenzhen CD.com Industrial Co.,Ltd
REV.: A/0
PAGE: 2 OF 4
3. SCHEMATICS:
1
2
3
4
28
5
6
8
9
27
26
7
10
25
24
11
12
23
22
13
14
21
17
18
1CT:1CT
29
1CT:1CT
30
1CT:1CT
31
1CT:1CT
32
1CT:1CT
33
1CT:1CT
34
1CT:1CT
35
1CT:1CT
36
15
16
4.ELECTRICAL SPECIFICATIONS @25℃
4.1 OCL : 350 μH Min. @ 100 KHz, 100mV with 8mA DC Bias
4.2 Leakage Inductance: 0.5 μH Max. @ 100KHz, 0.2V
4.3 Cw/w: 100 pF Max. @ 100KHz, 0.2V
4.4 DCR: 1.20Ω Max.
4.5 Turns Ratio(±5%): 1CT:1(TX), 1CT:1(RX)
4.6 Polarity: 1-36, 3-34, 5-32, 7-30, 10-27, 12-25, 14-23, 16-21 In-Phase
4.7 Insertion Loss: -1.1 dB Max. (TX & RX)@ 1-100 MHz
4.8 Return Loss: -18 dB Min @ 0.5-30MHz
-15 dB Min @ 40 MHz
-13 dB Min @ 60 MHz
-11 dB Min @ 80 MHz
-10 dB Min.@ 100 MHz
4.9 Cross Talk: -45 dB Min.@ 30 MHz
-40 dB Min.@ 60 MHz
-35 dB Min.@ 100 MHz
4.10 Common Mode Rejection : -43 dB Min.@ 1-30 MHz
-37 dB Min.@ 60 MHz
-33 dB Min.@ 80-100 MHz
4.11 Isolation HI-POT: 1500Vrms 1mA 3Second
PART NO. :G3601D
REV.: A/0
深圳磁联达电子有限公司
PAGE: 3 OF 4
5. Recommended Lead Free Wave Soldering Curve :
Item
Soldertechnique
simulation
1
Solder iron
2
Vapor phase reflow
3
4
5
Wave:TopsideBoar
d-mount product
Wave:BottomsideB
oard-mount
product
Vapor phase reflow
Temperature
350±10
(solder irno temp)
215±5
(vapor temp)
260±5
(solder temp)
260±5
(solder temp)
215±5
(vapor temp)
Time(s)
Temperature ramp/immersion
and emersion rate
4~5
10±1
25mm/s±6mm/s
20±1
10±1
215±5
(vapor temp)
Preheat 1℃/s~4℃/s to within
100℃ of solder temp
25mm/s±6mm/s
6. Reliability Test Criteria:
6.1 Terminal strength: Pull test withstand 9.8N 60+/-0.5S no looseness or movement.
6.2 Solderbility: Dipped in 245℃+/-5℃ molten solder for 3+/-0.5 seconds,95% min shall be smooth any and bright.
6.3 Resistance to soldering heat : Dip in 260℃+/- 5℃ molten solder for 5+/- 0.5 seconds. Shall not be any
abnormality.
6.4 Vibration: 1.5mm amplitude total excursion 10-55-10 Hz traversed in 1minute, x.y.z, axis for 2 hours. Shall not be any abnormality.
6.5 Random drop (Packing condition): Height 60cm, 3 times on the wood floorboard ,shall not be any
abnormality.
6.6 Dry heat: 100+/-2℃ 96 hours.
6.7 Cold: -20+/-2℃ 96 hours.
6.8 Damp Heat: 60+/-2℃, 93+/-3% RH 96 hours.
6.9 Change of temperature: exposed 5 cycle; each consisting of 30 minutes at -20+/-2℃,2-3minutes at 20+/2℃,30 minutes at 85+/-2℃, 2-3 minutes at 20+/-2℃.
PART NO. :G3601D
REV.: A/0
深圳磁联达电子有限公司
PAGE: 4 OF 4
很抱歉,暂时无法提供与“G3601D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.16687
- 10+2.02046
- 30+1.99118
- 100+1.90333
- 国内价格
- 1+3.56724
- 10+2.85768
- 30+2.54664
- 105+2.16756
- 450+1.99260
- 1050+1.89540
