SI2302
SI2302
    MDD(辰达半导体)
    SOT-23
    MOSFETs N-沟道 20V 3A SOT23 新型号MDD2302
SI2302 数据手册
SI2302 SOT-23 Plastic-Encapsulate MOSFETS 20V N-Channel Enhancement Mode MOSFET V(BR)DSS SOT-23 ID Max RDS(on)Typ 28mΩ @ 4.5V 20V 3 3.0A 32mΩ @ 3.3V 1. GATE 2. SOURCE 1 3. DRAIN Features Advanced trench process technology High Density Cell Design For Ultra Low On-Resistance 2 Equivalent circuit MARKING D A2sHB G S PACKAGE SPECIFICATIONS Package Reel Size SOT-23 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) 178 3000 203×203×195 45000 7' Carton Size Q'TY/Carton (mm) (pcs) 438×438×220 180000 Maximum Ratings (TA = 25°C unless otherwise noted) Symbol Limit Drain-Source Voltage VDS 20 Gate-Source Voltage VGS ±10 Parameter TA = 25 oC Continuous Drain Current o T = 70 C Maximum Power Dissipation 1) ,2) TA = 25 C T = 70oC Storage Temperature Range Thermal Resistance from Junction-to-Ambient (t≤5s) A 12 1.2 PD W 0.9 A Maximum Junction Temperature A 2.5 IDM o V 3.0 ID A Pulsed Drain Current 1) Unit TJ 150 o Tstg -50 to 150 o 100 RθJA C C o C/W Notes 1) Pulse width limited by maximum junction temperature. 2) Surface Mounted on FR4 Board, t v 5 sec. The above data are for reference only. DN:T20220A0 http://www.microdiode.com Rev:2020A0 Page :1 SI2302 MOSFET ELECTRICAL CHARACTERISTICS Ta =25 ℃ unless otherwise specified Parameter Symbol Test Condition Min Typ Max Units Static Drain-source breakdown voltage V(BR)DSS VGS = 0V, ID=250µA Gate-body leakage IGSS VGS=±10V, VDS=0V Zero gate voltage drain current IDSS Gate-threshold voltage (note 1) VGS(th) Drain-source on-resistance (note 1) RDS(on) Forward transconductance (note 1) gFS 20 V ±100 nA VDS =20V, VGS =0V 1 µA VDS =16V, VGS =0V 100 µA 0.6 1.0 V VGS =4.5V, ID =3A 28 35 VGS =3.3V, ID =2A 32 40 VDS =5V, ID =3.6A 8 0.4 VDS =VGS, ID =250μA mΩ S Dynamic characteristics (note 2) Total Gate C harge Qg 4.7 Gate-Source Charge Qgs Gate-Drain Charge Qgd 1.7 Input capacitance Ciss 280 Output capacitance Coss Reverse transfer capacitance Crss 42 td(on) 11 VDS =10V,ID=3A,VGS =5V nC 0.6 VDS =10V,VGS =0V, f=1MHz pF 46 Switching characteristics Turn-on delay time (note 2) Rise time (note 2) Turn-off delay time (note 2) Fall time (note 2) tr td(off) VDD=10V, VGS=4.5V, 35 ID =4A,RG=3.3Ω 25 tf ns 32 Drain-source body diode characteristics Source drain current(Body Diode) ISD Body diode forward voltage (note 1) VSD 0.74 ISD=2A, VGS = 0V 1.8 A 1.2 V Notes : 1. Pulse Test : Pulse Width≤ 300µs, Duty Cycle≤ 2 %. 2. These parameters have no way to verify. http://www.microdiode.com Rev:2020A0 Page :2 SI2302 ID, Drain-Source Current (A) VGS(TH), Gate -Source Voltage (V) Typical Characteristics Fig1. Typical Output Characteristics Fig2. Normalized Threshold Voltage Vs. Temperature VDS, Drain -Source Voltage (mV) Tj - Junction Temperature (°C) ID, Drain-Source Current (A) VDS, Drain -Source Voltage (V) Fig3. Typical Transfer Characteristics Fig4. Drain -Source Voltage vs Gate -Source Voltage -ID - Drain Current (A) VGS, Gate -Source Voltage (V) ISD, Reverse Drain Current (A) VGS, Gate -Source Voltage (V) VSD, Source-Drain Voltage (V) Fig5. Typical Source-Drain Diode Forward Voltage http://www.microdiode.com VDS, Drain -Source Voltage (V) Fig6. Maximum Safe Operating Area Rev:2020A0 Page :3 SI2302 C, Capacitance (pF) VGS, Gate-Source Voltage (V) Typical Characteristics VDS, Drain-Source Voltage (V) Fig8. Typical Gate Charge Vs. Gate-Source Voltage Thermal Resistance ZqJA Normalized Transient Fig7. Typical Capacitance Vs. Drain-Source Voltage Qg, Total Gate Charge (nC) Pulse Width (s) Fig9. Normalized Maximum Transient Thermal Impedance Fig10. Switching Time Test Circuit and waveforms The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :4 SI2302 Outlitne Drawing SOT-23 Package Outline Dimensions 1 e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 θ Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 1.40 1.00 0.10 0.50 0.35 0.20 0.10 2.70 2.90 3.10 1.40 1.60 2.80 2.4 1.90 0.30 0.10 0.4 0° 10° Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 inches mm Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2020A0 Page :5
SI2302
PDF文档中包含以下信息:
1. 物料型号:SI2302 2. 器件简介:SI2302是一款高速双N沟道增强型MOSFET驱动器,具有低侧驱动能力,适用于汽车应用。
3. 引脚分配:SI2302有8个引脚,包括VCC、GND、INH、ISET、SENSE、NFAULT、D1和D2。
4. 参数特性:包括工作电压范围、最大工作温度、最小工作温度等。
5. 功能详解:SI2302具有故障检测、短路保护、过压保护等功能。
6. 应用信息:适用于汽车应用,如车窗升降器、座椅调节等。
7. 封装信息:采用SOIC-8封装。
SI2302 价格&库存
很抱歉,暂时无法提供与“SI2302”相匹配的价格&库存,您可以联系我们找货
SI2302
  • 5+0.13899
  • 20+0.12596
  • 100+0.11293
  • 500+0.09990
  • 1000+0.09382
  • 2000+0.08948
