AN_SY6288
Low Loss Power Distribution Switch
Preliminary Specification
General Description
Features
SY6288 is an ultra-low RDS(ON) switch with current
limiting function to protect the power source from over
current and short circuit conditions.
Ordering Information
SY6288□(□□)□
Temperature Code
Package Code
Optional Spec Code
Temperature Range: -40°C to 85°C
Ordering Number
SY6288AAAC
SY6288ACAC
SY6288AFAC
SY6288BAAC
SY6288BCAC
SY6288BFAC
SY6288CAAC
SY6288CCAC
SY6288CFAC
SY6288DAAC
SY6288DCAC
SY6288DFAC
SY6288D1AAC
SY6288D1CAC
SY6288D1FAC
SY6288EAAC
SY6288ECAC
SY6288EFAC
Package type
SOT23-5
MSOP8
SO8
SOT23-5
MSOP8
SO8
SOT23-5
MSOP8
SO8
SOT23-5
MSOP8
SO8
SOT23-5
MSOP8
SO8
SOT23-5
MSOP8
SO8
Note
0.6A/Active High
0.6A/Active High
0.6A/Active High
0.6A/Active Low
0.6A/Active Low
0.6A/Active Low
2A/Active High
2A/Active High
2A/Active High
2A/Active Low
2A/Active Low
2A/Active Low
1.5A/Active Low
1.5A/Active Low
1.5A/Active Low
2A/Active Low
2A/Active Low
2A/Active Low
Distribution voltages: 2.5V to 5.5V
Over temperature shutdown and automatic
retry
Reverse blocking (no body diode)
At shutdown, OUT can be forced higher than
IN
Fault flag (OCB) output for over current and
fault conditions
Automatic output discharge at shutdown
Built-in softstart
0.4ms rise time
RoHS Compliant and Halogen Free
Two Enable polarities and three current levels
o SY6288A: Active High/0.6A
o SY6288B: Active Low/0.6A
o SY6288C: Active High/2A
o SY6288D: Active Low/2A
o SY6288D1: Active Low/1.5A
o SY6288E: Active Low/2A
Compact packages minimize board space:
SOT23-5, SO8, MSOP8
Typical Application Circuit
Note: A low-ESR 150uF aluminum electrolytic or
tantalum between VOUT and GND is strongly
recommended.
AN_SY6288 Rev. 0.4
Silergy Corp. Confidential-prepared for Customer Use Only
1
AN_SY6288
Pin Configurations (Top View)
SOT23-5
MSOP8
SO8
Part Number
Package type
SY6288AAAC
SOT23-5
SY6288ACAC
MSOP8
SY6288AFAC
SO8
SY6288BAAC
SOT23-5
SY6288BCAC
MSOP8
SY6288BFAC
SO8
SY6288CAAC
SOT23-5
SY6288CCAC
MSOP8
SY6288CFAC
SO8
SY6288DAAC
SOT23-5
SY6288DCAC
MSOP8
SY6288DFAC
SO8
SY6288D1AAC
SOT23-5
SY6288D1CAC
MSOP8
SY6288D1FAC
SO8
SY6288EAAC
SOT23-5
SY6288ECAC
MSOP8
SY6288EFAC
SO8
Note① : x=year code, y=week code, z= lot number code.
Top Mark①
CWxyz
ABTxyz
AAJxyz
DBxyz
ABDxyz
AALxyz
DFxyz
ABUxyz
AAMxyz
BUxyz
ABExyz
AANxyz
DSxyz
ACKxyz
ACJxyz
COxyz
ABWxyz
ABVxyz
Functional Pin Description
Pin Number
(SO8, MSOP8)
2,3
1
6,7,8
Pin number
(SOT23-5)
5
2
1
EN- SY6288A/C
ENB- SY6288B/D/E
4
4
OCB
5
3
Pin Name
IN
GND
OUT
AN_SY6288 Rev. 0.4
Pin Description
Input pin
Ground pin
Output pin
ON/OFF control. Don’t float.
EN: high enable. ENB: low
enable.
Open Drain Fault Flag
2
AN_SY6288
Absolute Maximum Ratings (Note 1)
All pins-------------------------- -------------------------------------------------------------------------------- 6V
Power Dissipation, PD @ TA = 25°C SOT23-5/MSOP8/SO8--------------------------------------------- 0.4/0.5/0.65W
Package Thermal Resistance (Note 2)
SOT23-5/MSOP8/SO8, θ JA ------------------------------------------------------------------------ 250/150/90°C/W
SOT23-5/MSOP8/SO8, θ JC ------------------------------------------------------------------------ 130/ 65/ 45°C/W
Junction Temperature Range ---------------------------------------------------------------------------------- 150°C
Lead Temperature (Soldering, 10 sec.) -----------------------------------------------------------------------260°C
Storage Temperature Range ----------------------------------------------------------------------------------- -65°C to 150°C
ESD Susceptibility (Note 2)
HBM (Human Body Mode) ----------------------------------------------------------------------------------- 2kV
MM (Machine Mode) ------------------------------------------------------------------------------------------ 200V
Recommended Operating Conditions (Note 3)
IN----------------------------------------------------------------------------------------------------------------- 2.5V to 5.5V
EN/ENB--------------------------------------------------------------------------------------------------------- -0.3V to VIN+0.3V
All other pins --------------------------------------------------------------------------------------------------- 0-5.5V
Junction Temperature Range -------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range -------------------------------------------------------------------------------- -40°C to 85°C
AN_SY6288 Rev. 0.4
3
AN_SY6288
Electrical Characteristics
(VIN = 5V, CL=1uF, per channel, TA = 25°C unless otherwise specified)
Parameter
Input Voltage Range
Shutdown Input Current
Quiescent Supply Current
Symbol
VIN
ISHDN
IQ
Test Conditions
FET RON
RDS(ON)
Current Limit
ILIM
Logic-Low
Voltage
Logic-High
Voltage
IN UVLO Threshold
IN UVLO Hysteresis
Turn-ON Time
Turn-OFF Time
OCB Low Resistance
OCB Delay Time
OUT Shutdown Discharge
Resistance
Thermal
Shutdown
Temperature
Thermal Shutdown Hysteresis
VIL
RLOAD=ROPEN, switch off
RLOAD=ROPEN,switch on
SOT23-5(SY6288A/B/C/D/D1)
SOT23-5(SY6288E)
MSOP8 SY6288A/B/C/D/D1)
MSOP8 SY6288E)
SO8( SY6288A/B/C/D/D1)
SO8( SY6288E)
SY6288A/B
SY6288C/D
SY6288D1
SY6288E
VIN=2.5V to 5.5V
VIH
VIN=2.5V to 5.5V
EN/ EN
threshold
VIN,UVLO
VIN,HYS
TON
TOFF
Min
2.5
60
50
60
50
65
55
0.8
2.1
1.6
2.2
Typ
0.1
32
80
70
80
70
85
75
Max
5.5
1
100
90
100
90
105
95
1.6
3.7
3.7
3.7
0.8
2
Unit
V
µA
µA
mΩ
mΩ
mΩ
mΩ
mΩ
mΩ
A
A
A
A
V
V
2.4
ROCB
TOCB_Delay
10
10
V
V
µs
µs
Ω
ms
RDIS
10
Ω
TSD
150
°C
°C
RL=5ohm
0.1
400
200
Note 1: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device.
These are for stress ratings. Functional operation of the device at these or any other conditions beyond those
indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating
conditions for extended periods may remain possibility to affect device reliability.
Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity
test board of JEDEC 51-3 thermal measurement standard.
Note 3: The device is not guaranteed to function outside its operating conditions
AN_SY6288 Rev. 0.4
4
AN_SY6288
EN Pin Threshold Voltage (V)
Typical Operating Characteristics
Output Voltage vs. Output Current
Output Voltage (V)
6
5
4
3
2
1
SO-8, Vin=5V
1
1.5
2
2.5
3
Output Current (A)
AN_SY6288 Rev. 0.4
5
AN_SY6288
AN_SY6288 Rev. 0.4
6
AN_SY6288
Block diagram
AN_SY6288 Rev. 0.4
7
AN_SY6288
SOT23-5L Package Outline & PCB layout
0.55
1.50 - 1.70
0.80
2.70 - 3.00
2.40
2.80 - 3.10
0.95 TYP
0.30 - 0.50
0.01 - 0.1
0.1 - 0.15
0.25 REF
Recommended Pad Layout
1.0 - 1.3
0.95 TYP
0.3 - 0.6
1.90 TYP
Notes: All dimensions are in millimeters.
All dimensions don’t include mold flash & metal burr.
AN_SY6288 Rev. 0.4
8
AN_SY6288
5.40
3.80 - 4.00
1.27 TYP
5.80 - 6.20
6.10
1.55
SO8 Package outline & PCB layout design
0.30 – 0.50
0.60
0.60 - 0.85
0.08 - 0.25
1.40 - 1.60
-8
4.80 - 5.00
0.25 base
45°
0.25 - 0.50
0.18 - 0.25
1.27 (TYP)
AN_SY6288 Rev. 0.4
9
AN_SY6288
MSOP8 Package outline & PCB layout
4.70-5.10
5.30
2.85-3.10
1.35
0.65
0.45
0.40-0.80
0.25 base
0.10-0.25
0.75-0.95
2.85-3.10
0.00-0.15
0.65 (TYP)
AN_SY6288 Rev. 0.4
10
很抱歉,暂时无法提供与“SY6288CAAC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.04976
- 50+0.81821
- 150+0.70244
- 500+0.61560
- 3000+0.54616
- 6000+0.51138
- 国内价格
- 5+0.95256
- 50+0.74245
- 600+0.55860
- 1200+0.55022
- 3000+0.49559
- 国内价格
- 100+0.46762
- 500+0.45581
