ES1A
ES1J
THRU
1.0 AMP SURFACE MOUNT SUPER FAST RECTIFIERS
VOLTAGE RANGE
50 to 400 Volts
CURRENT
1.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Super fast recovery time for high speed switching
DO-214AC(SMA)
.110(2.79)
.100(2.54)
.058(1.47)
.052(1.32)
MECHANICAL DATA
.173(4.40)
.153(3.90)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.063 gram
.012(0.31)
.006(0.15)
.095(2.40)
.079(2.00)
.005
MAX.
(.127)
.205(5.20)
.189(4.80)
.060(1.52)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
ES1A
50
35
50
ES1B ES1C
100
70
100
150
105
150
at TL=110 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 1.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=100 C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Operating and Storage Temperature Range TJ, TSTG
ES1D
200
140
200
ES1E ES1G ES1J UNITS
300
210
300
400
280
400
600
420
600
A
1.0
30
1.25
0.95
V
V
V
1.7
A
V
5.0
500
35
nS
10
-65 +150
pF
C
NOTES:
1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (ES1A THRU ES1J)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
Tj=25 C
10
Pulse Width 300us
1% Duty Cycle
MU
1
1.2
1.0
0.8
Single Phase
0.6
Half Wave 60Hz
Resistive Or Inductive Load
0.4
0.2
5A
~S
60
SM
U1
1.0
6A
4A
3.0
SM
U1
1A
~S
MU
1
80
100
120
140
160
180
200
LEAD TEMPERATURE ( C)
0.1
.01
.4
.6
.8
1.0
1.2
1.4
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PULSE
GENERATOR
(NOTE 2)
PEAK FORWAARD SURGE CURRENT,(A)
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
50
40
30
Sine Wave
JEDEC method
10
5
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
-0.25A
100
FIG.5-TYPICAL JUNCTION CAPACITANCE
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
+0.5A
50
10
NUMBER OF CYCLES AT 60Hz
OSCILLISCOPE
(NOTE 1)
trr
8.3ms Single Half
Tj=25 C
1W
NONINDUCTIVE
35
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
50
30
25
10
5
-1.0A
1cm
SET TIME BASE FOR
.01
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
50 / 10ns / cm
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“ES1D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09581
- 50+0.04785
- 2000+0.03630
- 国内价格
- 50+0.07769
- 400+0.06349
- 800+0.06254
- 2000+0.04665
- 国内价格
- 50+0.08475
- 500+0.06926
- 2000+0.05089
- 4000+0.04576
- 24000+0.04125
- 48000+0.03879
