ME4055A
800mA Lithium Ion Battery Linear Charger ME4055A
General Description
Features
ME4055A is a complete constant-current/constant
voltage linear charger for single cell lithium-ion
batteries. Furthermore the ME4055A is specifically
designed to work within USB power specifications.
No external sense resistor is needed and no
●Protection of battery cell reverse connection
●No MOSFET sense resistor or blocking diode
required
●Complete Linear Charger in Thin SOT Package for
Single Cell Lithium-Ion Batteries
blocking diode is required due to the internal
●Constant- Current/Constant- Voltage operation with
PMOSFET architecture .Thermal feedback regulates
thermal regulation to maximize Rate Without risk
the charge current to limit the die temperature during
of overheating.
high
power
operation
or
high
ambient
● Preset 4.2V charge voltage with ±1% accuracy
temperature .The charge voltage is fixed at 4.2V,and
● Automatic Recharge
the charge current can be programmed externally with
●Charges Single Cell Li-Ion Batteries Directly from
a
single
resistor.
The
ME4055A
automatically
USB Port
terminates the charge cycle when the charge current
●C/10 charge termination
drops to 1/10th the programmed value after the final
● 55μA supply current in shutdown
float voltage is reached.
● 2.9V trickle current charge threshold
When the input supply (wall adapter or USB supply)
● Soft-Start limits inrush current
is removed the ME4055A automatically enters a low
●Charge Status Output Pin
current state dropping the battery drain current to less
●Available in SOT23-6 Package
than 2μA.The ME4055A can be put into shutdown
mode reducing the supply current to 55μA.
Other features include charge current monitor,
Applications
undervoltage lockout, automatic recharge and a
●Cellular Telephones, PDAs, MP3 Players
status.
●Charging Docks and Cradles
●Bluetooth Applications
V05
www.microne.com.cn
Page 1 of 17
ME4055A
Selection Guide
Typical charge cycle(750mAh batter
600mA Single Cell Li-Ion Charger
VIN
4.5V TO 6.5V
VCC
BAT 3
ME4055A
GND
1μF
2
PROG 5
600mA
4.2V
Li-Ion
1.65K
BATTERY
4.75
CONSTANT CURRENT
600
CONSTANT
500
POWER
CONSTANT 4.5
VOLTAGAE
4.25
400
4.0
300
VCC=5V
3.75
200
θ
3.5
100
RPROG=1.65K CHARGE
TA=25℃ TERMINATED
JA=130℃/W
3.25
0.25 0.5 0.75 1.0 1.25 1.5 1.75
3.0
2.0
TIME(HOURS)
Pin Configuration
CHRG 1
6 PROG
GND
2
5 STDBY
BAT
3
4 VCC
Package type:SOT23-6
V05
www.microne.com.cn
Page 2 of 17
BATTERY VOLTAGE(V)
4
CHARGE CURRENT(mA)
700
ME4055A
Pin Assignment
ME4055AM6G
Pin Num.
Symbol
Function
1
CHRG
Open-Drain charge status output
When the battery is being charged, the
pin is pulled low by an internal switch,
otherwise,
pin is in high impedance state.
2
GND
Ground
BAT
Battery connection Pin
Connect the positive terminal of the battery to this pin. Dropping BAT pin’s current to
less than 2μA when IC in disable mode or in sleep mode. BAT pin provides charge
current to the battery and provides regulation voltage of 4.2V.
VCC
Positive input supply voltage
Provides power to the internal circuit. When VCC drops to within 80mV of the BAT pin
voltage, the ME4055A enters low power sleep mode, dropping IBAT to less than 2μA.
3
4
5
6
STDBY
PROG
Charge terminated status output
STDBY is pulled low by an internal switch to indicate a battery charge terminated;
this means Charge termination. Otherwise STDBY pin is in high impedance state.
Constant Charge Current Setting and Charge Current Monitor Pin
The charge current is programmed by connecting a resistor RPROG from this pin to
GND. When in precharge mode, the PROG pin’s voltage is regulated to 0.1V. When
charging in constant-current mode this pin’s voltage is regulated to 1V. In all modes
during charging, the voltage on this pin can be used to measure the charge current
using the following formula:
V05
IBAT =
www.microne.com.cn
VPROG
*1100
RPROG
Page 3 of 17
ME4055A
Block Diagram
V05
www.microne.com.cn
Page 4 of 17
ME4055A
Absolute Maximum Ratings
Parameter
Rating
Unit
Input supply voltage : VCC
-0.3~6.5
V
PROG pin voltage
-0.3~VCC+0.3
V
BAT pin voltage
-0.3~6.5
V
pin voltage
-0.3~6.5
V
pin voltage
-0.3~6.5
V
BAT pin current
800
mA
PROG pin current
1200
μA
Maximum junction temperature
145
Operating ambient temperature :Topa
-40~85
Storage temperature :Tstr
-65~125
Soldering temperature and time
+260(Recommended 10S)
Caution: The absolute maximum ratings are rated values exceeding which the product could suffer physical damage.
These values must therefore not be exceeded under any conditions.
V05
www.microne.com.cn
Page 5 of 17
ME4055A
Electrical Characteristics
Symbol
Parameter
Condition
ICC -IBAT
VFLOAT
static current
Max
Unit
4.0
5.0
6.5
V
●Charge mode, RPROG=1.1KΩ
150
500
μA
●Standby mode(charge end)
55
100
μA
●Shutdown mode ( RPROG not
connected,
VCC
很抱歉,暂时无法提供与“ME4055AM6G-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41440
- 100+0.37250
- 300+0.35154
- 3000+0.32325
- 6000+0.31061
- 9000+0.30435
- 国内价格
- 5+0.49980
- 50+0.49230
- 600+0.36289
- 1200+0.35745
- 国内价格
- 100+0.25481
- 500+0.24611
- 国内价格
- 1+0.50930
- 200+0.32890
- 1500+0.28600
- 3000+0.25410
