SS215
THRU
SS220
2.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
150 to 200 Volts
CURRENT
2.0 Ampere
FEATURES
DO-214AC(SMA)
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
.110(2.79)
.100(2.54)
.058(1.47)
.052(1.32)
.177(4.50)
.157(3.99)
MECHANICAL DATA
.012(0.31)
.006(0.15)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.063 grams
.090(2.29)
.078(1.98)
.005
MAX.
(.127)
.208(5.28)
.194(4.93)
.060(1.52)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SS215
SS220
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
150
105
150
200
140
200
at TL=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 2.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
A
50
A
V
mA
10
170
-65
-65
V
V
V
2.0
0.92
0.05
Ta=100 C
UNITS
12
+150
+150
mA
PF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead Vertical PC Board Mounting 0.375"(9.5mm) Lead Length.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SS215 THRU SS220)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
50
2.0
1.6
1.2
0.8
0.4
60
80
100
120
140
160
180
200
LEAD TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
2.4
10
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
50
.01
40
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
30
8.3ms Single Half
Tj=25 C
Sine Wave
JEDEC method
10
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
1
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
700
600
500
400
300
200
10
Tj=100 C
1.0
.1
Tj=25 C
100
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SS220”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17946
- 200+0.13980
- 600+0.11777
- 2000+0.10455
- 8000+0.09306
- 16000+0.08692
- 国内价格
- 20+0.16450
- 200+0.12815
- 800+0.10795
- 2000+0.09583
