Metal
Oxide
Varistors
20D Series
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information.
Metal Oxide Varistors - 20D Series
Features
• Wide operating voltage (V1mA) range from 18V to 1800V.
• Fast responding to transient over-voltage.
• Large absorbing transient energy capability.
• Low clamping ratio and no following-on current.
General Information
• Surge protection in consumer electronics
• Surge protection in industrial electronics
• Relay and electromagnetic valve surge absorption
• Transistor, diode, IC, thyristor or triac semiconductor protection
• Surge protection in electronic home appliances, gas and petroleum appliances
General Characteristics
• Body: Nickel Plated
• Devices with No Leads: Nickel Plated
• Operating Temperature: -40ºC to +85ºC
• Storage Temperature: -40 ºC to +125ºC
• Leads: Surface-mount, Axial Devices: Tin Plated
Product Name
2
Element Diameter
D
Type
D: Disk
S: Square
4
7
1
K
J
Nominal Varistor Voltage
Varistor Voltage
Tolerance
Surge Series
471=47*101V
K = ±10 %
No Suffix:Standard
Type
J:High Surge Type
H:Super Surge Type
Circuit Protection
System
Revision:DEC-16
Page:1
Electriacl Characteristics
Type Number
Standard
High Surge
Maximum
Allowable
Voltage
Varistor Voltage
Maximum
Clamping
Voltage
VAC(V) VDC(V)
V1mA(V)
IP(A) VC(V)
Withstanding
Surge Current
I(A)
Standard
I(A)
High Surge
Maximum Energy Rated
(10/1000μs)
Power
(J)
Standard
(J)
High Surge
(W)
Typical
Capacitance
(Reference)
@1KHz(pf)
20D180K
20D180KJ
11
14
18(15~21.6)
2000
3000
5.4
6.8
0.2
39000
20D220K
20D220KJ
14
18
22(19.5~26)
2000
3000
6.6
8.3
0.2
32000
20D270K
20D270KJ
17
22
27(24~30)
2000
3000
8.1
10.1
0.2
22000
20K330K
20K330KJ
33(29.5~36.5)
2000
3000
9.9
12.4
0.2
18000
20D390K
20D390KJ
25
31
39(35~43)
2000
3000
11.7
14.6
0.2
16000
20D470K
20D470KJ
30
38
47(42~54)
2000
3000
14.1
17.6
0.2
14000
20D560K
20D560KJ
35
45
56(50~62)
2000
3000
16.8
21.0
0.2
12000
20D680K
20D680KJ
40
56
68(61~75)
2000
3000
20.4
25.5
0.2
10000
20D820K
20D820KJ
50
65
82(74~90)
100
135
6500
10000
24.6
30.8
1.0
5800
20D101K
20D101KJ
60
85
100(90~110)
100
165
6500
10000
30.0
37.5
1.0
4800
20D121K
20D121KJ
75
100
120(108~132)
100
200
6500
10000
36.0
45.0
1.0
3800
20D151K
20D151KJ
95
125
150(135~165)
100
250
6500
10000
45.0
56.3
1.0
3000
20D181K
20D181KJ
115
150
180(162~198)
100
300
6500
10000
54.0
67.5
1.0
2600
20D201K
20D201KJ
130
170
200(180~220)
100
340
6500
10000
60.0
75.0
1.0
2400
20D221K
20D221KJ
140
180
220(198~242)
100
360
6500
10000
66.0
82.5
1.0
1800
20D241K
20D241KJ
150
200
240(216~264)
100
395
6500
10000
72.0
90.0
1.0
1500
20D271K
20D271KJ
175
225
270(243~297)
100
455
6500
10000
81.0
101.3
1.0
1400
20D301K
20D301KJ
190
250
300(270~330)
100
500
6500
10000
90.0
112.5
1.0
1350
20D331K
20D331KJ
210
275
330(297~363)
100
550
6500
10000
99.0
123.8
1.0
1300
20D361K
20D361KJ
230
300
360(324~396)
100
595
6500
10000
108.0
135.0
1.0
1250
20D391K
20D391KJ
250
320
390(351~429)
100
650
6500
10000
117.0
146.3
1.0
1180
20D431K
20D431KJ
275
350
430(387~473)
100
710
6500
10000
129.0
161.3
1.0
1100
20D471K
20D471KJ
300
385
470(423~517)
100
775
6500
10000
141.0
176.3
1.0
1050
20D511K
20D511KJ
320
415
510(459~561)
100
845
6500
10000
153.0
191.3
1.0
1000
20D561K
20D561KJ
350
460
560(504~616)
100
925
6500
10000
168.0
210.0
1.0
970
20D621K
20D621KJ
385
505
620(558~682)
100
1025
6500
10000
186.0
232.5
1.0
950
20D681K
20D681KJ
420
560
680(612~748)
100
1120
6500
10000
186.0
232.5
1.0
900
20D751K
20D751KJ
460
615
750(675~825)
100
1240
6500
10000
186.0
232.5
1.0
850
20D781K
20D781KJ
485
640
780(702~858)
100
1290
6500
10000
187.2
234.0
1.0
750
20D821K
20D821KJ
510
670
820(738~902)
100
1355
6500
10000
196.8
246.0
1.0
700
20D911K
20D911KJ
550
745
910(819~1001)
100
1500
6500
10000
218.4
273.0
1.0
600
20D951K
20D951KJ
580
780
950(855-1045)
100
1570
6500
10000
228.0
285.0
1.0
580
20D102K
20D102KJ
625
825
1000(900~1100)
100
1650
6500
10000
240.0
300.0
1.0
500
20D112K
20D112KJ
680
895
1100(990~1210)
100
1815
6500
10000
264.0
330.0
1.0
450
20D152K
20D152KJ
900
1220
1500(1350-1650)
100
2475
6500
10000
359.0
449.0
1.0
400
20D182K
20D182KJ
1100
1465
1800(1620~1980)
100
2970
6500
10000
432.0
540.0
1.0
220
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:2
Electrical Ratings
Items
Test Condition/Description
Requirement
Varistor Voltage
The voltage between two terminals with the specified measuring current
1mA.DC applied is called Vb.
Maximum Allowable
Voltage
The recommended maximum sine wave voltage (RMS) or the Maximum
DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Maximum Clamping
Voltage
To meet the
Specified value
Rated Wattage
The maximum average power that can be applied within the specified
ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10% when
one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10% with
the standard impulse current (8/20μs) applied one time.
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
5Φ series
7Φ series
Surge Life
10Φ series
14Φ series
20Φ series
Circuit Protection
System
180K to 680K
10A (8/20μs)
820K to 751K
20A (8/20μs)
180K to 680K
25A (8/20μs)
820K to821K
50A (8/20μs)
180K to 680K
50A (8/20μs)
820K to 112K
100A (8/20μs)
180K to 680K
75A (8/20μs)
820K to 182K
150A (8/20μs)
180K to 680K
100A (8/20μs)
820K to 182K
200A (8/20μs)
∆Vb ±10%
Vb ≤
Revision:DEC-16
Page:3
Soldering Recommendation
Wave Lead Free Soldering Recommendation
Item
Conditions
Peak Temperature
265ºC
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360ºC (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:4
Package Dimensions (Unit:mm)
A
T
D
B
H1
K
很抱歉,暂时无法提供与“20D821K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.55100
- 50+1.18800
- 250+1.10000
- 国内价格
- 1+2.67090
- 10+2.37420
- 50+2.13670
- 100+1.94250
- 500+1.78060
- 1000+1.52630
- 2500+1.33550
- 国内价格
- 1+1.33281
- 10+1.28381
- 100+1.16620
- 500+1.10740
- 国内价格
- 5+2.59321
- 50+2.00449
- 250+1.72687
- 500+1.41209
- 2500+1.27183
- 5000+1.18770
