3R090TB-8
3R090TB-8
    RUILON(瑞隆源)
    GDT_D8X10MM_SM
    电极数:3 直流击穿电压(典型值):90V 精度:±20% 脉冲放电电流:10kA 极间电容:1.5pF 气体放电管
3R090TB-8 数据手册
Gas Discharge Tubes(GDT) 3RB-8 Series Description GDT is placed in front of, and in parallel with, sensitive telecom equipment such as power lines, communication lines, signal lines and data transmission lines to help protect them from damage caused by transient surge voltages that may result from lightning strikes and equipment switching operations. These devices do not influence the signal in normal operation. However, in the event of an overvoltage surge, such as a lightning strike, the GDT switches to a low impedance state and diverts the energy away from the sensitive equipment. Our GDT offer a high level of surge protection, a broad voltage range, low capacitance, and many form factors including new surface mount devices, which makes them suitable for applications such as Main Distribution Frame (MDF) modules, high data-rate telecom applications (e.g. ADSL, VDSL), and surge protection on power lines. Their low capacitance also results in less signal distortion. When used in a coordinated circuit protection solution with PolySwitch devices, they can help equipment manufacturers meet stringent safety regulatory standards. Electrical symbol a a = Tip b = Ring e = Ground (center electrode) b e Features Applications l l l l l l l l l l l l l l l l l Excellent response to fast rising transients Stable breakdown voltage GHz working frequency 8/20μs Impulse current capability: 10KA Non-Radioactive Ultra Low capacitance (
3R090TB-8 价格&库存
很抱歉,暂时无法提供与“3R090TB-8”相匹配的价格&库存,您可以联系我们找货
3R090TB-8
  • 1+2.42000
  • 100+2.25500
库存:1000
3R090TB-8
库存:35
