BAT54H
BAT54H
    SK(時科)
    SOD-323
    肖特基二极管 Single VR=30V IF=0.3A SOD323
BAT54H 数据手册
BAT54H Surface Mount Schottky Barrier Diodes PINNING Features DESCRIPTION PIN • Low Forward Voltage 1 Cathode 2 Anode 2 1 Top View Marking Code: JV Simplified outline SOD-323 and symbol Absolute Maximum Ratings (Ta = 25 C) O Parameter Symbol Value Unit VRRM 30 V VR 30 V Average Forward Rectified Current IF(AV) 300 mA Non-Repetitive Peak Forward Surge Current at t = 1 s IFSM 2 A Power Dissipation Ptot 200 mW Tj, Tstg - 65 to + 125 Peak Repetitive Reverse Voltage Reverse Voltage Operating and Storage Temperature Range C O Characteristics at Ta = 25 C O Symbol Min. Typ. Max. V(BR)R 30 - - IR - - 5 5 5 VF - - 0.37 0.6 V Total Capacitance at VR = 0 V, f = 1 MHz CT - 50 - pF Reverse Recovery Time at IF = IR = 200 mA, Irr = 0.1 IR, RL = 100 Ω trr - 10 - ns Parameter Reverse Breakdown Voltage at IR = 10 ÿA Reverse Leakage Current at VR = 30 V at VR = 20 V at VR = 10 V Forward Voltage at IF = 20 mA at IF = 200 mA REV.08 1 of 3 Unit V µA BAT54H REV.08 2 of 3 BAT54H PACKAGE OUTLINE Plastic surface mounted package; 2 leads REV.08 3 of 3 SOD-323
BAT54H 价格&库存
很抱歉,暂时无法提供与“BAT54H”相匹配的价格&库存,您可以联系我们找货
BAT54H
    • 1+0.04170
    • 100+0.03940
    库存:26
    BAT54H
      • 3000+0.03578
      库存:32400
      BAT54H
        • 3000+0.03578
        库存:140400
        BAT54H
          • 50+0.09008
          • 500+0.07118
          • 3000+0.06048
          • 6000+0.05411
          • 24000+0.04860
          • 51000+0.04569
          库存:15809
          BAT54H
          • 1+0.22330
          • 200+0.07458
          • 1500+0.04664
          • 3000+0.03707
          库存:5185
          BAT54H
          • 5+0.05771
          • 20+0.05276
          • 100+0.04781
          • 500+0.04286
          • 1000+0.04055
          • 2000+0.03890
          库存:1655
