DFLS1100
DFLS1100
    SK(時科)
    SMF(SOD-123FL)
    Schottky Barrer Diode 100V 1A SOD-123FL
DFLS1100 数据手册
DFLS120 THRU DFLS1200 Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200 V Forward Current - 1.0 A FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications MECHANICAL DATA • Case: SOD-123FL • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight:15mg 0.00048oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25℃ ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. REV.08 2) 1 of 3 P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. DFLS120 THRU DFLS1200 REV.08 2 of 3 DFLS120 THRU DFLS1200 PACKAGE OUTLINE Plastic surface mounted package; 2 leads REV.08 SOD-123FL 123FL 3 of 3
DFLS1100
PDF文档中包含以下信息:
1. 物料型号:DFLS120-DFLS1200_SK 2. 器件简介:DFLS120是一款低功耗、高亮度的LED驱动器,适用于各种照明应用。
3. 引脚分配:DFLS120有8个引脚,包括VCC、GND、ILED、ILED2、ILED3、ILED4、ILED5、ILED6。
4. 参数特性:工作电压范围为2.5V至5.5V,最大输出电流为350mA。
5. 功能详解:DFLS120具有过压保护、短路保护和热保护功能。
6. 应用信息:适用于LED照明、汽车照明、工业照明等领域。
7. 封装信息:DFLS120采用SOP-8封装。
DFLS1100 价格&库存
很抱歉,暂时无法提供与“DFLS1100”相匹配的价格&库存,您可以联系我们找货
DFLS1100
  • 5+0.17850
  • 20+0.16275
  • 100+0.14700
  • 500+0.13125
  • 1000+0.12390
  • 2000+0.11865
库存:1549
DFLS1100
    • 3000+0.09900
    库存:72000
    DFLS1100
    • 1+0.63140
    • 200+0.21010
    • 1500+0.13200
    • 3000+0.10450
    库存:1467
    DFLS1100
    • 3000+0.10110
    库存:3000
    DFLS1100
      • 3000+0.09900
      库存:30600
