RB160M-40
RB160M-40
    SK(時科)
    SMF(SOD-123FL)
    Schottky Barrer Diode 40V 1A SOD-123FL
RB160M-40 数据手册
Surface Mount Schottky Barrier Rectifier Reverse Voltage - 30 to 90 Forward Current - 1.0 A FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability PIN DESCRIPTION 1: Cathode 2: Anode • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Simplified outline SOD-123FL 123FL and symbol MECHANICAL DATA • Case: SOD-123FL • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight:15mg 0.00048oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25℃ ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. 2) P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. 1 of 3 2 of 3 PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL 123FL 3 of 3
RB160M-40 价格&库存
很抱歉,暂时无法提供与“RB160M-40”相匹配的价格&库存,您可以联系我们找货
RB160M-40
    • 3000+0.08800
    库存:14400
    RB160M-40
      • 3000+0.08800
      库存:3600
      RB160M-40
      • 5+0.17001
      • 20+0.15501
      • 100+0.14001
      • 500+0.12501
      • 1000+0.11801
      • 2000+0.11301
      库存:479
