ABS10
ABS10
    JINGDAO(晶导微电子)
    ABS
    0.8A表面安装玻璃钝化桥式整流器Vr=1KV ABS
ABS10 数据手册
山东晶导微电子有限公司 ABS1 THRU ABS10 Jingdao Microelectronics 0.8A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: PINNING • Glass Passivated Chip Junction • Reverse Voltage - 100 to 1000 V • Forward Current - 0.8 A PIN DESCRIPTION 1 Input Pin(~) 2 Input Pin(~) • High Surge Current Capability 3 Output Anode(+) • Designed for Surface Mount Application 4 Output Cathode(-) MECHANICAL DATA • Case: ABS/LBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 88mg 0.0031oz 3 4 2 1 ABS/LBF Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols ABS1 ABS2 ABS4 ABS6 ABS8 ABS10 Units Maximum Repetitive Peak Reverse Voltage V RRM 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 100 200 400 600 800 1000 V Parameter Average Rectified Output Current at T c = 125 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) Forward Voltage per element @I F= 0.4A @I F =0.8A Maximum DC Reverse Current at Rated DC Blocking Voltage @ T A =100℃ IO 0.8 A I FSM 30 A VF 1.0 1.1 V IR 5.0 50 100 μA Cj 13 pF RθJA RθJC 80 22 °C/W T j , T stg -55 ~ +150 °C @ T A =25 °C @ T A =125 °C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Operating and Storage Temperature Range Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. 2016.01 ABS-A-ABS1~ABS10-0.8A1KV Page 1 of 3 山东晶导微电子有限公司 ABS1 THRU ABS10 Jingdao Microelectronics Fig.2 Typical Reverse Characteristics 1.2 1.0 0.8 0.6 0.4 0.2 Resistive or Inductive Load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Rectified Output Current (A) Fig.1 Average Rectified Output Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 100 T J =25°C 10 1 0.5 1.0 1.5 2.0 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 40 8.3 ms Single Half Sine Wave (JEDEC Method) 30 20 10 00 1 10 100 Number of Cycles 2016.01 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 ABS1 THRU ABS10 Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 4 leads ABS/LBF ∠ALL ROUND ∠ALL ROUND C A a L1 d L HE e D e E ABS/LBF mechanical data A C D E HE d e max 1.5 0.22 5.2 4.5 6.4 4.2 0.7 min 1.3 0.15 4.9 4.2 6.0 3.8 0.5 max 59 8.7 205 177 252 165 28 min 51 5.9 193 166 236 150 20 UNIT mm L L1 a 0.95 0.6 0.2 ∠ 7° 37 mil The recommended mounting pad size 24 4 Marking Type number 6.2 244 4.0 157 1.0 39 2.0 79 201.01 mm Unit : (mil) JD512284B6 Marking code ABS1 ABS1 ABS2 ABS2 ABS4 ABS4 ABS6 ABS6 ABS8 ABS8 ABS10 ABS10 ABSxx Page 3 of 3
ABS10 价格&库存
很抱歉,暂时无法提供与“ABS10”相匹配的价格&库存,您可以联系我们找货
ABS10
  • 20+0.25132
  • 200+0.19829
  • 600+0.16881
  • 5000+0.15120
  • 10000+0.13587
  • 20000+0.12766
库存:55682
ABS10
  • 5000+0.07232
  • 10000+0.07040
库存:5000
ABS10
  • 20+0.23037
  • 500+0.15474
  • 2000+0.15242
  • 5000+0.13860
库存:12812
