B5819W
B5819W
    JINGDAO(晶导微电子)
    SOD-123
    肖特基二极管 独立式 正向压降(Vf)900mV@3A 直流反向耐压(Vr)40V 整流电流1A 反向电流(Ir)1mA@40V
B5819W 数据手册
山东晶导微电子股份有限公司 B5819W-YJH Jingdao Microelectronics co.LTD SCHOTTKY BARRIER RECTIFIERS FEATURES PINNING • Metal silicon junction, majority carrier conduction PIN DESCRIPTION • Guarding for overvoltage protection 1 Cathode • Low power loss, high efficiency 2 Anode • High current capability 2 • low forward voltage drop • High surge capability 1 Top View Marking Code: 14A Simplified outline SOD-123 and symbol • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications MECHANICAL DATA • Case: SOD-123 • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight:16mg/0.00056oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Symbols B5819W Units Maximum Repetitive Peak Reverse Voltage V RRM 40 V Maximum RMS voltage V RMS 28 V Maximum DC Blocking Voltage V DC 40 V Maximum Average Forward Rectified Current I F(AV) 1 A Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed On Rated Load (JEDEC method) I FSM 25 A at 1 A at 3 A VF 0.6 0.9 V Maximum Instantaneous Reverse Current at TA = 25°C Rated DC Reverse Voltage TA = 100°C IR 1 10 mA Typical Junction Capacitance Cj 110 pF T j , T stg -55 ~ +125 °C Parameter Maximum Instantaneous Forward Voltage Storage and Operating Junction Temperature Range 2019.05 SOD123-S-YJH-B5819W-1A40V Page 1 of 3 山东晶导微电子股份有限公司 B5819W-YJH Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 10 3 T J =125°C 10 2 T J =75°C 10 1 T J =25°C 10 0 0 Case Temperature (°C) Fig.3 Typical Forward Characteristic 60 80 100 Fig.4 Typical Junction Capacitance 500 5° C =2 TJ 12 5°C 0.5 Junction Capacitance ( pF) 1.0 TJ = Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) 0.2 0.1 0 0.1 0.2 0.3 0.4 0.5 0.6 200 100 50 20 10 0.7 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 30 8.3 ms Single Half Sine Wave (JEDEC Method) 25 20 15 10 05 00 1 10 100 Number of Cycles at 50Hz 2019.05 www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 B5819W-YJH Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 A D b E A1 C ∠ALL ROUND L1 E1 SOD-123 mechanical data A C D E E1 L1 b A1 max 1.3 0.22 1.8 2.8 3.9 0.45 0.7 0.2 min 0.9 0.09 1.5 2.5 3.6 0.25 0.5 max 51 8.7 71 110 154 18 28 min 35 3.5 59 98 142 10 20 UNIT ∠ mm 9° 8 mil The recommended mounting pad size Marking Type number 2.0 (79) 1.2 (47) B5819W Marking code 14A 1.2 (47) 1.2 (47) Unit: mm (mil) 2019.05 905212A8 Page 3 of 3
B5819W 价格&库存
很抱歉,暂时无法提供与“B5819W”相匹配的价格&库存,您可以联系我们找货
B5819W
  • 50+0.11800
  • 500+0.09390
  • 3000+0.08140
库存:29762
B5819W
  • 50+0.11860
  • 600+0.09563
  • 1200+0.09420
  • 3000+0.08286
  • 15000+0.07524
  • 30000+0.06861
库存:224576
B5819W
    • 3000+0.05010
    库存:3000
    B5819W
    • 1+0.32890
    • 200+0.10989
    • 1500+0.06875
    • 3000+0.05456
    库存:76520
