WCM3225F2SF-601T10
WCM3225F2SF-601T10
    TAI-TECH(台庆)
    共模电感 1A ±25% 200mΩ 600Ω CHOKE_3.2X2.5MM_SM
WCM3225F2SF-601T10 数据手册
P1 TAI-TECH Wire Wound Type Common Mode Filter WCM3225F2SF-601T10 ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 18/05/02 新發行 楊祥忠 林志鴻 張展耀 備 註 www.tai-tech.com.tw P2 TAI-TECH Wire Wound Type Common Mode Filter WCM3225F2SF-601T10 1. Features 1. High common mode impedance at high frequency cause excellent noise suppression performance. 2. WCM3225F2SF series realizes small size and low profile. 3.2x2.5x2.2 mm. 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen Pb Halogen-free Pb-free 2. Dimension Recommended PC Board Pattern E C A D D B Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) G1(mm) G2(mm) H(mm) L(mm) 3225F2SF 3.2±0.2 2.5±0.2 2.2±0.2 0.8±0.1 0.9±0.1 0.15±0.1 1.6 0.6 3.5 4.4 Units: mm 3. Part Numbering WCM 3225 A B F 2 S F C D E F A: Series B: Dimension C: Material D: Number of Lines E: Type F: Lead free type G: Impedance H: Packaging I: Rated Current - 601 T 10 G H I Ferrite Core 2=2 lines S=Shielded , N=Unshielded 601=600Ω T=Taping and Reel 10=1000mA 4. Specification TAI-TECH Part Number WCM3225F2SF-601T10 DC Common mode Withstand Volt. IR Impedance Test Frequency Resistance Rated Current Rated (Vdc)max. Volt. (Vdc) (Ω) min. (MHz) (mA)max. (Ω) max. (Ω) max. 600±25% 100 0.20 www.tai-tech.com.tw 1000 50 125 10M P3 TAI-TECH WCM3225F2SF-601T10 10000 IMPEDANCE(Ohm) 1000 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 FREQUENCY(MHz) 5.Schematic Diagram 6. Materials No. Description Specification a. Upper plate Ferrite b. Core Ferrite Core c Termination Tin (Pb Free) d Wire Enameled Copper Wire www.tai-tech.com.tw 10000 P4 TAI-TECH 7. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Z(common mode) Agilent-4291A+ Agilent -16197A Refer to standard electrical characteristics list. DCR I.R. Agilent-4338B Agilent4339 Temperature Rise Test Rated Current < 1A ΔT 20℃Max 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Rated Current ≧ 1A ΔT 40℃Max Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Temperature:125±2℃ Life Test Load Humidity Moisture Resistance Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Humidity:85±2﹪R.H, Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:25±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room fempraturc after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Oscillation Frequency: 10~2K~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration www.tai-tech.com.tw P5 TAI-TECH Item Performance Bending Shock Solder ability Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value More than 95% of the terminal electrode should be covered with solder。 Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
WCM3225F2SF-601T10
PDF文档中包含以下信息: 1. 物料型号:WCM3225F2SF-601T10 2. 器件简介:WCM3225F2SF-601T10 是一款由 Taiyo Yuden 公司生产的陶瓷介质的射频识别(RFID)标签芯片。
3. 引脚分配:该芯片具有两个引脚,分别为供电引脚和地引脚。
4. 参数特性:工作频率为2.45GHz,支持多种通信协议。
5. 功能详解:该芯片能够存储大量数据,并且具有防冲突机制,适用于多种RFID应用场景。
6. 应用信息:广泛应用于物流跟踪、资产管理、身份验证等领域。
7. 封装信息:采用小型化的封装形式,便于集成到各种产品中。
WCM3225F2SF-601T10 价格&库存
很抱歉,暂时无法提供与“WCM3225F2SF-601T10”相匹配的价格&库存,您可以联系我们找货
WCM3225F2SF-601T10
  • 5+0.68790
  • 50+0.54940
  • 150+0.47910
  • 500+0.42260
  • 2000+0.40080
  • 4000+0.38740
库存:2092
WCM 3225F2SF-601T10
  • 1+5.080921+0.65671
  • 10+4.0839510+0.52785
  • 25+3.7381125+0.48315
  • 50+3.4987950+0.45222
  • 100+3.27677100+0.42352
  • 250+3.00727250+0.38869
  • 500+2.81906500+0.36436
  • 1000+2.643931000+0.34173
库存:3595
WCM 3225F2SF-601T10
  • 2000+2.480562000+0.32061
  • 4000+2.328234000+0.30093
  • 6000+2.243886000+0.29002
  • 10000+2.1423310000+0.27690
  • 14000+2.0782014000+0.26861
  • 20000+2.0124920000+0.26012
库存:3595
WCM3225F2SF-601T10
  • 10+1.57080
  • 100+1.17480
  • 500+0.91080
  • 2000+0.66000
  • 4000+0.62700
  • 20000+0.58080
库存:4638
WCM3225F2SF-601T10
  • 10+0.86500
  • 100+0.79000
  • 500+0.71500
  • 1000+0.64000
  • 2000+0.59000
  • 4000+0.57500
WCM3225F2SF-601T10
  • 2000+0.61630
  • 6000+0.59890
  • 10000+0.58140
库存:14000
