TAI-TECH
SMD Power Inductor
TMPA0603S-Series(N)-D
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
15/07/02
新發行
楊祥忠
詹偉特
何秦芝
備
注
TAI-TECH
SMD Power Inductor
1. Features
1. Shielded construction.
2. Capable of corresponding high frequency (5MHz).
Halogen
Pb
Halogen-free
Pb-free
3. Low loss realized with low DCR.
4. High performance (Isat) realized by metal dust core.
5. Ultra low buzz noise, due to composite construction.
6. 100% Lead(Pb)-Free and RoHS compliant.
2. Applications
1. DC/DC converters in distributed power systems.
2. DC/DC converter for Field Programmable Gate Array(FPGA).
3. Battery powered devices.
4. Thin type on-board power supply module for exchanger.
5. VRM for server.
6. High current, low profile POL converters.
7. PDA/notebook/desktop/server and battery powered devices.
3. Dimensions
Recommend PC Board Pattern
C
A
D
L
H
E
B
1R0
1526
T
Series
TMPA0603
A
B
G
C
E
T
L(mm)
G(mm)
H(mm)
3.0±0.2
0~0.15
8.0
3.7
3.4
D
7.1±0.3 6.6±0.2 2.8±0.2 1.6±0.3
Note: Only for reference.
Unit:mm
4. Part Numbering
TMPA
0603
S
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: Code
1R0
MN
D
E
D
F
BxC
Standard.
R10=0.1uh,1R0=1.0uh,100=10uh,101=100uh,102=1000uh.
K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%
Marking: Black.1R0 and 1526(15 YY, 26 WW,follow production date).
TAI-TECH
5. Specification
Part Number
Inductance
L0 A(uH)
±20%
Heat Rating
Current DC
Typ ( A ) Irms.
Saturation
Current DC
Typ (A)I sat
DCR
(mΩ)Typ
DCR
(mΩ)Max
TMPA0603S-R15YN-D
0.15±30%
30
40
1.7
2.1
TMPA0603S-R22MN-D
0.22
23
34
2
2.5
TMPA0603S-R33MN-D
0.33
21
25
2.8
3.4
TMPA0603S-R36MN-D
0.36
3.3
3.9
TMPA0603S-R47MN-D
0.47
18
4
TMPA0603S-R56MN-D
0.56
16.5
18
3.9
4.5
TMPA0603S-R68MN-D
0.68
16
17
4.7
5.3
TMPA0603S-R82MN-D
0.82
14
16
5.4
6
TMPA0603S-1R0MN-D
1.00
12
15
6.7
7.4
TMPA0603S-1R2MN-D
1.20
10
14
7.7
9.5
TMPA0603S-1R5MN-D
1.50
10
14
10.2
12.1
TMPA0603S-2R2MN-D
2.20
8
10
13.5
15
TMPA0603S-3R3MN-D
3.30
6.5
9.5
19
22
TMPA0603S-4R7MN-D
4.70
5.5
6.5
28
33
TMPA0603S-5R6MN-D
5.60
5.5
6
39
42
TMPA0603S-6R8MN-D
6.80
4.5
6
43
50
TMPA0603S-8R2MN-D
8.20
4.5
6
54
60
TMPA0603S-100MN-D
10.0
4
5.5
62
68
TMPA0603S-150MN-D
15.0
3
4.5
110
140
TMPA0603S-220MN-D
22.0
2.5
3
150
190
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
6. Material List
NO
Items
1
Core
Materials
Alloy Powder .
2
Wire
3
Solder Plating
100% Pb free solder
Polyester Wire or equivalent.
4
Ink
Halogen-free ketone
7. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
△L≦30% typical.
Saturation DC Current (Isat) will cause L0
to drop △L(%)(keep quickly).
Approximately △T≦40℃
△T(℃) without core loss.
1.Applied the allowed DC current(keep 1 min.).
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature:125±2℃(Bead)
Life Test
Temperature: 85±2℃(Inductor)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
times.( IPC/JEDEC
Humidity:85±2﹪ R.H,
Load Humidity
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Appearance:No damage.
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
Thermal
shock
RDC:within ±15% of initial value and shall not
times.( IPC/JEDEC J-STD-020DClassification
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:25±2℃ ≦0.5min
Step3:105±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Type
Peak
value
(g’s)
Normal
duration (D)
(ms)
SMD
1500
Lead
100
Shock
Bending
Wave
form
Velocity
change
(Vi)ft/sec
0.5
Half-sine
15.4
6
Half-sine
12.3
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805:40x100x1.2mm
=0805:1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“TMPA0603S-150MN-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+1.18230
- 100+1.10350
- 500+1.02470
- 1000+0.94580
- 2000+0.86710
- 4000+0.78820
