山东晶导微电子有限公司
ES1JS
Jingdao Microelectronics
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 600 V
PINNING
Forward Current – 0.5 A
PIN
FEATURES
• Easy pick and place
• For surface mounted applications
• Low profile package
• Built-in strain relief
• Superfast recovery times for high efficiency
DESCRIPTION
1
Cathode
2
Anode
1
2
Simplified outline SOD-123FL and symbol
MECHANICAL DATA
• Case: SOD-123FL
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight:15mg 0.00053oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES1JS
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
600
V
Maximum RMS voltage
V RMS
420
V
Maximum DC Blocking Voltage
V DC
600
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
0.5
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
15
A
Maximum Forward Voltage at 0.5 A
VF
1.7
V
IR
1
50
μA
Cj
10
pF
t rr
50
ns
RθJA
110
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SOD123FL-E-ES1JS-0.5A600V
Page 1 of 3
山东晶导微电子有限公司
ES1JS
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
10 ohm
Noninductive
t rr
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
OSCILLOSCOPE
Note 1
NonInductive
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
25ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
0.6
0.5
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
0.4
0.3
0.2
0.1
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
Case Temperature (°C)
0.1
0.01
0.001
0.5
80
100
14
T J =25°C
Fig.5 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
1.0
40
% of PIV.VOLTS
1.0
1.5
2.0
12
10
2.5
Instaneous Forward Voltage (V)
8
6
4
2
T J =25°C
f = 1.0MHz
V sig = 50mV p-p
0.1
1
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
ES1JS
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
g
pad
e
E
A
pad
HE
7°
The recommended mounting pad size
Marking
Type number
2.0
(79)
ES1JS
1.2
(47)
Marking code
EJS
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2016.01
JD512263B8
Page 3 of 3
很抱歉,暂时无法提供与“ES1JS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.03410
- 20+0.03109
- 100+0.02808
- 500+0.02508
- 1000+0.02367
- 2000+0.02267
