KBP210
KBP210
    JINGDAO(晶导微电子)
    KBP
    桥式整流器/整流桥 1KV 2A KBP
KBP210 数据手册
山东晶导微电子有限公司 Jingdao Microelectronics KBP2005 thru KBP210 REVERSE VOLTAGE - 50 to 1000 Volts FORWARD CURRENT - 2.0 Amperes GLASS PASSIVATED BRIDGE RECTIFIERS KBP FEATURES Rating to 1000V PRV Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique The plastic material has UL flammability classification 94V#0 MECHANICAL DATA Polarity : As marked on body Weight : 0.05 ounces, 1.52 grams Mounting position : Any + ~ ~ - MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. SYMBOL KBP 2005 KBP 201 KBP 202 KBP 204 KBP 206 KBP 208 KBP 210 UNIT Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V CHARACTERISTICS Maximum DC Blocking Voltage Maximum Average Forward Rectified Current @TC=100°C Peak Forward Surge Current 8.3ms single half sine-wave @ Tj = 25 ℃ Peak Forward Surge Current @ Tj = 25 ℃ 1.0ms single half sine-wave @ TJ = 125℃ I(AV) 2.0 A IFSM 45 A IFSM 80 100 A VF 1.1 V IR 5.0 500 uA Maximum Forward Voltage at 2.0A DC Maximum DC Reverse Current at rated Blocking Voltage @Tj=25°C @Tj=125°C I t Rating for fusing (3ms≦t ≦8.3ms) 2 I t 2 17.5 A S Typical Junction Capacitance per element (Note 1) CJ 25 pF RΘJC 10 RΘJL 18 RΘJA 40 TJ -55 to 150 °C TSTG -55 to 150 °C Typical thermal resistance (Note 2) Operation Temperature Range Storage Temperature Range 2 °C/W Note: (1) Measured at 1.0MHz and applied reverse voltage of 4.0V DC. (2) Thermal Resistance Junction to Case, Lead and Ambient. 1 Version: 0 山东晶导微电子有限公司 Jingdao Microelectronics KBP2005 thru KBP210 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD CURRENT AMPERES FIG.1 # FORWARD CURRENT DERATING CURVE 2.0 1.0 0 0 100 50 150 FIG.2 # MAXIMUM NON-REPETITIVE SURGE CURRENT 45 40 35 30 25 20 15 10 Single Half#Sine#Wave 05 0 1 2 5 TEMPERATURE , C 50 100 NUMBER OF CYCLES AT 60Hz FIG.4 # TYPICAL FORWARD CHARACTERISTICS FIG.3 # TYPICAL JUNCTION CAPACITANCE 100 INSTANTANEOUS FORWARD CURRENT ,(A) 10 10 Vsig=50mV p#p TJ = 25 C, f= 1MHz 1.0 0.1 TJ = 25 C PULSE WIDTH 300us .01 1.0 0.1 1.0 4 100 10.0 0 REVERSE VOLTAGE , VOLTS 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE , VOLTS FIG.5 # TYPICAL REVERSE CHARACTERISTICS 1000 INSTANTANEOUS REVERSE CURRENT ,(uA) CAPACITANCE , (pF) 20 10 TJ = 125 C 100 10 1.0 TJ = 25 C 0.1 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) 2 Version: 0 山东晶导微电子有限公司 Jingdao Microelectronics KBP2005 thru KBP210 KBP Package Outline Dimensions KBP MIN. MAX. A 14.25 14.75 B 3.35 3.65 C 10.20 10.60 D 14.25 14.73 d 1.40 1.70 E 1.80 2.20 DIM. F 0.80 1.10 G 3.56 4.06 H 0.35 0.55 I 1.22 1.42 J 0.76 0.86 K + ~ ~ - 2.7 x 45° (Typ) L # 3° M # 2° All Dimensions in millimeter 3 Version: 0
KBP210 价格&库存
很抱歉,暂时无法提供与“KBP210”相匹配的价格&库存,您可以联系我们找货
KBP210
    • 5+0.50911
    库存:29
    KBP210
      • 1+0.77100
      库存:5
