山东晶导微电子股份有限公司
MMBT4401
Jingdao Microelectronics co.LTD
SOT-23
MMBT4401
NPN TRANSISTOR
3
FEATURES
• Switching Transistor
1
MAXIMUM RATINGS (Ta=25℃ unless other wise noted)
Parameter
Collector–Base Voltage
Collector–Emitter Voltage
Emitter–Base Voltage
Collector Current — Continuous
Collector Power Dissipation
Thermal Resistance From Junction
To Ambient
Operation Junction and Storage
Temperature Range
Symbol
Value
Unit
V CBO
V CEO
V EBO
IC
PC
60
40
6
600
300
V
V
V
mA
mW
R thJA
417
℃/W
T J ,T stg
-55~+150
2
1.BASE
2.EMITTER
3.COLLECTOR
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted.)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V (BR)CBO
I C = 100uA, I E = 0
60
V
Collector-emitter breakdown voltage
V (BR)CEO
I C = 1 mA, I B = 0
40
V
Emitter-base breakdown voltage
V (BR)EBO
I E = 100uA, I C = 0
6
V
Collector cut-off current
I CBO
V CB = 50V, I E = 0
0.1
uA
I CEX
V CE = 35V, V EB =0.4V
0.1
uA
Emitter cut-off current
I EBO
V EB = 5V, I C =0
0.1
uA
h FE1
V CE = 1V, I C =0.1mA
h FE2
V CE = 1V, I C =1mA
40
h FE3
V CE = 1V, I C =10mA
80
h FE4
V CE = 1V, I C = 150mA
100
h FE5
V CE = 2V, I C = 500mA
40
DC current gain
Collector-emitter saturation voltage
Base-emitter saturation voltage
V CE(sat)
V BE(sat)
Transition frequency
fT
Delay time
td
Rise time
tr
Storage time
ts
Fall time
tf
2020.10
300
I C = 150mA, I B = 15mA
0.4
V
I C = 500mA, I B = 50mA
0.75
V
0.95
V
1.2
V
V CE = 10V, I C = 20mA,
f=100MHz
V C C =30V,V BE(off) =-2V
I C =150mA, I B1 =15mA
V CC = 30V, I C = 150mA
I B1 = I B2 = 15mA
www.sdjingdao.com
250
MH Z
15
ns
ns
225
ns
60
ns
Page 1 of 4
山东晶导微电子股份有限公司
MMBT4401
TYPICAL CHARACTERICS
COMMON
EMITTER
T a =25℃
0.20
I B =1mA
I B =0.9mA
I B =0.8mA
I B =0.7mA
I B =0.6mA
I B =0.5mA
0.10
I B =0.4mA
I B =0.3mA
I B =0.2mA
I B =0.1mA
2
3
4
5
6
400
200
CAPACITANCE C (pF)
f=1MHz
I E=0/ Ic=0
Ta=25℃
100
C ib
10
C ob
1
10
COLLECTOR-EMITTER SATURATION
VOLTAGE V CEsat (V)
Fig.4
C ob / C ib —— V CB / V EB
1000
1
0.1
150
V CEsat —— I C
Τ α =25℃
0.1
β=10
0.01
0.1
1
10
100
600
I C , COLLECTOR CURRENT (mA)
h FE --Ic
Fig.6
V BEsat —— I C
1
BASE-EMITTER SATURATION
VOLTAGE V BEsat (V)
DC CURRENT GAIN h FE
125
1
Τ α =25℃
100
COMMON
EMITTER
V CE =1V
0.8
10
1
100
500
Τ α =25℃
0.6
0.4
β=10
10
0.2
0.1
600
Fig.8
TRANSITION FREQUENCY f T (MHz)
I C —— V BE
Fig.7
COMMON
EMITTER
V CE =1V
100
T a =25℃
10
1
0.1
0.4
0.6
0.8
1.0
10
1
100
600
1000
COLLECTOR CURRENT I C (mA)
100
10
1000
f T ——I C
1000
100
1.2
COMMON EMITTER
V CE =10V
T a =25℃
10
1
10
40
50
BASE-EMMITER VOLTAGE V BE (V)
2020.10
75
100
REVERSE BIAS VOLTAGE V (V)
Fig.5
50
AMBIENT TEMPERATURE Ta ( ℃)
COLLECTOR-EMITTER VOLTAGE V CE (V)
Fig.3
P C —— T a
Fig.2
COLLECTOR POWER DISSIPATION
Pc (mW)
COLLECTOR CURRENT I C (A)
Fig.1 Static characteristics
0.25
www.sdjingdao.com
Page 2 of 4
山东晶导微电子股份有限公司
MMBT4401
SOT-23 Package Outline Dimensions
e
∠ALL ROUND
A
D
e
M
e
E
C
a
L1
L
HE
SOT-23 mechanical data
UNIT
mm
mil
A
C
D
E
HE
max 1.1 0.15 1.4 3.0
2.6
min 0.9 0.08 1.2 2.8
2.2
e
M
L
L1
a
0.5 1.95 0.55 0.36 0.0
(ref) (ref)
0.3 1.7
0.15
12°
max 43
6
55
118 102
min 35
3
47
110
12
67
87
22
14 0.0
(ref) (ref)
6
Marking
The recommended mounting pad size
0.8
(0.031)
Type number
Marking code
MMBT4401
2X
0.9
(0.039)
0.95
(0.037)
0.95
(0.037)
2.0
(0.079)
mm
Unit :
(inches)
2020.10
201021
Page 3 of 4
山东晶导微电子股份有限公司
MMBT4401
SOT-23 Packing
1.The method of packaging and dimension are shown as below figure. (Dimension in mm)
7 inX8 mm
Cover Tape
3,000 pcs per reel
Carrier Tape
SOT-23
220mm
8 reels per box
24,000 pcs per box
5 boxes per carton
120,000 pcs per carton
105 mm
m
mm
m
210
5m
0m
18
55
180
mm
SOT-23 Embossed Carrier Tape
SOT-23 Tape Leader and Trailer
2020.10
www.sdjingdao.com
Page 4 of 4
很抱歉,暂时无法提供与“MMBT4401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08694
- 500+0.06772
- 3000+0.05703
- 国内价格
- 50+0.08740
- 600+0.06652
- 1200+0.06552
- 3000+0.05492
- 国内价格
- 20+0.16240
- 100+0.10070
- 800+0.06650
- 3000+0.04750
- 6000+0.04510
- 30000+0.04170
- 国内价格
- 50+0.07970
- 600+0.06207
- 1200+0.06114
- 3000+0.05227
