山东晶导微电子有限公司
RS3AB THRU RS3MB
Jingdao Microelectronics
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 3 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: RS3A~RS3M
Simplified outline SMB symbol
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS3AB
RS3BB
RS3DB
RS3GB
RS3JB
RS3KB
RS3MB
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Forward Voltage at 3 A
VF
1.3
V
IR
5
100
μA
Cj
40
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
t rr
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
250
150
500
ns
RθJA
RθJC
48
16
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMB-F-RS3AB~RS3MB-3A1KV
Page 1 of 3
山东晶导微电子有限公司
RS3AB THRU RS3MB
Fig.2 Typical Reverse Characteristics
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Maximum Average Forward Current Rating
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.5
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
RS3AB THRU RS3MB
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2017.01
JD072228B4
Marking
Type number
Marking code
RS3AB
RS3A
RS3BB
RS3B
RS3DB
RS3D
RS3GB
RS3G
RS3JB
RS3J
RS3KB
RS3K
RS3MB
RS3M
Page 3 of 3
很抱歉,暂时无法提供与“RS3MB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.26298
- 200+0.20639
- 600+0.17496
- 国内价格
- 1+0.24310
- 200+0.15840
- 1500+0.13640
- 3000+0.12100
- 国内价格
- 20+0.25430
- 200+0.20240
- 600+0.16820
- 3000+0.14920
- 国内价格
- 20+0.45310
- 100+0.27020
- 800+0.18920
- 3000+0.13510
- 6000+0.12830
- 30000+0.11890
- 国内价格
- 10+0.24106
- 100+0.23744
- 600+0.16038
- 1200+0.15878
