S2M
S2M
    JINGDAO(晶导微电子)
    SMA(DO-214AC)
    整流二极管 VRRM=1KV If=2A VF=1.1V CJ=25pF SMA
S2M 数据手册
山东晶导微电子有限公司 S2A THRU S2M Jingdao Microelectronics Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 2 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View MECHANICAL DATA • Case: SMA • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz Marking Code: S2A-S2M Simplified outline SMA and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols S2A S2B S2D S2G S2J S2K S2M Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 50 A Maximum Instantaneous Forward Voltage at 2 A VF 1.1 V IR 5 100 μA Cj 25 pF RθJA 65 °C/W T j , T stg -55 ~ +150 °C Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance Typical Thermal Resistance (1) (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2016.11 SMA-A-S2A~S2M-2A1KV Page 1 of 3 山东晶导微电子有限公司 S2A THRU S2M Jingdao Microelectronics Fig.2 Typical Reverse Characteristics 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 10 Junction Capacitance ( pF) Instaneous Forward Current (A) 20 percent of Rated Peak Reverse Voltage (%) 1.0 100 T J =25°C 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 75 60 45 30 15 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2016.11 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 S2A THRU S2M Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 2 leads A A SMA c a VM e A HE g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil g e A D The recommended mounting pad size a 0.3 12 Marking Type number 2.4 (94) mm Unit : (mil) 2016.11 S2A S2A S2B S2B S2D S2D S2G S2G 1.8 (71) 1.8 (71) 1.8 (71) Marking code JD611296B0 S2J S2J S2K S2K S2M S2M Page 3 of 3
S2M
- 物料型号:S2A至S2M - 器件简介:这些是用于表面安装的通用硅整流器,具有低剖面封装,玻璃钝化芯片结,易于拾取和放置,符合EU RoHS 2011/65/EU指令的无铅。 - 引脚分配:有两个引脚,1号引脚为阴极,2号引脚为阳极。 - 参数特性:包括最大重复峰值反向电压(VRRM)从50V至1000V,最大直流阻断电压(Voc)与VRRM相同,最大平均正向整流电流(IF(AV))为2A,最大瞬态正向电压(VF)在2A时为1.1V等。 - 功能详解:文档提供了正向电流降额曲线、典型反向特性、典型正向特性、典型结电容和最大非重复峰值正向浪涌电流等图表。 - 应用信息:适用于单相半波60Hz的电阻性或感性负载,对于电容性负载,电流需降额20%。 - 封装信息:塑料表面安装封装,2个引脚,提供了封装的尺寸数据和推荐安装垫尺寸。
很抱歉,暂时无法提供与“S2M”相匹配的价格&库存,您可以联系我们找货
S2M
    • 1+0.07670
    库存:10
    S2M
    • 50+0.09340
    • 500+0.07360
    • 1500+0.06210
    • 5000+0.05570
    库存:9900
    S2M
    • 1+0.25520
    • 500+0.08514
    • 2500+0.05665
    • 5000+0.04653
    库存:9769
    S2M
    • 20+0.17650
    • 100+0.10970
    • 500+0.07250
    • 5000+0.05170
    • 10000+0.04920
    • 50000+0.04550
    库存:32682
    S2M
    • 50+0.09415
    • 1000+0.07425
    • 2000+0.06326
    • 5000+0.05663
    库存:5000
