MMBT5401
MMBT3904
AO3400
SI2305
TRANSISTOR (PNP)
MMBT5401
FEATURES
Complementary to MMBT5551
Ideal for medium power amplification and switching
SOT-23
1.BASE
2.EMITTER
3.COLLECTOR
MARKING: 2L
MAXIMUM RATINGS (TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
VCBO
Collector-Base Voltage
-160
V
VCEO
Collector-Emitter Voltage
-150
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-0.6
A
PC
Collector Power Dissipation
0.3
W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified)
Parameter
Collector-base breakdown voltage
Collector-emitter breakdown voltage
Emitter-base breakdown voltage
Symbol
IC= -100µA,
V(BR)CEO
IC= -1mA,
V(BR)EBO
IE= -10µA, IC=0
Emitter cut-off current
DC current gain
Base-emitter saturation voltage
IE=0
IB=0
MIN
MAX
-160
-150
V
-5
V
-0.1
ICBO
VCB=-120 V,
IE=0
IEBO
VEB=-4V ,
IC=0
hFE1
VCE= -5V,
IC= -1mA
80
hFE2
VCE= -5V,
IC=-10mA
100
hFE3
VCE= -5V,
IC=-50mA
50
-0.1
IB= -5mA
-0.5
VBE(sat)
IC= -50 mA,
IB= -5mA
-1
1
VCE= -5V,
IC= -10mA
100
µA
µA
300
IC=-50 mA,
fT
UNIT
V
VCE(sat)
Transition frequency
www.tw-gmc.com
conditions
V(BR)CBO
Collector cut-off current
Collector-emitter saturation voltage
Test
V
V
MHz
MMBT5401
MMBT3904
AO3400
SI2305
Typical Characteristics
Static Characteristic
-20
-100uA
-18
-70uA
DC CURRENT GAIN
hFE
IC
COLLECTOR CURRENT
(mA)
o
Ta=100 C
250
-80uA
-14
200
-12
-60uA
-10
150
-50uA
-8
-40uA
-6
o
Ta=25 C
100
-30uA
-4
50
-20uA
-2
-0
IC
VCE=-5V
COMMON
EMITTER
Ta=25℃
-90uA
-16
hFE —
300
IB=-10uA
-0
-3
-6
COLLECTOR-EMITTER VOLTAGE
VCE
COLLECTOR-EMITTER
SATURATION VOLTAGE VCEsat
(V)
BASE-EMITTER
SATURATION VOLTAGE
VBEsat (V)
-0.6
Ta=100℃
-0.2
-0.0
-0.1
-1
-10
IC
IC
-0.1
Ta=25℃
-1
(mA)
-10
Cob / Cib
100
IC
(mA)
—— VCB / VEB
VCE=-5V
f=1MHz
IE=0 / IC=0
o
Ta=25 C
IC
Cib
C
-10
CAPACITANCE
(pF)
COLLECTOR CURRENT
(mA)
-600
-100
COLLECTOR CURRENT
IC —— V
BE
-100
(mA)
Ta=100℃
-0.01
-0.1
-600
-100
COLLECTOR CURRENT
IC
β=10
Ta=25℃
-0.4
-600
-100
VCEsat ——
-1
β=10
-0.8
-10
COLLECTOR CURRENT
—— IC
VBEsat
-1.0
-1
(V)
o
Ta=100 C
10
Ta=25℃
-1
-0.1
-0.0
-0.2
-0.4
-0.8
-0.6
BASE- EMITTER VOLTAGE
fT
300
Cob
1
-0.5
-1.0
-1
-10
REVERSE VOLTAGE
VBE(V)
—— IC
Pc
0.4
V
(V)
Ta
0.3
200
COLLECTOR POWER
DISSIPATION Pc
(W)
TRANSITION FREQUENCY
(MHz)
fT
250
0.2
150
100
0.1
50
VCE=-5V
o
Ta=25 C
-0
-5
-10
-15
COLLECTOR CURRENT
www.tw-gmc.com
-25
-20
IC
0.0
-30
50
75
AMBIENT TEMPERATURE
(mA)
1
2
100
Ta
125
150
MMBT5401
MMBT3904
AO3400
SI2305
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
www.tw-gmc.com
SOT-23
1
3
2
很抱歉,暂时无法提供与“MMBT5401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08435
- 500+0.06804
- 3000+0.05562
- 6000+0.05022
- 24000+0.04547
- 51000+0.04288
- 国内价格
- 1+0.24750
- 200+0.08239
- 1500+0.05148
- 3000+0.04092
