MMBT3904
AO3400
SI2305
TRANSISTOR (NPN)
MMBT3904
FEATURES
Epitaxial Planar Die Construction
Complementary PNP Type Available (MMBT3906)
Ideal for Medium Power Amplification and Switching
SOT-23
MARKING: 1AM
1.BASE
2.EMITTER
3.COLLECTOR
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
60
V
VCEO
Collector-Emitter Voltage
40
V
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current
200
mA
PC
Total Device Dissipation
200
mW
RθJA
ThermalResistanceFromJunction toAmbient
625
℃/W
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55 ~ +150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
Min
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC= 10μA, IE=0
60
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= 1mA, IB=0
40
V
Emitter-base breakdown voltage
V(BR)EBO
IE=10μA, IC=0
6
V
Collector cut-off
current
ICBO
VCB= 60V, IE=0
0.1
μA
Collector cut-off
current
ICEX
VCE= 30V, VBE(off)=3V
50
nA
IEBO
VEB= 5V, IC=0
0.1
μA
hFE(1)
VCE= 1V, IC=10mA
100
hFE(2)
VCE= 1V, IC= 50mA
60
hFE(3)
VCE= 1V, IC= 100mA
30
Collector-emitter saturation voltage
VCE(sat)
IC= 50mA, IB= 5mA
0.3
V
Base-emitter saturation voltage
VBE(sat)
IC= 50mA, IB= 5mA
0.95
V
Emitter cut-off
current
DC current gain
Transition frequency
fT
VCE= 20V, IC=10mA, f=100MHz
Delay Time
td
VCC= 3V,
Rise Time
tr
ts
tf
IC= 10mA, IB1=-IB2=1.0mA
Storage Time
Fall Time
www.tw-gmc.com
VCC= 3V,
VBE=-0.5V
IC=10mA,
IB1=-IB2=1mA
1
300
300
MHz
35
nS
35
nS
200
nS
50
nS
MMBT3904
AO3400
SI2305
Typical Characteristics
aracteristic
Static Ch
IC
COLLECTOR CURRENT
(mA)
300uA
250uA
200uA
40
150uA
Ta=25℃
200
100
100uA
Ta=100℃
300
350uA
60
IC
COMMON EMITTER
VCE=1V
COMMON
EMITTER
Ta=25℃
500uA
450uA
400uA
80
hFE
400
DC CURRENT GAIN
hFE
100
IB=50uA
8
12
16
COLLECTOR-EMITTER VOLTAGE
VCEsat
600
VCE
0.3
IC
VBEsat
1.2
30
10
3
COLLECTOR CURRENT
(V)
IC
100
(mA)
IC
BASE-EMITTER
SATURATION VOLTAGE
VBEsat (V)
COLLECTOR-EMITTER
SATURATION VOLTAGE VCEsat
(mV)
300
Ta=25℃
0.8
Ta=100℃
100
Ta=25℃
Ta=100℃
0.4
30
β=10
β=10
10
1
10
3
IC
100
100
30
COLLECTOR CURRENT
IC
0.0
200
1
10
3
(mA)
—— VBE
Cob/ Cib
9
IC
VCB/ VEB
f=1MHz
IE=0/IC=0
Ta=25℃
C
10
300
(mA)
Cib
Ta=100℃
CAPACITANCE
(pF)
COLLECTOR CURRENT
(mA)
IC
COMMON EMITTER
VCE=1V
30
3
Ta=25℃
1
3
Cob
0.3
0.1
0.2
0.6
0.4
0.8
1.0
1
0.1
1.2
fT
300
1
0.3
BASE-EMITTER VOLTAGE VBE (V)
—— IC
PC
250
VCE=20V
Ta=25℃
10
3
REVERSE VOLTAGE
V
(V)
Ta
200
fT
200
150
COLLECTOR POWER
DISSIPATION PC
(mW)
TRANSITION FREQUENCY
(MHz)
100
30
COLLECTOR CURRENT
100
50
100
1
3
10
COLLECTOR CURRENT
www.tw-gmc.com
30
IC
(mA)
50
75
AMBIENT TEMPERATURE
1
2
100
Ta
125
150
MMBT3904
AO3400
SI2305
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
www.tw-gmc.com
SOT-23
1
3
2
很抱歉,暂时无法提供与“MMBT3904”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.14630
- 200+0.04884
- 1500+0.03047
- 3000+0.02420
- 国内价格
- 50+0.04584
- 600+0.03703
- 1200+0.03647
- 3000+0.02901
