SD103AX
FEATURES
SCHOTTKY BARRIER RECTIFIERS
M etal silicon junction, majority carrier conduction
PINNING
PIN
G uarding for overvoltage protection
DESCRIPTION
1
Cathode
L ow power loss, high efficiency
2
Anode
H igh current capability
l ow forward voltage drop
H igh surge capability
2
F or use in low voltage, high frequency inverters,
1
free wheeling, and polarity protection applications
Top View
Marking Code: S4
MECHANICAL DATA
Simplified outline SOD-523 and symbol
Case: SOD-523
Terminals: Solderable per MIL-STD-750, Method 2026
Absolute Maximum Ratings (Ta = 25 C)
O
Parameter
Symbol
Value
Unit
VRRM
40
V
VR
40
V
Average Forward Rectified Current
IF(AV)
350
mA
Non-Repetitive Peak Forward Surge Current at t = 1 s
IFSM
2
A
Power Dissipation
Ptot
200
mW
Tj, Tstg
- 65 to + 125
Peak Repetitive Reverse Voltage
Reverse Voltage
Operating and Storage Temperature Range
C
O
Characteristics at Ta = 25 C
O
Symbol
Parameter
Reverse Breakdown Voltage
at IR =10uA
V(BR)R
Reverse Leakage Current
at VR =30V
Min.
40
Typ.
Max.
Unit
V
IR
5
µA
Forward Voltage
at IF = 20 mA
at IF = 200 mA
VF
0.37
0.6
V
Total Capacitance
at VR = 0 V, f = 1 MHz
CT
50
pF
Reverse Recovery Time
at IF = IR = 200 mA, Irr = 0.1 IR, RL = 100 Ω
trr
10
ns
www.tw-gmc.com
1
SD103AX
www.tw-gmc.com
1
2
SD103AX
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
ALL ROUND
A
C
HE
D
www.tw-gmc.com
UNIT
mm
bp
E
A
A
0.70
0.60
bp
0.4
0.3
C
0.135
0.100
D
1.25
1.15
1
3
E
0.85
0.75
HE
1.7
1.5
V
0.1
5
O
很抱歉,暂时无法提供与“SD103AX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.06392
- 300+0.05133
- 国内价格
- 20+0.08150
- 200+0.07530
- 600+0.06900
- 3000+0.06270
- 国内价格
- 50+0.08122
- 500+0.06372
- 3000+0.05487
- 6000+0.04904
- 24000+0.04396
- 51000+0.04126
