山东晶导微电子有限公司
US2A THRU US2M
Jingdao Microelectronics
SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 2 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• High efficiency
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: US2A~US2M
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
US2A
US2B
US2D
US2G
US2J
US2K
US2M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Parameter
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
50
A
Maximum Instantaneous Forward Voltage at 2 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Maximum Reverse Recovery Time (1)
Typical Thermal Resistance
(2)
Operating and Storage Temperature Range
1.0
1.3
5
100
IR
t rr
1.65
μA
75
50
V
ns
RθJA
RθJC
65
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.11
SMA-U-US2A~US2M-2A1KV
Page 1 of 3
山东晶导微电子有限公司
US2A THRU US2M
Fig.2 Typical Reverse Characteristics
3.0
2.5
2.0
1.5
1.0
0.5
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
T J =25°C
1.0
US2A~US2D
US2G
0.1
US2J~US2M
0.01
0.001
1.0
1.5
2.0
60
80
100
120
140
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
2.5
Instaneous Forward Voltage (V)
2016.11
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
1
10
100
Number of Cycles
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
US2A THRU US2M
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
The recommended mounting pad size
2.4
(94)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
2016.11
g
e
A
D
JD611296B0
a
0.3
12
Marking
Type number
Marking code
US2A
US2A
US2B
US2B
US2D
US2D
US2G
US2G
US2J
US2J
US2K
US2K
US2M
US2M
Page 3 of 3
很抱歉,暂时无法提供与“US2D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08129
- 100+0.07587
- 300+0.07045
- 500+0.06503
- 2000+0.06232
- 5000+0.06070
- 国内价格
- 50+0.11870
- 500+0.09245
- 1500+0.07787
- 国内价格
- 20+0.20650
- 100+0.12800
- 500+0.08450
- 5000+0.06040
- 10000+0.05740
- 50000+0.05310
- 国内价格
- 1+0.31900
- 500+0.10626
- 2500+0.07084
- 5000+0.05808
