山东晶导微电子有限公司
SS52F THRU SS520F
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200V
Forward Current - 5.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS52 — SS520
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 27mg / 0.00095oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS52F
SS54F
SS56F
SS58F
SS510F
SS512F
SS515F
SS520F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
5.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage at 5 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
0.45
0.55
0.70
0.85
1.0
50
IR
Cj
Operating Junction Temperature Range
Storage Temperature Range
VF
mA
500
800
V
pF
RθJA
45
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
1) Measured
2)
at 1MHz and applied reverse voltage of 4 V D.C.
P.C.B. mounted with 0.5 X 0.5" (12.7 X 12.7 mm) copper pad areas.
2015.03
SMAF-S-SS520F-5A200V
Page 1 of 3
山东晶导微电子有限公司
SS52F THRU SS520F
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
6.0
100LFM
5.0
4.0
3.0
2.0
Single phase half wave resistive
or inductive P.C.B mounted on
0.5×0.5"(12.7×12.7mm ) pad areas
1.0
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
T J =100°C
10 3
10 1
T J =25°C
10 0
Lead Temperature (°C)
60
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
SS52F
SS54F
SS56F/SS58F
SS510F/SS520F
0.1
1.0
1.5
100
SS52F/SS54F
SS54F/SS520F
SS56F-SS520F
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
Instaneous Forward Voltage (V)
175
25
1000
2.0
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
100
10
Number of Cycles at 60Hz
2015.03
T J =75°C
10 2
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS52F THRU SS520F
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
D
E
A
V M
7°
The recommended mounting pad size
Marking
Type number
2.2
(86)
1.6
(63)
1.8
(71)
1.6
(63)
mm
Unit :
(mil)
2015.03
www.sdjingdao.com
Marking code
SS52F
SS52
SS54F
SS54
SS56F
SS56
SS58F
SS58
SS510F
SS510
SS512F
SS512
SS515F
SS515
SS520F
SS520
Page 3 of 3
很抱歉,暂时无法提供与“SS54F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.26400
- 200+0.17050
- 1500+0.14740
- 3000+0.13090
- 国内价格
- 20+0.53020
- 100+0.31620
- 800+0.22140
- 3000+0.15810
- 6000+0.15020
- 30000+0.13910
- 国内价格
- 10+0.17568
- 50+0.16248
- 200+0.15148
- 600+0.14048
- 1500+0.13168
- 3000+0.12618
- 国内价格
- 10+0.38859
- 100+0.30046
- 300+0.25640
- 3000+0.22335
- 6000+0.19689
- 9000+0.18360
