SS32 THRU SS3200
Reverse Voltage - 20 to 200 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
PINNING
PIN
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
DESCRIPTION
1
Cathode
2
Anode
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
DO-214AC/SMA
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
2
1
250 °C/10 seconds at terminals
Mechanical Data
Unipolar
Case : JEDEC DO-214AC/SMA molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.0018 ounce, 0.064 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
SYMBOLS
SS32
SS33
SS34
SS35
SS36
SS38
SS310
SS3150
SS3200
UNITS
RMM
VRR
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
V
V
V
VRMS
VDC
Maximum average forward rectified current
at TL(see fig.1)
I(AV)
3.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
100
A
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
IR
CJ
Typical thermal resistance (NOTE 2)
RJA
TJ
10
300
500
0.95
0.2
2.0
-55 to +125
1
mA
℃/W
-55 to +150
-55 to +150
TSTG
V
pF
55.0
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.tw-gmc.com
0.70
0.5
Operating junction temperature range
Storage temperature range
0.55
SS32 THRU SS3200
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
3.5
3.0
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
10 4
T J =75°C
10 2
SS32-SS36
SS38-SS320
10
1
T J =25°C
10 0
80
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1.0
SS32/SS34
SS34A/SS38
SS310/SS312
SS315/SS320
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
200
100
SS32~SS38
SS32F~SS36F
SS310~SS320
SS38F~SS320F
10
0.1
10
1
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
Transient Thermal Impedance( °C /W)
Instaneous Forward Voltage (V)
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
1000
1.8
100
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
T J =100°C
10 3
Lead Temperature (°C)
Peak Forward Surage Current (A)
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
SS32 THRU SS3200
PACKAGE OUTLINE
A
A
Plastic surface mounted package; 2 leads
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
2.4
(94)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
www.tw-gmc.com
3
a
0.3
12
很抱歉,暂时无法提供与“SS34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24022
- 100+0.22420
- 300+0.20819
- 500+0.19217
- 2000+0.18417
- 5000+0.17936
