产品承认书
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N:
CND-TEK P/N. :
DESCRIPTION:
G9602D
HIGH POE+ (1.7A) ENABLED TRANSFORMER 10/100/1000 BASE-T
QUAD PORT THROUGH-HOLE MAGNETICS
REF NO:
QTC-001
REV/NO:
V1.02
DATE:
2015/03/02
■ SPECIFICATION
■ SAMPLE
Q’TY OF SAMPLES
PCS
FULL APPROVED
CONDITIONAL APPROVED
REJECTED
CUSTOMER'S SIGNATURE
REMARK
G9602D
MAGNETICS
V1.0.2
Feb 2, 2015
␡ൣ⻱㚄䗮⭥ᆀᴹ䲀ޜਨ
6KHQ]KHQ&1'7(.Electronics&R/WG
ޜਨൠ൰␡ൣᐲইኡ४㾯ѭ䭷街道百旺社区牛城村牛城路221号505
7(/ )$;86-
(PDLOsales2#FGWHNFRP
+WWSZZZFGWHNFRP
1. FEATURES:
1.1 10/100/1000 BASE-T QUAD PORT THROUGH-HOLE MAGNETICS
1.2 Meets IEEE 802.3at & ANSI X3.263 Standards.
1.3 Suitable For End-span and Mid-span POE+ Applications.
1.4 850mA Current Capabillty Per POE Port
1.5 RoHS Compliant
1.6 Operating Temperature range: 0℃ TO +70℃
1.7 Storage temperature range: -25℃ TO +125℃
2. DIMENSIONS & MARKING
3. SCHEMATICS:
4.ELECTRICAL SPECIFICATIONS @25℃G9602D
4.1 OCL :
350 μH Min. @ 100 KHz, 100mV with 8mA DC Bias
4.2 Leakage Inductance:
0.5 μH Max. @ 100KHz, 0.2V
4.3 Cw/w:
35 pF Max. @ 100KHz, 0.2V
4.4 DCR:
1.20Ω Max.
4.6 Insertion Loss
-1.2 dB Max. (TX & RX)@ 1~100 MHz
4.7 Return Loss:
-16 dB Min @ 0.5-40MHz
-10+20*log(f/80) dB Min @ 40.1-100 MHz
4.8 Cross Talk:
-50 dB Min.@ 1~10 MHz
-55+22*log(f/10) dB Min.@ 10~100 MHz
4.9 Common Mode Rejection : -50 dB Min.@ 2 MHz
4.10 Isolation HI-POT:
-15+20*log(f/200) dB Min.@ 30~200 MHz
1500Vrms 1mA 1Second
5. Recommended Lead Free IR Reflow Soldering Curve:
Item
Soldertechnique
simulation
Temperature
Time(s)
1
Solder iron
350±10
(solder irno temp)
4~5
2
Vapor phase reflow
215±5
(vapor temp)
60±5
3
IR/convection reflow
255±5
(component temp)
30±5
Temperature ramp/immersion
and emersion rate
1℃/s~4℃/s time above 183℃
90s~120s
Note:The curve includes recommended value only, please adjust your equipment to make sure the solder
process.Details please refers to the standard J-STD-020.
6. Reliability Test Criteria:
6.1 Terminal strength: Pull test withstand 9.8N 60+/-0.5S no looseness or movement.
6.2 Solderbility: Dipped in 245℃+/-5℃ molten solder for 3+/-0.5 seconds,95% min shall be smooth any and
bright.
6.3 Resistance to soldering heat : Convection reflow condition setting: peak temperature at 260℃+0/-5℃
above 217℃ for 90-180 seconds, ramp-up rate 2-3℃/s. Ramp-down rate 6℃/s Max. No mechanical problem
found. No electrical failure found per our specification.
6.4 Vibration: 1.5mm amplitude total excursion 10-55-10 Hz traversed in 1minute, x.y.z, axis for 2 hours. Shall
not be any abnormality.
6.5 Random drop (Packing condition): Height 60cm, 3 times on the wood floorboard ,shall not be any
abnormality.
6.6 Dry heat: 100+/-2℃ 96 hours.
6.7 Cold: -20+/-2℃ 96 hours.
6.8 Damp Heat: 60+/-2℃, 93+/-3% RH 96 hours.
6.9 Change of temperature: exposed 5 cycle; each consisting of 30 minutes at -20+/-2℃,2-3minutes at 20+/2℃,30 minutes at 85+/-2℃, 2-3 minutes at 20+/-2℃.
很抱歉,暂时无法提供与“G9602D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.35000
- 10+11.40000
- 30+11.21000
- 国内价格
- 1+15.39000
- 10+13.06098
- 34+11.36808
- 102+9.87012
- 510+9.20322
- 1020+8.90568
