NUP4202W1
NUP4202W1
    YENJI(台湾元基)
    SOT363
    TVS二极管 SOT363 VRWM=5V VC=20V
NUP4202W1 数据手册
NUP4202W1 ESD Protection Array RoHS Device Halogen Free Features - Low operating voltage: 5V - Ultra low capacitance: 0.7pF - Solid-state silicon-avalanche and active circuit triggering technology SOT-363 - Back-drive protection for power-down mode 6 5 4 1 2 3 Mechanical Characteristics - SOT-363 &SC-88 package - Molding compound flammability rating: UL 94V- 0 - Marking: Marking Code - Packaging: Tape and Reel Applications IEC COMPA TIBILITY (EN61000-4) - Video/Graphics Card - IEC 61000-4-2 (ESD) ± 27kV (air), ±16 kV (contact) - Digital Visual Interface (DVI) - IEC 61000-4-4 (EFT) Level - 3, 55A (5/50ns) - USB2.0 Powerand Data lines protection - IEC 6 1000-4-5 (Lightning ) 6A (8/20us ) - Notebook and PC Computers - Monitors and Flat Panel Displays Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 120 Watts Peak Pulse Current ( tp =8/20μs ) Ipp 6 A Operating Temperature TJ -55 to + 85 °C T STG -55 to +150 °C Storage Temperature 1 NUP4202W1 ESD Protection Array Electrical Parameters (T=25℃) Symbol Parameter I IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IF Working Peak Reverse Voltage VC VBR VRWM Maximum Reverse Leakage Current @ V RWM Breakdown Voltage @ I T IT Test Current IF Forward Current VF Forward Voltage @ IF V I R VF IT I PP Electrical Characteristics Parameter Reverse Stand-Off Voltage Reverse Breakdown Voltage Symbol V RWM Pin5 to pin2 T=25°C VBR IT =1mA Pin 5 to pin2 Reverse Leakage Current IR Forward Voltage VF Clamping Voltage VC Junction Capacitance Conditions Cj Minimum Typical Maximum Units 5.0 V 6.0 V V RWM=5V, T=25°C 5 µA 0.8 1 V 17.5 20 V V R = 0V, f = 1MHz I/O pin to GND 1.0 1.5 pF V R = 0V, f = 1MHz Between I/O pins 0.5 Pin 5 to pin2 IT=10 mA IPP=6A, tp =8/20μs I/O pin to GND 2 pF NUP4202W1 ESD Protection Array Typical Characteristics Figure 2: Power Derating Curve 10 110 100 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 1 0.1 0.01 0.1 1 10 100 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration - µs 50 75 100 125 150 Ambient Temperature - TA (℃) Figure 3: Pulse Waveform Figure 4: Clamping Voltage vs. Peak Pulse Current 110 90 Percent Ipp 80 Clamping Voltage -VC(V) Waveform Paramters tr=8µs td=20µs 100 70 e-t 60 50 40 td=Ipp/2 30 20 10 0 0 5 10 15 20 25 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 12 1 2 3 4 5 6 7 8 9 10 11 Peak Pulse Current -Ipp(A) Time (µs) Figure 5: Capacitance vs. Reverse Voltage Figure 6: Forward Voltage vs. Forward Current 5 8 7 Forward Voltage–VF(V) Capacitance–Cj (pF) f=1 MHz 4 I/O Pin to Gnd 3 2 Between I/O Lines 1 6 5 4 3 Test Waveform Paramters tr=8µs td=20µs 2 1 0 0 0 1 2 3 4 5 Reverse Voltage–VR (V) 0 2 4 6 8 Forward Current–IF(A) 3 10 12 NUP4202W1 ESD Protection Array Outline Drawing – SOT-363 DIMENSIONS PACKAGE OUTLINE SYMBOL E E1 b SEE DETAIL A e1 D 0.2 MIN MAX MIN MAX 0.041 0.049 1.050 1.250 A1 0.000 0.004 0.000 0.100 A2 0.041 0.045 1.050 1.150 D 0.111 0.119 2.820 3.020 E 0.059 0.067 1.500 1.700 E1 0.104 0.116 2.650 2.950 A 0.037(BSC) 0.950(BSC) e1 0.071 0.079 1.800 2.000 L 0.012 0.024 0.300 0.600 θ 0o 8o 0o 8o θ A2 MILLIMETER A e e INCHES c L A1 X Notes THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT DIMENSIONS G C Y P Z YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S DIM INCHES MILLIMETERS Z 0.141 3.60 G 0.055 1.40 P 0.037 0.95 X 0.024 0.60 Y 0.043 1.10 C (0.098) (2.50) 4 MANUFACTURING GUIDELINES ARE MET.
NUP4202W1 价格&库存
很抱歉,暂时无法提供与“NUP4202W1”相匹配的价格&库存,您可以联系我们找货
