DF6A6.8FUT
DF6A6.8FUT
    YENJI(台湾元基)
    SOT363
    ESD抑制器/TVS二极管 VRWM=5V VBR=6.4V SOT363
DF6A6.8FUT 数据手册
DF6A6.8FUT ESD Protection Array Specification Features • • • • • • SOT-363 Package Allows Four Separate Unidirectional Configurations Low Leakage < 1 A @ 5 Volt Breakdown Voltage: 6.4 – 7.2 Volt @ 5 mA Low Capacitance (40 pF typical) ESD Protection Meeting 61000–4–2 Level 4 and 16 kV Human Body Model We declare that the material of product compliance with RoHS requirements. SOT-363 1 6 2 5 3 4 Mechanical Characteristics • • • • Void Free, Transfer–Molded, Thermosetting Plastic Case Corrosion Resistant Finish, Easily Solderable Package Designed for Optimal Automated Board Assembly Small Package Size for High Density Applications MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Rating Symbol Value Unit Peak Power Dissipation @ 8 x 20 s (Note 1) Ppk 75 Watts Steady State Power Dissipation (Note 2) PD 385 mW 328 3.0 °C/W mW/°C Thermal Resistance – Junction to Ambient Derate Above 25°C RJA Maximum Junction Temperature TJmax 150 °C Operating Junction and Storage Temperature Range TJ, Tstg –55 to +150 °C ESD Discharge MIL STD 883C – Method 3015–6 IEC61000–4–2, Air Discharge IEC61000–4–2, Contact Discharge VPP kV 16 16 8 Lead Solder Temperature (10 seconds duration) TL 1. Per Waveform Figure 1 2. Mounted on FR–5 Board = 1.0 X 0.75 X 0.062 in. 1/3 260 °C DF6A6.8FUT ESD Protection Array I IF VBR VRWM V IR VF IT V–I Curve ELECTRICAL CHARACTERISTICS Breakdown Voltage VBR @ 5 mA (Volts) Device DF6A6.8FUT tr 90 Typical Capacitance @ 0 V Bias Max VF @ IF = 10 mA Max ZZ @ 5 mA Max ZZK @ 0.5 mA Min Nom Max (A) (pF) (V) () () 6.4 6.8 7.2 1.0 40 1.25 30 300 4 5 50 PEAK VALUE IRSM @ 8 s TYPICAL CAPACITANCE (pF) 1 MHz FREQUENCY % OF PEAK PULSE CURRENT 100 Leakage Current IRM @ VRWM = 5 V PULSE WIDTH (tP) IS DEFINED AS THAT POINT WHERE THE PEAK CURRENT DECAY = 8 s 80 70 60 HALF VALUE IRSM/2 @ 20 s 50 40 30 tP 20 10 0 40 35 30 25 20 15 10 0 20 40 60 80 0 3 BIAS VOLTAGE (VOLTS) Figure 1. 8 × 20 s Pulse Waveform Figure 2. Capacitance Ipp , PEAK PULSE CURRENT (AMPS) 0.1 0.01 0.001 0.0001 0.6 2 1 t, TIME (s) 1 IF, FORWARD CURRENT (A) 45 0.7 0.8 0.9 1.0 1.1 1.2 10 8 x 20 s per Figure 1 1 8 9 10 11 VF, FORWARD VOLTAGE (VOLTS) VC, CLAMPING VOLTAGE (VOLTS) Figure 3. Forward Voltage Figure 4. Clamping Voltage versus Peak Pulse Current 2/3 12 DF6A6.8FUT ESD Protection Array PACKAGE DIMENSIONS SC–88 (SOT–363) A G V 6 5 4 1 2 3 NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. –B– S D 6 PL 0.2 (0.008) M B DIM A B C D G H J K N S V M N J C K H ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ ÉÉÉ 1.9 mm 3/3 0.65 mm 0.65 mm 0.4 mm (min) 0.5 mm (min) INCHES MIN MAX 0.071 0.087 0.045 0.053 0.031 0.043 0.004 0.012 0.026 BSC --0.004 0.004 0.010 0.004 0.012 0.008 REF 0.079 0.087 0.012 0.016 MILLIMETERS MIN MAX 1.80 2.20 1.15 1.35 0.80 1.10 0.10 0.30 0.65 BSC --0.10 0.10 0.25 0.10 0.30 0.20 REF 2.00 2.20 0.30 0.40
DF6A6.8FUT 价格&库存
很抱歉,暂时无法提供与“DF6A6.8FUT”相匹配的价格&库存,您可以联系我们找货
