SD03
SD03
    YENJI(台湾元基)
    SOD-323
    ESD抑制器/TVS二极管 VRWM=3.3V VC=10V SOD323
SD03 数据手册
SD03 THRU SD24 TVS Diodes Features z z z z z z z z z z Small SOD-323 Package Unidirectional Configurations Peak Power Dissipation 350W @8 x 20 us Pulse Low Leakage Fast Response Time < 1 ns Protects One Power or I/O Port ESD Protection to IEC 61000-4-2 Level 4,15KV(Air), 8KV(Contanct) ESD Protection to IEC 61000-4-2 Level 4, 30A 16KV Human Body Model ESD Requirements RoHS Compliant in Lead-Free Versions Applications z z z z z z Cell Phone Handsets and Accessories Microprocessor Based Equiment Personal Digital Assistant (PDA) Notebooks, Destops, and Servers Portable Instrumentation Pagers Periherals Absolute Maximum Ratings Parameter Symbol Value Units PPK 350 W Air ±15 KV CONTACT ±8.0 KV 30 A VPP 16 KV TSTG -55 to 150 °C TJ -55 to 150 °C Peak Power Dissipation (Note 1.) @TL = 25°C IEC 61000-4-2 (ESD) IEC 61000-4-4 (EFT) ESD Voltage Per Human Body Model Storage Temperature Range Operating Junction Temperature Range 1. 8 X 20 us, non–repetitive 1/3 SD03 THRU SD24 TVS Diodes Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ I PP VRWM Working Peak Reverse Voltage IR Maximum Reverse Leakage Current @ VRWM IT Test Current VBR Breakdown Voltage @ IT IF Forward Current VF Forward Voltage @ IF Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. VRWM (V) IR(uA) VBR (V)@ IT @ V RWM (Note 1) Max Max Min Max SD03 3.3 10 4.0 SD05 5.0 10 SD12 12 SD15 SD24 Device VC (V) VC (V) IPP C@OV 1MHz @ IPP=5 A* @ Max IPP* (A)* (pF) mA Typ Max Max Typ 6.0 1.0 6.5 10.0 30 500 6.2 7.3 1.0 9.8 14.5 20 350 1.0 13.3 15.75 1.0 19 25 15 150 15 1.0 16.7 19.05 1.0 22 28 12 100 24 1.0 26.7 30.15 1.0 42 49 10 70 IT *Surge current waveform per Figure 1. 1. V BR is measured with a pluse test current IT at an ambient temperature of 25℃. Fig1. Pulse Waveform Fig2. Power Derating 2/3 SD03 THRU SD24 TVS Diodes Package Dimensions SOD-323 Dim A A1 Millimeters Inches MIN NOM MAX MIN NOM MAX 0.80 0.00 0.90 0.05 1.00 0.10 0.031 0.000 0.035 0.002 0.040 0.004 A3 0.15 REF 0.006 REF b 0.25 0.32 0.4 0.010 0.012 0.016 C 0.080 0.12 0.177 0.003 0.005 0.007 D E 1.60 1.15 1.70 1.25 1.80 1.40 0.063 0.045 0.066 0.049 0.071 0.055 L 0.08 HE 2.30 0.098 0.106 0.003 2.50 2.70 3/3 0.090
很抱歉,暂时无法提供与“SD03”相匹配的价格&库存,您可以联系我们找货
