RSB6.8S
ESD Protection Diode
RoHS Device
Halogen Free
Features
SOD-523
- Bi-directional ESD protection of one line.
- IEC61000-4-2 Level 4 ESD protection.
- JESD22-A114-B ESD Rating of class 3B per human
body model.
0.051(1.30)
0.043(1.10)
- Low capacitance: 12pF(Typ.)
0.014(0.35)
0.010(0.25)
0.033(0.85)
0.030(0.75)
- Low reverse stand-off voltage: 5.0V
0.067(1.70)
0.059(1.50)
- Low reverse clamping voltage.
- Low leakage current.
0.031(0.77)
0.020(0.51)
- Fast response time
0.006(0.15)
0.003(0.08)
Mechanical data
- Case: SOD-523 standard package ,
molded plastic.
Dimensions in inches and (millimeter)
Circuit Diagram
- Terminals: Tin plated, solderable per
MIL-STD-750,method 2026.
- Mounting position: Any
Maximum Rating (at TA=25°C unless otherwise noted)
Parameter
Conditions
Symbol
IEC 61000-4-2(air)
Value
Unit
±20
ESD capability
IEC 61000-4-2(contact)
±20
(1)
kV
VESD
JESD22-A114-B ESD voltage
per human body model
±16
ESD voltage
Machine model
±0.4
Peak pulse power
TP = 8/20us
PPP
Peak pulse current
TP = 8/20us
IPP
(2)
50
W
(2)
5
A
Lead solder temperature
Maximum(10second duration)
TL
260
°C
Junction temperature range
Tj
-40~+150
°C
Storage temperature range
TSTG
-55~+150
°C
Notes:
(1). Device stressed with ten non-repetitive ESD pulses.
(2). Non-repetitive current pulse 8/20µs exponential decay waveform according to IEC61000-4-5
1
RSB6.8S
Electrical Characteristics (at TA=25°C unless otherwise noted)
Parameter
Symbol
Conditions
Reverse stand off voltage
VRWM
Min
Typ
(1)
Reverse leakage current
VRWM = 5V
Breakdown voltage
IT = 1mA
V(BR)
Clamping voltage
IPP = 5A
VC
Junction capacitance
VR = 0V, f = 1MHz
IR
5.7
(2)
CJ
Unit
Max
5
V
0.1
uA
7.82
V
10
V
pF
12
Notes:
(1). Other voltages available upon request
RATING AND CHARACTERISTIC CURVES (RSB6.8S)
Fig.1 - Reverse Characteristics
Fig.2 - Capacitance Characteristics
15
100
TA=25°C
f=1MHz
Pulsed
TA=100°C
Junction Capacitance, (pF)
Reverse Current, (mA)
75
50
TA=25°C
25
-50
12
9
6
3
-75
-8
-6
-4
-2
6
4
8
Fig.3 - VC — IPP
10
Clamping Voltage, (V)
TA=25°C
f=1MHz
9
8
7
6
5
1
2
3
2
3
4
Reverse Voltage, ( V )
Reverse Voltage, (V)
4
5
Reverse Peak Pulse Current, ( A )
2
5
6
RSB6.8S
Reel Taping Specification
d
P0
P1
E
F
B
A
W
C
P
12
o
D2
D1 D
W1
Trailer
Device
End
Leader
160mm (min)
Start
400mm (min)
Direction of Feed
SOD-523
SOD-523
SYMBOL
A
B
C
d
D
D1
D2
(mm)
0.90 ± 0.05
1.94 ± 0.05
0.73 ± 0.05
1.50 ± 0.10
178 ± 2.00
54.40 ± 1.00
13.00 ± 1.00
(inch)
0.035 ± 0.002
0.076 ± 0.002
0.029 ± 0.002
0.059 ± 0.004
7.008 ± 0.079
2.142 ± 0.039
0.511 ± 0.039
SYMBOL
E
F
P
P0
P1
W
W1
(mm)
1.75 ± 0.10
3.50 ± 0.10
2.00 ± 0.10
4.00 ± 0.10
2.00 ± 0.10
8.00 + 0.30 /–0.10
12.30 ± 1.0
(inch)
0.069 ± 0.004
0.138 ± 0.004
0.157 ± 0.004
0.157 ± 0.004
3
0.079 ± 0.004 0.315 + 0.012 /–0.004 0.484 ± 0.039
RSB6.8S
Suggested PAD Layout
SOD-523
D
A
E
SIZE
(mm)
(inch)
A
1.42
0.055
B
0.60
0.024
C
0.70
0.028
D
2.02
0.079
E
0.82
0.031
C
B
Standard Packaging
REEL PACK
Case Typ e
SOD-523
REEL
Reel Size
( pcs )
(inch)
3, 000
7
4
很抱歉,暂时无法提供与“RSB6.8S”相匹配的价格&库存,您可以联系我们找货
