RCLAMP0522P
RCLAMP0522P
    YENJI(台湾元基)
    SLP1610P4
    TVS二极管 VRWM=5V VC=15V SLP1610P4
RCLAMP0522P 数据手册
RCLAMP0522P TVS Protection Array Features Schematic & PIN Configuration  Solid-state silicon-avalanche technology  Low operating and clamping voltage  4 4 5 6  Up to four I/O Lines of Protection Ultra low capacitance: 0.25pF typical(I/O to I/O)  Low Leakage 3 2 1  Low operating voltage:5V Flow-Through design  SLP1610P4 Mechanical Characteristics Iden tifi caion Pin  SLP1610P4 package 1 ,2 Input lin e  Molding compound flammability rating: UL 5,6 Out pu t Lin es ( No I nte rn al Co nn ection) 3, 4 Groun d 94V-0  Marking: Marking Code  Packaging: Tape and Reel  RoHS Compliant Circuit Diagram Applications  Digital Visual Interface(DVI)  MDDI Ports  Display Port TM Interface  PCI Express  High Definition Multi-Media Interface(HDMI)  HDMI Interfaces Pin 1 Pin 2 Pin 3,4 IEC COMPATIBILITY (EN61000 -4) Line Protection  IEC 61000-4- 2 (ESD) ± 25kV (air), ± 20kV (contact)  IEC 61000-4-4 (EFT) 40A (5/50ns)  IEC 61000 -4-5 (Lightning ) 5A (8/20μs) 1/4 RCLAMP0522P TVS Protection Array Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 100 Watts Peak Pulse Current ( tp =8/20μs ) Ipp 5 A Operating Temperature TJ -55 to + 125 °C TSTG -55 to +150 °C Storage Temperature Electrical Parameters (T=25°C) Symbol I Parameter IPP Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IF Working Peak Reverse Voltage VC VBRVRWM Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IF Forward Current VF Forward Voltage @ IF V IR VF IT IPP Electrical Characteristics Parameter Reverse Stand-Off Voltage Symbol Conditions Minimum Typical Maximum Units 5.0 V VRWM Any I/O pin to ground VBR It = 1mA Any I/O pin to ground Reverse Leakage Current IR VRWM = 5V, T=25°C Any I/O pin to ground 0.5 µA Clamping Voltage Vc Ipp=5A, tp=8/20µs Any I/O pin to ground 15 V Reverse Breakdown Voltage Junction Capacitance Cj 5.6 V VR = 0V, f = 1MHz I/O pin to GND 0.6 0.8 pF VR = 0V, f = 1MHz Between I/O pins 0.25 0.4 pF 2/4 RCLAMP0522P TVS Protection Array Typical Characteristics Non-Repetitive Peak Pulse Power vs. Pulse Time Power Derating curve 110 % of Rated Power or IPP Peak Pulse Power - Ppp (KW) 10 1 100W 8/20µs Waveform 0.1 100 90 80 70 60 50 40 30 20 10 0 0.01 0.1 1 100 10 1000 0 25 Pulse Duration - tp (us) Percent of Ipp 80 Clamping Voltage - Vc(V) 90 e -t 50 40 30 Td=IPP /2 20 10 0 5 10 20 15 25 F=1MHz 1 C ( V R ) / CJ ( V R = 0 ) ) 2 Line to Line Line to Gnd 10 Waveform parameters: tr=8us td=20us 5 0 1 2 3 4 Peak Pulse Current - Ipp (A) Normalized Capacitance vs. Reverse Voltage 0 15 0 30 Time (us) 1.5 1.4 1.3 1.2 1.1 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 150 20 Waveform Parameters: tr=8us td=20us 100 0 125 100 Clamping Voltage vs.Peak Pulse Current 110 60 75 Ambient Temperature - TA ( Pulse Waveform 70 50 3 4 5 Reverse voltage - V R (V) 3/4 5 6 RCLAMP0522P TVS Protection Array Outline Drawing – SLP1610P4 b1 D b b2 L E DIMENSIONS e PIN1 INDICATOR (LASER MARK) e1 1 DIM A A2 A1 b NOTES: CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). MILLIMETERS INCHES MIN MAX MIN MAX D 1.55 1.65 0.061 0.065 E 0.95 1.05 0.037 0.041 L 0.33 0.43 0.013 0.017 b 0.15 0.25 0.006 0.010 b1 0.35 0.45 0.014 0.018 b2 0.25 0.35 0.010 0.014 e e1 A A1 A2 0.50BSC 0.020BSC 1.00BSC 0.45 0.039BSC 0.55 0.15REF 0.00 0.018 0.022 0.006REF 0.05 0.000 0.002 NOTES: DIMENSIONS P1 P Y (C) (Y1) G X DIM INCHES MILLIMETERS C 0.024 0.60 G 0.004 0.10 P 0.020 0.50 P1 0.039 1.0 X 0.012 0.30 Y 0.020 0.50 Y1 0.063 1.60 4/4 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING TO ENSURE YOUR COMPANYS MANNUFACTURING GUIDELINES ARE MET.
RCLAMP0522P 价格&库存
很抱歉,暂时无法提供与“RCLAMP0522P”相匹配的价格&库存,您可以联系我们找货
RCLAMP0522P
  • 1+0.42000
  • 30+0.40500
  • 100+0.39000
  • 500+0.36000
  • 1000+0.34500
  • 2000+0.33600
库存:1146
