P4SMA6.8CA
P4SMA6.8CA
    YENJI(台湾元基)
    SMA(DO-214AC)
    SMA SMT 5.8V 10.5V
P4SMA6.8CA 数据手册
P4SMA Series Transient Voltage Suppressors Description The P4SMA series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features t)BMPHFO'SFF t 3P)4DPNQMJBOU t '  PSTVSGBDFNPVOUFE applications to optimize board space t -PXQSPmMFQBDLBHF t #VJMUJOTUSBJOSFMJFG t 5ZQJDBMNBYJNVN temperature coefficient t 'BTUSFTQPOTFUJNF typically less than 1.0ps from 0V to BV min t &YDFMMFOUDMBNQJOH capability t -PXJODSFNFOUBMTVSHF resistance t 5ZQJDBM*R less than 1μA above 12V t )JHI5FNQFSBUVSF soldering guaranteed: 260°C/40 seconds at terminals t 1MBTUJDQBDLBHFIBT Underwriters Laboratory Flammability 94V-O t .BUUF5JO-FBEoGSFF1MBUFE ΔVBR = 0.1% x VBR@25°C x ΔT t (MBTTQBTTJWBUFEDIJQ junction t 8QFBLQVMTFQPXFS capability at 10×1000μs waveform, repetition rate (duty cycles):0.01% Maximum Ratings and Thermal Characteristics (TA =25OC unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power Dissipation at TA=25ºC by 10x1000μs waveform (Fig.1)(Note 1), (Note 2) PPPM 400 W Power Dissipation on infinite heat sink at TA=50OC PM(AV) 3.3 W 40 A 3.5V/6.5 V -65 to 150 °C Peak Forward Surge Current, 8.3ms IFSM Single Half Sine Wave (Note 3) Maximum Instantaneous Forward Voltage at 25A for Unidirectional VF only (Note 4) Operating Junction and Storage TJ , TSTG Temperature Range SMA(DO-214AC) Typical Thermal Resistance Junction to Lead R uJL 30 °C/W Typical Thermal Resistance Junction to Ambient R uJA 120 °C/W Notes: 1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25OC per Fig. 2 . 2. Mounted on 0.2x0.2” (5.0 x 5.0mm) copper pad to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. 4. V F
P4SMA6.8CA 价格&库存
很抱歉,暂时无法提供与“P4SMA6.8CA”相匹配的价格&库存,您可以联系我们找货
