SS12 THRU SS110
Surface Mount Schottky Barrier Rectifiers
Reverse Voltage - 20 to 100 V
Forward Current - 1 A
PINNING
PIN
Features
• Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
• For surface mounted applications
• Metal silicon junction, majority carrier conduction
• Built-in strain relief, ideal for automated placement
• Low power loss, high efficiency.
• High forward surge current capability
1
DESCRIPTION
Cathode
2
Anode
1
2
Top view
Plastic Package : SMA(DO-214AC)
Mechanical Data
• Case: SMA (DO-214AC) molded plastic body
• Terminals: leads solderable per MIL-STD-750,
Method 2026
• Polarity: color band denotes cathode end
Maximum Ratings and Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, resistive or inductive load, for
capacitive load, derate by 20 %
Symbols SS12 SS13 SS14 SS15 SS16 SS18 SS110 Unit
Parameter
Marking
Maximum Repetitive Peak Reverse Voltage
VRRM
40
50
60
80
100
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
V
Maximum DC Blocking Voltage
VDC
40
50
60
80
100
V
Maximum Average Forward Rectified Current
IF(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine-wave Superimposed on Rated Load
(JEDEC Method)
IFSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
Maximum DC Reverse Current
Ta = 25℃
at Rated DC Blocking Voltage
Ta = 100℃
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
Operating Junction Temperature Range
Storage Temperature Range
1)
Measured at 1MHz and applied reverse voltage of 4 V D.C.
2)
P.C.B. mounted with 2" X 2" (5 X 5 cm) copper pad areas.
0.55
0.75
0.5
IR
0.85
V
mA
Cj
110
pF
RθJA
90
℃/W
Tj
- 55 to + 125
Tstg
- 55 to + 150
1/3
Dated:28/10/2020 JD Rev:03
SS12 THRU SS110
Electrical characteristic curves
2/3
SS12 THRU SS110
Package Outline Dimensions in inches (millimeters)
SMA(DO-214AC)
Marking information
" **** " = Part No.
" III " = Cathode line
Font type: Arial
3/3
很抱歉,暂时无法提供与“SS14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.14790
- 50+0.13485
- 500+0.12180
- 1000+0.10875
- 2500+0.10266
- 5000+0.09744
- 国内价格
- 10+0.35262
- 100+0.28264
- 300+0.24765
