NSI8100N
NSI8100N
    NOVOSENSE(纳芯微)
    SOIC-8
    High Reliability Bidirectional I2C Isolators
NSI8100N 数据手册
NSi8100/NSi8101: High Reliability Bidire ctional I2C Isolators NOVOSENSE Datasheet (EN) 1.6 Safety Regulatory Approvals (pending) Product Overview The NSi810x devices are high reliability bidirectional isolators that are compatible with I2C interface. The NSi810x devices are AECQ100 qualified. The NSi810x devices are safety certified by UL1577 support several insulation withstand voltages (3.75kVrms, 5kVrms), while providing high electromagnetic immunity and low emissions at low power consumption. The I2C clock of the NSi810x is up to 2MHz, and the common-mode transient immunity (CMTI) is up to 150kV/us. Wide supply voltage of the NSi810x device support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. Key Features  Up to 5000VRMS Insulation voltage  I C Clock rate: up to 2MHz     Power supply voltage: 2.5V to 5.5V AEC-Q100 Grade 1 qualified Suitable for hot swap applications High CMTI: 150kV/us  Chip level ESD: HBM: ±6kV       UL recognition: up to 5000VRMS for 1 minute per UL1577 CQC certification per GB4943.1-2011  CSA component notice 5A approval IEC60950-1 standard  DIN V VDE V 0884-10(VDE V 0884-10): 2006-12 Applications  Power over Ethernet  Isolated I2C, SMBus, or PMBus interface  I2C level shifting  Battery Management Functional Block Diagrams 2 8 VDD2 VDD1 1 8 VDD2 7 SDA2 SDA1 2 7 SDA2 SCL1 3 6 SCL2 SCL1 3 6 SCL2 GND1 4 5 GND2 GND1 4 NSi8100N GND1 1 NC 2 High system level EMC performance: Enhanced system level ESD, EFT, Surge immunity Isolation Barrier Life: >60 years Operation temperature: -40℃~125℃ RoHS-compliant packages: SOIC-8 narrow body SOIC-16 wide body VDD1 1 SDA1 2 16 GND2 GND11 16 GND2 15 NC NC 2 15 NC 14 VDD2 VDD1 3 13 NC NC 4 5 GND2 NSi8101N 14 VDD2 VDD1 3 13 NC NC 4 SDA1 5 12 SDA2 SDA1 5 12 SDA2 SCL1 6 11 SCL2 SCL1 6 11 SCL2 GND1 7 NC 8 NSi8100W 10 NC GND17 9 NC 8 GND2 10 NC 9 NSi8101W Figure1. NSi810x Functional Block Diagram Novosense Confidential Page 1 GND2 NSi8100/NSi8101 Index 1.0 ABSOLUTE MAXIMUM RATINGS .............................................................................................................................. 3 2.0 SPECIFICATIONS ........................................................................................................................................................... 3 2.1. 2.2. 2.3. 3.0 3.1. 3.2. 3.3. ELECTRICAL CHARACTERISTICS........................................................................................................................................ 3 TYPICAL PERFORMANCE CHARACTERISTICS............................................................................................................. 7 PARAMETER MEASUREMENT INFORMATION ..................................................................................................................... 8 HIGH VOLTAGE FEATURE DESCRIPTION .............................................................................................................. 8 INSULATION AND SAFETY RELATED SPECIFICATIONS ......................................................................................................... 8 DIN VDE V 0884-10 (VDE V 0884-10) INSULATION CHARATERISTICS ............................................................................... 9 REGULATORY INFORMATION ........................................................................................................................................... 10 4.0 FUNCTION DESCRIPTION ..........................................................................................................................................11 5.0 APPLICATION NOTE ................................................................................................................................................... 12 5.1. PCB LAYOUT ................................................................................................................................................................. 12 6.0 PACKAGE INFORMATION ......................................................................................................................................... 13 7.0 ORDER INFORMATION .............................................................................................................................................. 15 8.0 REVISION HISTORY .................................................................................................................................................... 15 Novosense Confidential Page 2 NSi8100/NSi8101 1.0 ABSOLUTE MAXIMUM RATINGS Parameters Symbol Min Power Supply Voltage VDD1, VDD2 -0.5 6.5 V Maximum Input Voltage SDA1, SDA2, SCL1, SCL2 -0.4 VDD+0.41 V Maximum Input Pulse Voltage SDA1, SDA2, SCL1, SCL2 -0.8 VDD+0.8 V Common-Mode Transients CMTI Output current Io Typ Max ±150 -15 Comments Pulse width should be less than 100ns, and the duty cycle should be less than 10% kV/us 15 mA 5.3 kV Maximum Surge Isolation Voltage VIOSM Operating Temperature Topr -40 125 ℃ Storage Temperature Tstg -40 150 ℃ HBM ±6000 V CDM ±2000 V Electrostatic discharge 1 Unit The maximum voltage must not exceed 6.5V. 2.0 SPECIFICATIONS 2.1. ELECTRICAL CHARACTERISTICS (VDD1=2.5V~5.5V, VDD2=2.5V~5.5V, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 5V, Ta = 25℃) Parameters Symbol Power on Reset VDDPOR Min Typ Max Unit Comments 2.2 V POR threshold as during power-up VDD HYS 0.1 V POR threshold Hysteresis Start Up Time after POR trbs 40 usec Common Mode Transient Immunity CMTI ±100 VILT1 400 ±150 kV/us Side 1 Logic Level Input Threshold VIHT1 mV 600 mV Novosense Confidential Page 3 Input Threshold at rising edge NSi8100/NSi8101 VIT_HYS1 100 Low Level Output Voltage VOL1 650 Low-level output voltage to high-level input voltage threshold difference ΔVOIT1 70 800 mV Input Threshold Hysteresis mV IOL ≤ 4mA mV Side 2 Logic Level Input Threshold VILT2 1.6 V Input Threshold at rising edge VIT_HYS2 0.4 V Input Threshold Hysteresis High Level Input Voltage VIH2 2.0 V Low Level Input Voltage VIL2 0.8 V Low Level Output Voltage VOL 0.5 V IOL ≤ 30mA (VDD1=5V±10%, VDD2=5V±10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 5V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments IDD1(Q0) 5.10 7.5 mA All Input 0V IDD2(Q0) 3.96 5.7 mA IDD1(Q1) 2.52 3.6 mA IDD2(Q1) 1.78 2.5 mA IDD1(2M) 3.83 5.7 mA All Input with 2MHz, IDD2(2M) 2.78 4.2 mA CL=15pF IDD1(Q0) 2.85 4.2 mA All Input 0V IDD2(Q0) 2.66 4 mA IDD1(Q1) 2.42 3.6 mA IDD2(Q1) 1.57 2.4 mA IDD1(2M) 2.89 4.3 mA All Input with 2MHz, IDD2(2M) 2.64 4 mA CL=15pF 2 MHz NSi8100 All Input at supply Supply current NSi8101 Clock rate Propagation Delay DR t PLH12 0 24.8 37.2 ns All Input at supply See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD Novosense Confidential Page 4 NSi8100/NSi8101 t PHL12 32.8 49.2 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD t PLH21 24 36 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD t PHL21 38 57 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD Pulse Width Distortion Falling Time PWD12 8 12 ns |t PHL12 – t PLH12 | PWD21 14 21 ns |t PHL21 – t PLH21 | tf1 10.6 15.9 ns CL = 30pF tf2 22.8 34.2 ns CL = 300pF (VDD1=3.3V±10%, VDD2=3.3V±10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 3.3V, VDD2 = 3.3V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments IDD1(Q0) 4.96 7.4 mA All Input 0V IDD2(Q0) 3.85 5.6 mA IDD1(Q1) 2.40 3.5 mA IDD2(Q1) 1.68 2.4 mA IDD1(2M) 3.69 5.6 mA All Input with 2MHz, IDD2(2M) 2.67 4.2 mA CL=15pF IDD1(Q0) 2.79 4.2 mA All Input 0V IDD2(Q0) 2.58 3.9 mA IDD1(Q1) 2.60 3.9 mA IDD2(Q1) 1.50 2.3 mA IDD1(2M) 2.65 4 mA All Input with 2MHz, IDD2(2M) 2.40 3.6 mA CL=15pF 2 MHz NSi8100 All Input at supply Supply current NSi8101 Clock rate Propagation Delay DR t PLH12 0 29 43.5 ns All Input at supply See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD Novosense Confidential Page 5 NSi8100/NSi8101 t PHL12 39.8 59.7 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD t PLH21 30 45 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD t PHL21 61 91.5 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD Pulse Width Distortion Falling Time PWD12 10.8 16.2 ns |t PHL12 – t PLH12 | PWD21 31 46.5 ns |t PHL21 – t PLH21 | tf1 15.6 23.4 ns CL = 30pF tf2 32 48 ns CL = 300pF (VDD1=2.5V±10%, VDD2=2.5V±10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 2.5V, VDD2 = 2.5V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments IDD1(Q0) 4.89 7.3 mA All Input 0V IDD2(Q0) 3.79 5.5 mA IDD1(Q1) 2.34 3.4 mA IDD2(Q1) 1.63 2.3 mA IDD1(2M) 3.61 5.4 mA All Input with 2MHz, IDD2(2M) 2.59 4 mA CL=15pF IDD1(Q0) 2.75 4 mA All Input 0V IDD2(Q0) 2.54 3.8 mA IDD1(Q1) 2.57 3.9 mA IDD2(Q1) 1.47 2.2 mA IDD1(2M) 2.57 3.9 mA All Input with 2MHz, IDD2(2M) 2.29 3.5 mA CL=15pF 2 MHz NSi8100 All Input at supply Supply current NSi8101 Clock rate Propagation Delay DR t PLH12 0 33 49.5 ns All Input at supply See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD Novosense Confidential Page 6 NSi8100/NSi8101 t PHL12 52 78 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD t PLH21 47 70.5 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD t PHL21 100 150 ns See figure 2.6, R1=1500Ω,R2=500Ω, NO LOAD Pulse Width Distortion PWD12 19 28.5 ns |t PHL12 – t PLH12 | PWD21 53 79.5 ns |t PHL21 – t PLH21 | tf1 22 33 ns CL = 30pF tf2 36 54 ns CL = 300pF Falling Time Tplh1 40 30 20 2.5 3.3 5 10 0 -40 25 Tphl1 100 Propagation Delay(ns) Propagation Delay(ns) 2.2. TYPICAL PERFORMANCE CHARACTERISTICS 125 50 2.5 3.3 5 0 150 -40 Temperature(°C) Propagation Delay(ns) Propagation Delay(ns) 40 2.5 3.3 5 0 -40 25 125 150 Figure 2.2 Falling Edge Propagation Delay Vs Temp Tplh2 20 125 Temperature(°C) Figure 2.1 Rising Edge Propagation Delay Vs Temp 60 25 150 Tphl2 150 100 2.5 3.3 5 50 0 -40 Temperature(°C) 25 125 150 Temperature(°C) Figure 2.3 Rising Edge Propagation Delay Vs Temp Figure 2.4 Falling Edge Propagation Delay Vs Temp Novosense Confidential Page 7 NSi8100/NSi8101 Tf1 30 20 2.5 3.3 5 10 0 -40 25 Tf2 60 Falling time(ns) Falling time(ns) 40 40 2.5 3.3 5 20 0 125 150 -40 25 Temperature(°C) 125 Temperature(°C) Figure 2.5 falling time(@27pF) Vs Temp Figure 2.6 Falling time(@300pF) Vs Temp 2.3. PARAMETER MEASUREMENT INFORMATION VDD2 VDD1 Input Generator SDA1 or SCL1 SDA2 or SCL2 CL2 CL1 Figure 2.6 Switching Characteristic Test Circuit and Voltage Waveforms VDD1 VDD2 IN OUT Battery VO DC CL GND2 GND1 VCM Figure 2.7 Common-Mode Transient Immunity Test Circuit 3.0 HIGH VOLTAGE FEATURE DESCRIPTION 3.1. INSULATION AND SAFETY RELATED SPECIFICATIONS Parameters Symbol Value Novosense Confidential Page 8 Unit Comments 150 NSi8100/NSi8101 SOIC-8 SOIC-16 Minimum External Air Gap (Clearance) L(I01) 4.0 7.8 mm Shortest terminal-to-terminal distance through air Minimum External Tracking (Creepage) L(I02) 4.0 7.8 mm Shortest terminal-to-terminal distance across the package surface Minimum internal gap DTI 20 um Distance through insulation Tracking Resistance(Comparative Tracking Index) CTI >600 V DIN EN 60112 (VDE 0303-11); IEC 60112 Ⅰ Material Group 3.2. DIN VDE V 0884-10 (VDE V 0884-10) INSULATION CHARATERISTICS Description Test Condition Symbol Value SOIC-8 SOIC-16 For Rated Mains Voltage ≤ 150Vrms Ⅰto Ⅳ Ⅰto Ⅳ For Rated Mains Voltage ≤ 300Vrms Ⅰto Ⅲ Ⅰto Ⅳ For Rated Mains Voltage ≤ 400Vrms Ⅰto Ⅲ Ⅰto Ⅳ Unit Installation Classification per DIN VDE 0110 Climatic Classification 10/105/21 Pollution Degree per DIN VDE 0110, Table 1 2 Maximum repetitive isolation voltage Input to Output Test Voltage, Method B1 V IORM × 1. 5 = V pd (m) , 100% production test, 10/105/21 2 VIORM 565 800 Vpeak V pd (m) 847 1200 Vpeak t ini = t m = 1 sec, partial discharge < 5 pC Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 V IORM × 1.2 = V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC V pd (m) 678 960 Vpeak After Input and /or Safety Test Subgroup 2 and Subgroup 3 V IORM × 1.2= V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC V pd (m) 678 960 Vpeak t = 60 sec VIOTM 5300 7000 Vpeak Test method per IEC60065,1.2/50us waveform, VTEST=1.6 ×VIOSM VIOSM 5384 5384 Vpeak VIO =500V RIO >109 >109 Ω Maximum transient isolation voltage Maximum Surge Isolation Voltage Isolation resistance Novosense Confidential Page 9 NSi8100/NSi8101 Isolation capacitance f = 1MHz CIO 0.6 Input capacitance CI 2 Total Power Dissipation at 25℃ Ps θJA = 140 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C Safety input, output, or supply current pF 2 pF 1499 mW mA 160 Is θJA = 84 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C Case Temperature Ts Saftey Limiting Current (mA) 0.6 150 237 mA 150 ℃ 180 160 140 120 100 80 60 40 20 0 0 50 100 150 200 Case Temperature (℃) Saftey Limiting Current (mA) Figure 3.1 NSi8100N/NSi8101N Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN V VDE V 0884-10 250 200 150 100 50 0 0 50 100 150 200 Case Temperature (℃) Figure 3.2 NSi8100W/NSi8101W Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN V VDE V 0884-10 3.3. REGULATORY INFORMATION The NSi8100N/NSi8101N are approved or pending approval by the organizations listed in table. UL UL 1577 Component Recognition Program1 CSA Approved under CSA Component Acceptance Notice 5A VDE DIN V VDE V088410 (VDE V 0884- Novosense Confidential Page 10 CQC Certified by CQC11471543-2012 NSi8100/NSi8101 Single Protection, 3750Vrms Isolation voltage IEC60950-1 10):2006-122 400VRMS basic insulation working voltage Basic Insulation 565Vpeak, VIOSM=6000Vpeak File (pending) File (pending) File (E500602) 1 GB4943.1-2011 Basic insulation at 400VRMS (565Vpeak) File (pending) In accordance with UL 1577, each NSi8100N/NSi8101N is proof tested by applying an insulation test voltage ≥ 4500 V rms for 1 sec. 2 In accordance with DIN V VDE V 0884-10, each NSi8100N/NSi8101N is proof tested by applying an insulation test voltage ≥ 1059 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN V VDE V 0884-10 approval. The NSi8100W/NSi8101W are approved or pending approval by the organizations listed in table. UL CSA UL 1577 Component Recognition Program Approved under CSA Component Acceptance Notice 5A VDE DIN V VDE V088410 (VDE V 088410):2006-12 CQC Certified by CQC11471543-2012 GB4943.1-2011 IEC60950-1 Single Protection, 5000Vrms Isolation voltage 800VRMS basic insulation working voltage 400VRMS Reinforced insulation working voltage File (pending) 1 File (pending) Basic Insulation 800Vpeak, VIOSM=5384Vpeak File (pending) Basic insulation at 800VRMS (1131Vpeak) Reinforced insulation at 400VRMS (565Vpeak) File (pending) In accordance with UL 1577, each NSi8100W/NSi8101W is proof tested by applying an insulation test voltage ≥ 6000 V rms for 1 sec. 2 In accordance with DIN V VDE V 0884-10, each NSi8100W/NSi8101W is proof tested by applying an insulation test voltage ≥ 1592 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN V VDE V 0884-10 approval. 4.0 FUNCTION DESCRIPTION The NSi810x is a bidirectional isolator based on a capacitive isolation barrier technique. The NSi810x devices are compatible with I2C interface. Internally, the I2C interface is split into two unidirectional channels communicating in opposing directions via a dedicate capacitive isolation channel for each. The digital signal is modulated with RF carrier generated by the internal oscillator at the Transmitter side. Then it is transferred through the capacitive isolation barrier and demodulated at the Receiver side. The NSi8100 devices are high reliability dual-channel bidirectional isolators for clock and data lines while NSi8101 has a bidirectional data and a unidirectional clock channel. The NSi8100 is suitable for multi-master application while NSi8101 is useful in a single master application. The Side 2 logic levels of NSi810x are standard I2C value, and the maximum load for side 2 is ≤ 400pF. So multiple NSi810x devices connected to a bus by their Side 2 pins can communicate with each other and with other I 2C compatible devices. The Side 1 logic levels of NSi810x are not standard value. The output low level of NSi810x is 650mV, while low-level output voltage to high-level input voltage threshold is 50mV. This prevents an output logic low at Side 1 being transmitted back to Side 2 and pulling down the I2C bus. The NSi810x devices are AEC-Q100 qualified. The NSi810x device is safety certified by UL1577 support several insulation withstand voltages (3.75kVrms, 5kVrms), while providing high electromagnetic immunity and low emissions at low power consumption. The I2C clock of the NSi810x is up to 2MHz, and the common-mode transient immunity (CMTI) is up to 150kV/us. Wide supply voltage of the NSi810x device support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. The Table 4.1 shows the functional of NSi810x.The NSi810x is high impedance output when VDDIN is unready and VDDOUT is ready as shown in. Table 4.1 Output status vs. power status Input VDD1 VDD2 Output Comment Novosense Confidential Page 11 NSi8100/NSi8101 status status H Ready Ready Z L Ready Ready L X Unready Ready Z The output follows the same status with the input within 60us after input side VDD1 is powered on. X Ready Unready X The output follows the same status with the input within 60us after output side VDD2 is powered on. Normal operation. 5.0 APPLICATION NOTE 5.1. PCB LAYOUT The NSi810x requires a 0.1 µF bypass capacitor between VDD1 and GND1, VDD2 and GND2. The capacitor should be placed as close as possible to the package. Figure 5.1 to Figure 5.4 show the recommended PCB layout, make sure the space under the chip should keep free from planes, traces, pads and via. The pull-up resistors required for both Side 1 and Side 2 buses. And the value of the resistors depend on the number of I2C devices on the bus. Figure5.1 Recommended PCB Layout — Top Layer Figure5.2 Recommended PCB Layout — Bottom Layer Figure5.3 Recommended PCB Layout — Top Layer Figure5.4 Recommended PCB Layout — Bottom Layer Novosense Confidential Page 12 NSi8100/NSi8101 6.0 PACKAGE INFORMATION VDD1 1 8 VDD2 VDD1 1 8 VDD2 SDA1 2 7 SDA2 SDA1 2 7 SDA2 SCL1 3 6 SCL2 SCL1 3 6 SCL2 GND1 4 5 GND2 GND1 4 5 GND2 NSi8100N NSi8101N Figure 6.1 NSi8100N/NSi8101N Package Figure 6.3 SOIC8 Package Shape and Dimension Dimensions shown in millimeters and (inches) Table6.1 NSi8100N/ NSi8101N Pin Configuration and Description NSi8100N PIN NO. NSi8101N PIN NO. SYMBOL FUNCTION 1 1 VDD1 Power Supply for Isolator Side 1 2 2 SDA1 Serial data input /output, Side 1 3 3 SCL1 Serial clock input /output, Side 1 4 4 GND1 Ground 1, the ground reference for Isolator Side 1 5 5 GND2 Ground 2, the ground reference for Isolator Side 2 6 6 SCL2 Serial clock input /output, Side 2 7 7 SDA2 Serial data input /output, Side 2 8 8 VDD2 Power Supply for Isolator Side 2 Novosense Confidential Page 13 NSi8100/NSi8101 GND1 1 NC 2 16 GND2 GND11 16 GND2 15 NC NC 2 15 NC 14 VDD2 VDD1 3 13 NC NC 4 14 VDD2 VDD1 3 13 NC NC 4 SDA1 5 12 SDA2 SDA1 5 12 SDA2 SCL1 6 11 SCL2 SCL1 6 11 SCL2 GND1 7 NC 8 10 NC GND17 10 NC 9 NC 8 9 GND2 NSi8100W NSi8101W Figure 6.2 NSi8100W/ NSi8101W Package Figure 6.6 SOIC16 Package Shape and Dimension Dimensions shown in millimeters and (inches) Table6.2 NSi8100W/ NSi8101W Pin Configuration and Description NSi8100W PIN NO. NSi8101W PIN NO. SYMBOL FUNCTION 1 1 GND1 Ground 1, the ground reference for Isolator Side 1 2 2 NC No Connection. 3 3 VDD1 Power Supply for Isolator Side 1 4 4 NC No Connection. 5 5 SDA1 Serial data input /output, Side 1 6 6 SCL1 Serial clock input /output, Side 1 7 7 GND1 Ground 1, the ground reference for Isolator Side 1 Novosense Confidential Page 14 GND2 NSi8100/NSi8101 8 8 NC No Connection. 9 9 GND2 Ground 2, the ground reference for Isolator Side 2 10 10 NC No Connection. 11 11 SCL2 Serial clock input /output, Side 1 12 12 SDA2 Serial data input /output, Side 1 13 13 NC No Connection. 14 14 VDD2 Power Supply for Isolator Side 2 15 15 NC No Connection. 16 16 GND2 Ground 2, the ground reference for Isolator Side 2 7.0 ORDER INFORMATION Part No. Isolation Rating(kV) Number Number Max Clock Temperature Automotive Package of side 1 of side 2 Rate (MHz) inputs inputs NSi8100N 3.75 2 2 2 NO SOIC8 -40 to 125℃ NSi8100NQ 3.75 2 2 2 YES SOIC8 -40 to 125℃ NSi8101N 3.75 2 1 2 NO SOIC8 -40 to 125℃ NSi8101NQ 3.75 2 1 2 YES SOIC8 -40 to 125℃ NSi8100W 5 2 2 2 NO WB SOIC16 -40 to 125℃ NSi8101W 5 2 1 2 NO WB SOIC16 -40 to 125℃ NOTE: All packages are RoHS-compliant with peak reflow temperatures of 260 °C according to the JEDEC industry standard classifications and peak solder temperatures. All devices are AEC-Q100 qualified. 8.0 REVISION HISTORY Revision 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Description Original Change to Ordering information Add maximum operation current specification. Change block diagram Change “Start Up Time after POR” specification to 40us Add “Maximum Input Pulse Voltage” Change to Ordering information Novosense Confidential Page 15 Date 2017/11/15 2018/3/26 2018/6/20 2018/7/28 2018/8/25 2018/10/9 2018/12/20
NSI8100N 价格&库存
很抱歉,暂时无法提供与“NSI8100N”相匹配的价格&库存,您可以联系我们找货
NSI8100N
  • 1+10.21680
  • 10+8.31600
  • 30+7.25760
  • 100+6.08040
  • 500+5.55120
  • 1000+5.31360
库存:999
NSI8100N
    库存:15726
    NSI8100N
    • 1+9.36540
    • 10+7.62300
    • 500+5.08860
    • 1000+4.87080
    • 2500+4.82209
    库存:1215
    NSI8100N
    • 1+4.07000
    • 100+3.38800
    • 1250+3.08000
    • 2500+2.94800
    库存:4322
