PJ78L10SQ
PJ78L10SQ
    PJ(平晶)
    SOT89-3
    输出类型:固定 输出极性:正 输出通道数:1 最大输入电压:30V 输出电压:10V
PJ78L10SQ 数据手册
PJ78L10SQ 3-Terminal Voltage Regulator Features SOT-89  Input voltage:up to 30V  Output:10V  Output current up to 100 mA, internal thermal overload protection and short-circuit current limiting. 1. OUT 2. GND 3. IN Marking Code : 78L10 Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Input Voltage VI 30 V Output Current IO 100 mA Maximum Power Dissipation PD 500 mW Junction Temperature TJ 150 °C Operating Temperature Range TOPR -40 to +125 °C Storage Temperature Range TSTG -55 to +150 °C Vi C1 0.33 µF www.pingjingsemi.com Revision:2.0 Aug-2021 3 PJ78L10SQ 2 Vo 1 C2 0.1 µF 1/3 PJ78L10SQ 3-Terminal Voltage Regulator Electrical Characteristics VI=17V, IO=40mA,0℃≤ TJ≤125℃, CI=0.33μF,CO=0.1μF,unless otherwise specified. Parameter Output Voltage Symbol VO Line Regulation △VO Load Regulation △VO Ripple Rejection RR Dropout Voltage VD Quiescent Current IQ Quiescent Current Change Output Noise Voltage www.pingjingsemi.com Revision:2.0 Aug-2021 △IQ VN Test Conditions Min. Typ. Max. Unit TJ=25°C 9.6 10 10.4 V 9.5 10 10.5 V IO=1mA to 70mA 9.5 10 10.5 V VI=13V to 25V, TJ=25°C -- -- 175 mV VI=14V to 25V, TJ=25°C -- -- 125 mV IO=1mA to 100mA ,TJ=25°C -- -- 90 mV IO=1mA to 40 mA, TJ=25°C -- -- 40 mV 37 44 -- dB -- 1.7 -- V -- -- 6 mA VI=14V to 25V -- -- 1.5 mA IO=1mA to 40mA -- -- 0.1 mA 10Hz≤f≤100Hz -- 62 -- μV IO=1mA to 40mA, VI=13V to 25V VI=9V to 19V, f=120Hz, TJ=25°C TJ=25°C 2/3 PJ78L10SQ 3-Terminal Voltage Regulator Package Outline SOT-89 Dimensions in mm Ordering Information Device Package Shipping PJ78L10SQ SOT-89 3,000PCS/Reel&13inches www.pingjingsemi.com Revision:2.0 Aug-2021 3/3
PJ78L10SQ 价格&库存
很抱歉,暂时无法提供与“PJ78L10SQ”相匹配的价格&库存,您可以联系我们找货
PJ78L10SQ
  • 10+0.43308
  • 100+0.34236
  • 300+0.29700
库存:179
