AH1G.104
AH1G.104
    ANTENNAHOME(德诺菲)
    Antenna
    50Ω VSWR:2.5 增益:1.5dBi -40~+85℃天线
AH1G.104 数据手册
AntennaHome 产 品/Product : 料 号/PN : - Antenna and Solutions Supplier H50 Rubber SMA-JW ,868/915M, GSM900/1800M Antenna AH1G.104 应 用/Application : LoRa 868/915M ,GSM/GPRS 900/1800M, NB-NoT 900/1800M ,ISM Transfer /Recciever ; 电气参数(Electrical Properties) 频率/Frequency: 868/915 MHz,900/1800MHz 输入阻抗/Impedance: 50Ω 驻波比/VSWR: ≤2.5 增益/Gain: 1.5 dBi 极化方式/Polarization: Vertical / Omni 机械参数(Mechanical Properties) 接头&线缆/Conn&Cable: SMA-JW 材料&颜色/Material&Color: Copper / ABS 安装方式/Mounting: SMA connector 尺寸/Size: ¢8×H48 mm 重量/Weight: 5.7 g/pcs 工作温度/Operate Temp: -40 ~ +85 ℃ AntennaHome - Antenna and Solutions Supplier 关联产品/Relation Product SMA-K DIP (AHCG.202) SMA-K ASSY (AHCG.101) H175 Rubber Magnetic (AH1G.401) H200 FiberGlass (AH1G.501) 产品手册/ Product Catalogue 免费样品申请 Ask free sample 下载地址/Download Link: http://docs.AntennaHome.com/ant/catalogue.pdf Online Support Contact Us E-mail : CS@AntennaHome.com Website : Http://www.AntennaHome.com
AH1G.104 价格&库存
很抱歉,暂时无法提供与“AH1G.104”相匹配的价格&库存,您可以联系我们找货
AH1G.104
  • 1+4.62000
  • 10+4.41000
库存:10
