SS12-110 SERIES
SCHOTTKY
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
ROHS
FEATURES
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250℃/10 seconds at terminals
The plastic material carries U/L recognition 94V-O
MECHANICAL DATA
Case: JEDEC DO -214AC. molded plastic
Terminals: Axial leads. Solderable per MIL - STD - 750
Method 2026
Polarity: Color band denotes cathode
Weight: 0.003 ounce. 0.093 grams
Mounting position: Any
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ℃ ambient temperature unless otherwise specified.
Single phase half wave 60HZ. resistive or inductive load. For capacitive load current derate by 20%
SYMBOL
SS12
SS13
SS14
SS15
SS16
SS18
SS110
UNITS
Maximum Recurrent Peak Reverse Voltage
VRRM
40
50
60
80
100
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
V
Maximum DC Blocking Voltage
VDC
40
50
60
80
100
V
Maximum Average Forward Rectified Current
9.5mm Lead Length. TA = 75℃
I(AV)
1.0
A
IFSM
40.0
A
Peak Forward Surge Current
8.3ms Single half-sine-wave superimposed
on rated Tj = 125℃
Maximum Forward Voltage at 1.0A DC
Maximum Reverse Current
TA = 25℃
at Rated DC Blocking Voltage TA = 100℃
VF
Cj
Typical Thermal Resistance ( Note 2 )
RQJA
Operating Junction Temperature Range
Tj
0.70
0.85
0.5
IR
Typical Junction Capacitance ( Note 1 )
Storage Temperature Range
0.55
0.45
6.0
5.0
110
90
mA
pF
℃/W
88.0
65 to 125
TSTG
65 to 150
65 to 150
NOTE:
1. Measured at 1.0MHz and applied reverse voltage of 4.0V DC.
2. P.C.B.mounted with 0.2×0.2 (5.0×5.0mm)copper pad areas
Rev 8: Nov 2014
www.born-tw.com
V
Page 1 of 2
SS12-110 SERIES
SCHOTTKY
SMA Plastic-Encapsulate
SURFACE
MOUNT SCHOTTKY
Schottky
BARRIER
BarrierRECTIFIERS
Diode
ROHS
Forward Current: 1.0Ampere
Reverse Voltage:20 to 100 Volts
FIG.1-TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
FIG.2-TYPICAL JUNCTION CHARACTERISTICS
1000
10
JUNCTION CAPACITANCE, p F
pulse width=300μS
TJ=25℃
SS12-SS14
1.0
AMPERES
INSTANTANEOUS FORWARD CURRENT,
50
SS15-SS16
SS18-SS110
0.1
300
Tj = 25 ℃
f = 1.0 MHZ
SS12-SS14
100
30.0
0.01
SS15-SS110
10.0
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.0
4.0
INTANTANEOUS FORWARD VOLEAGE,
10
100
REVERSE VOLTAGE, VOLTS
VOLTS
FIG.3-FORWARD CURRENT DERATING CURVE
FIG.4-MAXIMUM NON-REPETITIVE PEAK
FORWARD SURGE CURRENT
40
SS15-SS110
1.0
0.5
SS12-SS14
CURRENT, AMPERES
PEAK FORWARD SURGE
Single Phase Half Wave 60Hz
Resistive or Inductive Load
CURRENT,AMPERES
AVERAGE FORWARD RECTIFIED
1.5
30
8.3mS SINGLE HALF
SINE-WAVE
(JEDEC Method)
10
50
75
100
125
150
10
NUMBER OF CYCLES AT 60Hz
AMBIENT TEMPERATURE, ℃
Rev 8: Nov 2014
2.0
www.born-tw.com
Page 2 of 2
100
很抱歉,暂时无法提供与“SS14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.42904
- 500+0.14260
- 2500+0.09524
- 5000+0.07825
- 国内价格
- 20+0.16632
- 200+0.13425
- 600+0.11643
- 5000+0.09148
- 10000+0.08230
- 20000+0.07722
- 国内价格
- 20+0.15246
- 500+0.10672
- 2000+0.10512
- 5000+0.08385
