RS3219-3.3YF5
RS3219-3.3YF5
    RUNIC(润石)
    SOT23-5
    LDO Vin(Max)=5.5V Iout=300mA Vout=3.3V 固定
RS3219-3.3YF5 数据手册
此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 Low Power, Low Dropout, 300-mA Low-Noise, Low-IQ LDO FEATURES DESCRIPTION  Low Output Noise The RS3219 series low-power, low-dropout, CMOS LDO operate from 2.5V to 5.5V input voltage that can supply up to 300 mA of output current. Designed to meet the requirements of RF and analog circuits, the RS3219 series device provides low noise, high PSRR, low quiescent current, and low line and load transient response. The device is designed to work with a 1-µF input and a 1-µF output ceramic capacitor (no separate noise bypass capacitor required). An external noise bypass capacitor connected to the device’s BP pin can further reduce the noise level. Other features include a 10nA logic- controlled shutdown mode, foldback current limit and thermal shutdown protection. The RS3219 series is available in Green SOT23-3, SOT23-5 and SOT353 (SC70-5) packages. It operates over an ambient temperature range of 40°C to +85°C.  Low Dropout Voltage  Thermal-Overload Protection  Output Current Limit  10nA Logic-Controlled Shutdown  Available in Multiple Output Voltage Versions  Fixed Outputs of 1.5V,1.8V,2.5V,3.3V APPLICATIONS • Cellular Telephones • Camera Modules • Sensors • • HiFi Audio Radio Transceivers PLL/Synthesizer, Clocking • Medium-Current, Noise-Sensitive Applications Functional Block Diagram Current Limit IN 1.2V VREF OUT Error amp Internal Controller Thermal Shutdown EN BP GND REV A.3 1 Copyright © 2017, RUNIC Technology www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 Pin Configuration and Functions (Top View) IN 1 GND 2 EN 3 5 OUT 4 BP SOT23-5/SOT353(SC70-5) SOT353 (SC70-5) / SOT23-5 NUMBER DESCRIPTION I/O NAME 1 IN I Regulator Input. Supply voltage can range from 2.5V to 5.5V. Bypass with a 1μF capacitor to GND. 2 GND G Ground. 3 EN I 4 BP O 5 OUT O Shutdown Input. A logic low reduces the supply current to 10nA. Connect to IN for normal operation. Reference-Noise Bypass (fixed voltage version only). Bypass with a low-leakage 0.1μF ceramic capacitor for reduced noise at the output. Regulator Output. GND 1 3 OUT IN 2 SOT23-3 SOT23-3 NUMBER NAME DESCRIPTION I/O 1 GND G Ground. 2 OUT O Regulator Output. 3 IN I Regulator Input. Supply voltage can range from 2.5V to 5.5V. Bypass with a 1μF capacitor to GND. 2 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted)(1)(2) MIN MAX UNIT VIN Input voltage -0.3 6 V VOUT Output voltage -0.3 VIN + 0.3 V VEN Enable input voltage -0.3 VIN V TJ Junction temperature 150 °C PD Continuous power dissipation(3) Tstg Storage temperature (1) (2) (3) W Internally Limited -65 150 °C Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltages are with respect to the GND pin. Internal thermal shutdown circuitry protects the device from permanent damage. ESD Ratings VALUE V(ESD) ±2000 ±200 Human-body model (HBM) Electrostatic discharge UNIT Machine model(MM) V V Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted)(1) MIN MAX UNIT 5.5 V 5 V VIN Input supply voltage 2.5 VOUT Output voltage 1.2 VEN Enable input voltage 0 VIN V IOUT Output current 0 300 mA –40 85 °C TJ (1) Junction temperature All voltages are with respect to the GND pin. Thermal Information THERMAL METRIC(1) RS3219 RS3219 SOT23-5 SOT353( SC70-5) 5 PINS 5 PINS UNIT RθJA Junction-to-ambient thermal resistance 230 230 °C/W RθJC(top) Junction-to-case (top) thermal resistance 150 100 °C/W RθJB Junction-to-board thermal resistance 55 70 °C/W ψJT Junction-to-top characterization parameter 30 5 °C/W ψJB Junction-to-board characterization parameter 55 70 °C/W RJC(bot) Junction-to-case (bottom) thermal resistance N/A N/A °C/W 3 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 ELECTRICAL CHARACTERISTICS (VIN = VOUT (NOMINAL) + 0.5V (1), Full = -40 PARAMETER Input Voltage to +85 , unless otherwise noted.) SYMBOL CONDITIONS VIN Output Voltage Accuracy (1) IOUT = 0.1mA Maximum Output Current (1) Current Limit (1) ILIM Ground Pin Current IQ IOUT = 1mA Dropout Voltage (2) ΔVLNR Load Regulation ΔVLDR Output Voltage Noise en Power Supply Rejection Ratio PSRR MIN MAX UNITS +25 2.5(1) 5.5 V +25 -3.0 6.0 % +25 300 +25 300 +25 TYP mA 500 100 mA 200 1.5 +25 IOUT = 300mA Line Regulation (1) SHUTDOWN No load, EN = 2V TEMP 280 400 µA mV VIN = 2.5V or (VOUT + 0.5V) to 5.5V, IOUT = 1mA +25 0.03 0.09 %/V IOUT =0.1mA to 300mA, COUT = 1µF, +25 0.002 0.005 %/mA f = 10Hz to 100kHz, CBP = 0.1µF, COUT = 10µF +25 28 µVRMS +25 67 dB +25 64 dB f = 217Hz CBP = 0.1μF, ILOAD = 50mA, COUT = 1μF, VIN = VOUT+1V f = 1kHz (3) VIH EN Input Threshold VIN = 2.5V to 5.5V, VEN = -0.3V to VIN VIL IB(SHDN) EN = 0V or EN = 5.5V Shutdown Supply Current IQ(SHDN) EN = 0.4V Shutdown Exit Delay 0.7x VIN V Full EN Input Bias Current (4) Full CBP = 0.01μF, COUT = 1μF, No Load +25 0.3 0.01 1 μA Full 0.01 Full 0.01 μA 30 μs +25 THERMAL PROTECTION Thermal Shutdown Temperature Thermal Shutdown Hysteresis TSHDN 150 ΔTSHDN 15 NOTES: 1. VIN = VOUT (NOMINAL) + 0.5V or 2.5V, whichever is greater. 2. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT + 0.5V. (Only applicable for VOUT = +2.5V to +5.0V.) 3. VEN = -0.3V to VIN 4. Time needed for VOUT to reach 90% of final value. 4 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 TYPICAL APPLICATION CIRCUIT 5Pin Typical Circuit VIN OUT CIN 1uF COUT 1uF RS3219 ON OFF EN BP GND CBP 0.1uF 3Pin Typical Circuit VIN OUT CIN 1uF COUT 1uF RS3219 GND 5 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 TYPICAL PERFORMANCE CHARACTERISTICS VIN = VOUT (NOMINAL) + 0.5V, CIN = 1μF, COUT = 1μF, CBP = 0.1μF, TA = +25℃, unless otherwise noted. SHUTDOWN START UP 2V 2V EN 0V 0V EN VOUT 3V 3.3V 0V 0V VOUT Time(20us/div) Time(200us/div) LOAD-TRANSIENT RESPONSE LOAD-TRANSIENT RESPONSE 300mA 50mA 0mA ILOAD 0mA 3.5V ILOAD 3.5V 3.3V VOUT 3.3V 3.1V VOUT 3.1V Time(100us/div) Time(100us/div) GROUND CURRENT vs TEMPERATURE 150 GROUND CURRENT vs LOAD CURRENT 250 230 140 Ground Current(uA) Ground Current(uA) 210 130 190 120 170 150 110 130 100 110 90 90 -40 -15 10 35 60 85 0 50 100 150 200 250 300 Load Current(mA) Temperature(℃) 6 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 TYPICAL PERFORMANCE CHARACTERISTICS VIN = VOUT (NOMINAL) + 0.5V, CIN = 1μF, COUT = 1μF, CBP = 0.1μF, TA = +25℃, unless otherwise noted. GROUND CURRENT vs INPUT VOLTAGE CURRENT LIMIT vs TEMPERATURE 600 140 550 120 500 Current Limit(mA) Ground Current(uA) 160 100 450 80 400 350 60 300 40 250 20 200 0 0 1 2 3 4 Input Votage(V) -40 5 3 0.3 Output Voltage Accuracy(%) Output Voltage(V) 0.4 2.5 2 1.5 10 35 Temperature(℃) 60 85 OUTPUT VOLTAGE ACCURACY vs TEMPERATURE OUTPUT VOLTAGE vs INPUT VOLTAGE 3.5 -15 0.2 0.1 0 -0.1 1 -0.2 0.5 -0.3 -0.4 0 0 1 2 3 4 Input Votage(V) -40 5 7 -15 10 35 Temperature(℃) 60 85 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 PACKAGE/ORDERING INFORMATION MODEL VOUT (V) PINPACKAGE ORDERING NUMBER PACKAGE MARKING PACKAGE OPTION RS3219-3.3 3.3V SOT23-3 RS3219-3.3YF3 LA33 Tape and Reel, 3000 RS3219-3.3 3.3V SOT23-5 RS3219-3.3YF5 LA33 Tape and Reel, 3000 RS3219-3.3 3.3V SOT353 (SC70-5) RS3219-3.3YC5 LA33 Tape and Reel, 3000 RS3219-2.5 2.5V SOT23-3 RS3219-2.5YF3 LA25 Tape and Reel, 3000 RS3219-2.5 2.5V SOT23-5 RS3219-2.5YF5 LA25 Tape and Reel, 3000 RS3219-2.5 2.5V SOT353 (SC70-5) RS3219-2.5YC5 LA25 Tape and Reel, 3000 RS3219-1.8 1.8V SOT23-3 RS3219-1.8YF3 LA18 Tape and Reel, 3000 RS3219-1.8 1.8V SOT23-5 RS3219-1.8YF5 LA18 Tape and Reel, 3000 RS3219-1.8 1.8V SOT353 (SC70-5) RS3219-1.8YC5 LA18 Tape and Reel, 3000 RS3219-1.5 1.5V SOT23-3 RS3219-1.5YF3 LA15 Tape and Reel, 3000 RS3219-1.5 1.5V SOT23-5 RS3219-1.5YF5 LA15 Tape and Reel, 3000 RS3219-1.5 1.5V SOT353 (SC70-5) RS3219-1.5YC5 LA15 Tape and Reel, 3000 8 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 PACKAGE OUTLINE DIMENSIONS SOT23-3 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 9 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 10 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 RS3219 SOT353 (SC70-5) D 1.30 b 1.9 E E1 0.75 Pin1 Index Area 0.65 0.4 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Symbol Dimensions In Millimeters L1 Dimensions In Inches Min Max Min Max A 0.900 1.100 0.035 0.043 A1 0.000 0.100 0.000 0.004 A2 0.900 1.000 0.035 0.039 b 0.150 0.350 0.006 0.014 c 0.080 0.150 0.003 0.006 D 2.000 2.200 0.079 0.087 E 1.150 1.350 0.045 0.053 E1 2.150 2.450 0.085 0.096 e 0.650(BSC) 0.026(BSC) e1 1.300(BSC) 0.051(BSC) L 0.260 L1 θ 0.460 0.010 0.525 0° 0.018 0.021 8° 11 0° 8° www.run-ic.com
RS3219-3.3YF5 价格&库存
很抱歉,暂时无法提供与“RS3219-3.3YF5”相匹配的价格&库存,您可以联系我们找货
RS3219-3.3YF5
    RS3219-3.3YF5
    • 10+0.31500
    • 100+0.27300
    • 600+0.23000
    • 1200+0.22655
    • 3000+0.18800
    库存:1446
