OK06XK
OK06XK
    RUNIC(润石)
    SOIC-8
    6.5MHz,SOIC8_150MIL,轨对轨输入/输出CMOS运算放大器
OK06XK 数据手册
此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 6.5MHz, Rail-to-Rail I/O CMOS Operational Amplifier FEATURES DESCRIPTION  HIGH GAIN BANDWIDTH:6.5MHz  RAIL-TO-RAIL INPUT AND OUTPUT 0.8mV Typical Vos INPUT VOLTAGE RANGE: -0.1V to +5.6V with Vs = 5.5V   SUPPLY RANGE: +2.5V to +5.5V  SPECIFIED UP TO +125°C The OK06 offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (6.5MHz) and slew rate of 3.7V/us. The op-amps are unity gain stable and feature an ultra-low input bias current. The devices are ideal for sensor interfaces, active filters and portable applications. The OK06 operational amplifier are specified at the full temperature range of −40°C to +125°C under single or dual power supplies of 2.5V to 5.5V. APPLICATIONS  SENSORS  PHOTODIODE AMPLIFICATION  ACTIVE FILTERS  TEST EQUIPMENT  DRIVING A/D CONVERTERS PIN CONFIGURATIONS OK06 OUT A 1 -IN A 2 +IN A 3 V- A B 4 8 V+ 7 OUT B 6 -IN B 5 +IN B SOIC-8 REV A.2 1 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 ABSOLUTE MAXIMUM RATINGS (1) Supply Voltage, V+ to V-...............................................7.0V (2) Input Terminals, Voltage …………... – 0.5 to (V+) + 0.5V (2) Current …………………....…..... ±10mA Storage Temperature ……….…………… −65°C to +150°C Operating Temperature ……….………… −40°C to +125°C Junction Temperature................................................150°C Package Thermal Resistance @ TA = +25°C SOT23-5, SOT23-6………………….………………200°C/W MSOP-10, SOIC-8 …………………….…………... 150°C/W SOIC-14, TSSOP-14………….……….……………100°C/W Lead Temperature (Soldering, 10s) ……………........260°C ESD Susceptibility HBM …......................................................................5000V MM ……………………….........………………...……….400V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be current-limited to 10mA or less. PACKAGE/ORDERING INFORMATION PRODUCT ORDERING NUMBER OK06 OK06XK TEMPERATURE PACKAGE PACKAGE RANGE LEAD MARKING -40℃~125℃ SOIC-8 OK06 2 PACKAGE OPTION Tape and Reel,2500 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS OK06 TJ MIN POWER SUPPLY Vs Operating Voltage Range IQ Quiescent Current/Amplifier PSRR Power-Supply Rejection Ratio 25°C 25°C 25°C –40°C to 125°C Vs= 2.5V to 5.5V INPUT Vos Input Offset Voltage 25°C Vos TC Input Offset Voltage Average Drift-40°C to 125°C Input Bias Current IB 25°C Ios Input Offset Current 25°C Vcm Common-Mode Voltage Range Vs=5.5V 25°C Vs = 5.5V, Vcm 25°C =-0.1V to 4V –40°C to 125°C CMRR Common-Mode Rejection Ratio Vs = 5.5V, Vcm 25°C = -0.1V to 5.6V –40°C to 125°C OUTPUT RL =2KΩ, Vo = 25°C 0.15V to 4.85V –40°C to 125°C AOL Open-Loop Voltage Gain RL = 10kΩ, Vo = 25°C 0.05V to 4.95V –40°C to 125°C RL = 2KΩ 25°C Output Swing From Rail RL = 10kΩ 25°C Iout Output Short-Circuit Current 25°C FREQUENCY RESPONSE SR Slew Rate 25°C GBP Gain-Bandwidth Product 25°C Phase Margin Φm 25°C ts Settling Time, 0.1% VIN • Gain ≥ Vs Overload Recovery Time NOISE f = 1 kHz 25°C en Input-Referred Voltage Noise f = 10 kHz 25°C 3 TYP 2.5 75 72 590 94 0.8 2 1 1 -0.1 74 68 62 60 95 83 98 85 MAX UNIT 5.5 820 V uA dB 3 10 10 5.6 mV uV/°C pA pA V 92 83 dB 100 106 40 7 50 dB mV mA 3.7 6.5 63 0.5 0.5 V/us MHz ° us us 12 8 nV/√Hz nV/√Hz www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩconnected to VS/2, VOUT = VS/2, unless otherwise noted. COMMON−MODE REJECTION RATIO vs FREQUENCY OPEN−LOOP GAIN AND PHASE vs FREQUENCY Phase 100 120 80 100 60 80 40 60 20 40 0 20 -20 10 1K 100K 120 140 100 CMRR(dB) 120 Open-Loop Gain(dB) 160 Gain Phase Margin (°) 140 80 60 40 0 10M 20 1 10 Frequency(Hz) INPUT VOLTAGE NOISE SPECTRAL DENSITY vs FREQUENCY Voltage Noise (nV/√Hz) 1000 10K 100 PSRR(dB) 100 10 80 60 40 20 1 10 100 1K 10K 1 100K 10 100 1K 10K Frequency(KHz) Vs=5V Frequency(Hz) QUIESCENT CURRENT vs TEMPERATURE QUIESCENT CURRENT vs TEMPERATURE 0.8 0.8 Quiescent Current(mA) Quiescent Current(mA) 1K POWER−SUPPLY REJECTION RATIO vs FREQUENCY 120 | | 100 Frequency(KHz) Vs=5V 0.7 0.6 0.5 0.7 0.6 0.5 0.4 0.4 -40 -20 0 -40 -20 20 40 60 80 100 120 140 0 20 40 60 80 100 120 140 Temperature(℃) Vs=5V Temperature(℃) Vs=2.7V 4 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩconnected to VS/2, VOUT = VS/2, unless otherwise noted. SOURCE CURRENT vs TEMPERATURE 60 58 56 54 52 50 48 46 44 42 40 Source Current(mA) Sink Current(mA) SINK CURRENT vs TEMPERATURE -40 -20 0 70 68 66 64 62 60 58 56 54 52 50 48 46 44 42 40 20 40 60 80 100 120 140 -40 -20 0 Temperature(℃) INPUT BIAS CURRENT vs TEMPERATURE 20 40 60 80 100 120 140 Temperature(℃) SMALL−SIGNAL STEP RESPONSE 10K 50mV/div 100 10 1 0.1 -40 -20 0 20 40 60 200ns/div 80 100 120 140 Temperature(℃) POSITIVE OVERLOAD RECOVERY CL=100PF 200mV/div LARGE−SIGNAL STEP RESPONSE 0V VIN 1V/div VOUT 0V 400ns/div VS=±2.5V G=-100 1V/div Input Bias Current(pA) CL=100PF 1K 500ns/div 5 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩconnected to VS/2, VOUT = VS/2, unless otherwise noted. NEGATIVE OVERLOAD RECOVERY VIN 0V 1V/div 0V Percentage of Amplifiers (%) 200mV/div 25 VS=±2.5V G=-100 VOUT 20 OFFSET VOLTAGE PRODUCTION DISTRIBUTION 12300 Samples 1 Production Lot VS = ±2.5V 15 10 5 0 500ns/div -4 -3 -2 -1 0 1 2 3 Offset Voltage (mV) 6 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 APPLICATION NOTES The OK06 is high precision, rail-to-rail operational amplifiers that can be run from a single-supply voltage 2.5V to 5.5V (±1.25V to ±2.75V). Supply voltages higher than 7V (absolute maximum) can permanently damage the amplifier. INSTRUMENTATION AMPLIFIER In the three-op amp, instrumentation amplifier configuration shown in Figure2, Rail-to-rail input and output swing significantly increases dynamic range, especially in low-supply applications. V1 OK06 Good layout practice mandates use of a 0.1uF capacitor place closely across the supply pins. OK06 VOUT LAYOUT GUIDELINS OK06 V2 Attention to good layout practices is always recommended. Keep traces short. When possible, use a PCB ground plane with surface-mount components placed as close to the device pins as possible. Place a 0.1uF capacitor closely across the supply pins. These guidelines should be applied throughout the analog circuit to improve performance and provide benefits such as reducing the EMI susceptibility. Figure2. Amplifier instrumentation amplifier +Vs 10uF 0.1uF Vin Vip Vout OK06 10uF 0.1uF -Vs Figure1. Amplifier with Bypass Capacitors 7 www.run-ic.com 此文档权利由RUNIC(润石)享有,您也可访问RUNIC(润石)官方网站获取;立创商城 WWW.SZLCSC.COM,中国领先的现货元器件交易平台。 OK06 PACKAGE OUTLINE DIMENSIONS SOIC-8 b e 5.2 E E1 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 8 www.run-ic.com
OK06XK 价格&库存
很抱歉,暂时无法提供与“OK06XK”相匹配的价格&库存,您可以联系我们找货
OK06XK
  • 5+0.40800
  • 20+0.37200
  • 100+0.33600
  • 500+0.30000
  • 1000+0.28320
  • 2000+0.27120
