JFWSI13B20A204C
JFWSI13B20A204C
    JF(晶发)
    HC49S
    无源晶振 20pF 35Ω ±20ppm HC49S 13.52127MHz -20℃~+70℃
JFWSI13B20A204C 数据手册
深 圳 市 晶 发 电 子 有 限 公 司 SHENZHEN JINGFA ELECTRONICS CO.,LTD 规格书 SPECIFICATION 产品名称 石英晶体谐振器 Description Crystal Unit 型号 · 标称频率 Type · Nominal Frequency 49S 13.52127MHz 规格书号 Specification . JFWSI13B20A204C 制作 DESIGNED BY 杨 阳 BY 何 珍 APPROBED BY 肖 琳 审核 CHECKED 批准 工厂地址:深圳市宝安区福永安达电子工业区4栋6楼 电话:0755-23001622 传真:0755-26741500 网址:www.jingfadianzi.com 深 圳 市 晶 发 电 子 有 限 公 司 SHENZHEN JINGFA ELECTRONICS CO.,LTD 技术特性Specification 1 标称频率 Nominal Frequency 13.52127MHz 2 规格型号 Holder Type 3 振动模式 Mode of Oscillation Fund AT 4 调整频差 Frequency Tolerance at( 25℃±2℃) ±20ppm 5 温度频差 Temperature Frequency Stability vs Temp ±20ppm 6 工作温度 Operating Temperature Range -20~+70℃ 7 贮存温度 Storage Temperature Range -45~+80℃ 8 负载电容 Load Capacitance 9 静电容 Shunt capacitance 10 等效电阻 Equivalent Series Resistance ≤35Ω(Max) 11 激励功率 Drive Level 100 u W 12 绝缘阻抗 Insulation Resistance 500MΩat DC100V 13 年老化率 Aging Rate a Year ±5PPM HC-49S 20pF <5PF(Max) 尺寸构造Dimensions&Stucture 工厂地址:深圳市宝安区福永安达电子工业区4栋6楼 电话:0755-23001622 传真:0755-26741500 网址:www.jingfadianzi.com 深 圳 市 晶 发 电 子 有 限 公 司 SHENZHEN JINGFA ELECTRONICS CO.,LTD 机械及环境性能Environmental&Physical Characteristics 1. 2.. 3. Item Condition Drop characteristics Free drop from 75cm height on a hard wooden board 跌落性 for 3 times. (Board is thickness more than 30 mm.) Shake characteristics 振动性 4. 5. ≤5ppm hours. Rr as specification pressure 0.4~0.5mpa 10 minutes, then take out and Bend characteristics 弯曲性 characteristics 260±5℃, 3 seconds 90% exhibit tin ok 5N,90°,3 times, test machine no damage Frequency change: +40±2℃ & 90%~95% R.H. 250 hours 7. characteristics 低温性 High temperature 8. characteristics 高温性 ≤5ppm Rr as specification 恒温性 Low temperature IR≥500MΩ blow for 5 minutes Humidity 6. Rr as specification 1.5mm, direction x/y/z, all 30 minutes, test after 1 characteristics 可焊性 ≤5ppm Frequency change: Put crystal into the pressure cabin with alcohol, keep Weld characteristics Frequency change: Shake frequency 10~55Hz, cyc1~2 minutes, swing Airproof 密封性 Standard -30±2℃, 250 hours, put in room temperature, test after 1 hours. +85±2℃, 250 hours, put in room temperature, test after 1 hours. Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification 工厂地址:深圳市宝安区福永安达电子工业区4栋6楼 电话:0755-23001622 传真:0755-26741500 网址:www.jingfadianzi.com 深 圳 市 晶 发 电 子 有 限 公 司 SHENZHEN JINGFA ELECTRONICS CO.,LTD 温度循环Temperature cycling Condition: ℃ ℃ ℃ ℃ ℃ ℃ 回流焊测试Refluence examination 工厂地址:深圳市宝安区福永安达电子工业区4栋6楼 电话:0755-23001622 传真:0755-26741500 网址:www.jingfadianzi.com 深 圳 市 晶 发 电 子 有 限 公 司 SHENZHEN JINGFA ELECTRONICS CO.,LTD Dimension of Inside Package 内包装尺寸图 200pcs/bag*10=1 inner box Dimensions of outside Package 外包装尺寸图 10 inner box=1 outer box 工厂地址:深圳市宝安区福永安达电子工业区4栋6楼 电话:0755-23001622 传真:0755-26741500 网址:www.jingfadianzi.com
JFWSI13B20A204C 价格&库存
很抱歉,暂时无法提供与“JFWSI13B20A204C”相匹配的价格&库存,您可以联系我们找货
