7U11289AE20UCG
7U11289AE20UCG
    SJK(晶科鑫)
    SMD3225_4P
    无源晶振 20pF 150Ω ±10ppm -40℃~+85℃ 11.2896MHz SMD3225_4P
7U11289AE20UCG 数据手册
QUARTZ CRYSTAL UNIT SERIES 7U, SEAM SEALED CERAMIC3.2*2.5MM SURFACE MOUNT PACKAGE 深圳市晶科鑫实业有限公司 Shenzhen Crystal Technology Industrial Co., Ltd APPROVAL SHEET CUSTOMER P/N: TYPE: DESCRIPTION: P N/ SJK: SMD CRYSTAL SMD3225 MSL: 20PF ±10PPM -40~85℃ □PAHS □other 7U11289AE20UCG ENVIRONMENTAL: ■RoHS REVISION: 11.2896MHZ A1 ■REACH ■HF 2017-5-10 MOQ: 3000pcs/real Levels 1 SIGNATURE SUPPLIER Issue Check CUSTOMER Approve QA SJK Signature FAE_EMAIL Date Date Check Approve: □accept Approve □unaccepted Note: Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 1 /4 QUARTZ CRYSTAL UNIT SERIES 7U, SEAM SEALED CERAMIC3.2*2.5MM SURFACE MOUNT PACKAGE 1. TESTING CONDITION Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity : 40%~70% Measure equipment Electrical characteristics measured by S&A250B or equivalent. 2. ELECTRICAL SPECIFICATIONS Output Frequency Range 11.289600MHz Mode AT/Fundamental Frequency Tolerance ±10 ppm max Load Capacitance(CL) 20.0 PF Frequency Stability Over Operating Temperature Characteristics (at 25°C) ±30ppm max Operating Temperature Range -40 °C to +85 °C Storage Temperature Range -40 °C to +125 °C Shunt Capacitance (C0) 3.0 PF Max Driver Level (Typical) 10µW Equivalent Series Resistance(ESR) 150Ω Max Aging @25°C 1st year (Max) ±3ppm/year Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 2 /4 QUARTZ CRYSTAL UNIT SERIES 7U, SEAM SEALED CERAMIC3.2*2.5MM SURFACE MOUNT PACKAGE 3. DIMENSION (Units: mm) 4. MARKING 5. REFLOW CONDITION Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 3 /4 QUARTZ CRYSTAL UNIT SERIES 7U, SEAM SEALED CERAMIC3.2*2.5MM SURFACE MOUNT PACKAGE 6. RELIABILITY TEST SPECIFICATION 1.Mechanical Endurance No. Test Item Test Methods REF.DOC 1.1 Drop Test 150 cm height, 3 times on concrete floor. JIS C6701 1.2 Mechanical Shock 1.3 Vibration 1.4 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm2 MIL-STD-883E 1.5 Fine Leak Helium Bombing 4.5 Kg/ cm2 for 2 hr MIL-STD-883E 1.6 Solder ability Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 hours (Total test time 12 hours) Temperature Immersing depth Immersion time Flux 245 ℃ ± 5℃ 0.5 mm minimum 5 ± 1 seconds Rosin resin methyl alcohol solvent ( 1 : 4 ) MIL-STD-202F MIL-STD-883E MIL-STD-883E 2.Environmental Endurance No. Test Item Test Methods 2.1 Resistance To Soldering Heat Pre-heat temperature Pre-heat time 60 ~ Test temperature Test time 2.2 2.3 High Temp. Storage Low Temp. Storage REF.DOC 125 ℃ 120 sec. 260 ± 5 ℃ 10 ± 1 sec. MIL-STD-202F + 125 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E - 40 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E Total 100 cycles of the following temperature cycle 2.4 2.5 2.6 Thermal Shock High Temp &Humidity Pressure Cooker Storage MIL-STD-883E 85℃ ± 3℃, RH 85% , 500Hrs JIS C5023 121 ± 3℃ , RH100% , 2 bar , 240Hrs JIS C6701 Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 4 /4
7U11289AE20UCG
1. 物料型号:7U11289AE20UCG,属于SMD CRYSTAL,描述为SMD3225 20PF 11.2896MHZ,环境要求为ROHS REACH HF。
2. 器件简介:这是一系列7U,缝封陶瓷3.22.5MM表面贴装封装的石英晶体单元。
3. 引脚分配:文档中未明确提及引脚分配,但通常石英晶体单元会有至少两个引脚,分别连接到电路的地和信号源。
4. 参数特性: - 输出频率范围:11.289600MHz - 频率容差:±10 ppm 最大值(在25°C) - 负载电容(CL):20.0 PF - 频率稳定性在工作温度范围内:±30ppm 最大值 - 工作温度范围:-40 °C 至 +85 °C - 存储温度范围:-40 °C 至 +125 °C - 并联电容(Co):3.0 PF 最大值 - 驱动电平(典型值):10 W - 等效串联电阻(ESR):150 最大值 - 老化 @25°C 第一年(最大值):±3ppm/年
5. 功能详解:文档中未提供详细的功能描述,但石英晶体单元通常用于为电子设备提供稳定的时钟信号。
6. 应用信息:文档中未明确提及应用信息,但石英晶体单元广泛应用于需要精确时钟信号的各种电子设备。
7. 封装信息:3.22.5MM表面贴装封装,适用于SMD技术。
8. 可靠性测试规范:包括机械耐久性测试和环境耐久性测试,如跌落测试、机械冲击测试、振动测试、气密性测试、焊接能力测试、耐焊接热测试、高温存储、低温存储、热冲击、高温高湿、压力锅存储等。
9. 回流条件:提供了预热、主要加热和峰值温度的时间和温度设置。
10. 联系信息:包括供应商的联系电话、传真、网址和地址。
7U11289AE20UCG 价格&库存
很抱歉,暂时无法提供与“7U11289AE20UCG”相匹配的价格&库存,您可以联系我们找货
7U11289AE20UCG
  • 1+0.67014
  • 30+0.64719
  • 100+0.62424
  • 500+0.57834
  • 1000+0.55539
  • 2000+0.54162
库存:295
